Settled on new Clutch/FW combo - Mustang Evolution
Old 12-01-2014, 12:55 PM   #1
Deerslayer's Avatar
Clutch is still solid in this car, but I know it is a matter of time with the power it is putting down. After doing a lot of research, I decided to go this route to keep the daily drivability as close to stock as possible:
Exedy Mach 500 Stage 3 clutch
Exedy Lightweight Steel Racing Flywheel
Exedy Hydraulic TOB
Already have the McLeod Braided clutch line, MGW shifter and the Blowfish Bracket and removed the helper spring. This transmission has never been notchy at all and been a great shifting transmission, but will still occasionally get the high RPM lockout. Would have gone the McLeod route, but really did not want a dual disc clutch without springs.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-01-2014, 01:08 PM   #2
Rapinator126's Avatar
Why you going steel?
I went with the aluminum one. No problems not even when the car had the bottle on it
Old 12-01-2014, 01:12 PM   #3
Deerslayer's Avatar
Steel's engagement is a little smoother. Plus, I got a really good deal on a Exedy Lightweight Racing FW.
$750 shipped for the Clutch/Pressure Plate, Pilot Bearing, Hydraulic TOB/Slave Cyl, Lightweight Racing Flywheel & Dowels
Old 12-01-2014, 01:18 PM   #4
That's not bad at all, I keep 4 getting it's your sons DD also.
Old 12-01-2014, 01:20 PM   #5
Deerslayer's Avatar
^^ exactly ^^ If it was tracked more, or my second car, I would have gone the McLeod route. This car does not have NEAR enough room for me to haul around deer or hogs after my hunts
which flywheel clutch combo u guys recommend? Xavier9370 1996-2004 Mustang GT 26 04-18-2013 01:39 PM
New rim/tire combo :) milgt 2011-2014 Mustang GT 23 08-19-2012 05:33 PM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 04:53 PM
settled on my car today, insurance-wise jimmy_beaner The Bar 23 05-08-2006 04:34 AM
As the sun settled just before dusk in the South... KrazyPony Pictures and Videos 14 04-25-2005 07:10 PM
09:27 PM
