Suspension cold? - Mustang Evolution
Old 12-01-2014, 02:41 PM   #1
Suspension cold?
Question: This morning while driving around I noticed my suspension was making some noises at low speeds, mainly 5mph or so. Going over bumps it was making loud squeaking sounds, turning my wheel while stopped made some popping sounds. Kinda like an old suspension would sound like. 13 GT, 13k miles, all stock suspension. It's 20 degrees out, any cause for concern?
Old 12-01-2014, 04:16 PM   #2
Deerslayer's Avatar
That is exactly what happens to my bones on cold days too.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 12-01-2014, 04:42 PM   #3
DallasStang77's Avatar
That's exactly what happens to my GF when the weather is cold. She squeals and squeaks and chatters until the car is warmed up and heater is hot.
Old 12-01-2014, 05:30 PM   #4
This info is all really helpful, thanks.
Old 12-01-2014, 06:01 PM   #5
zinc03svt's Avatar
I've driven mine in 20 degree weather and no squeaks nor noises over bumps etc. 3500 miles.
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 12-01-2014, 07:06 PM   #6
Stangholio's Avatar
Couple weeks ago we had a cold front and it got into the 20's. I didn't notice any unusual noises.
Stangholio is offline   Reply With Quote
Old 12-01-2014, 09:50 PM   #7
SilverGT_CS's Avatar
If it's coming from the front end it could be the tie rod ends or bad strut mounts. My 2014 gt was making a squeaking noise at low speeds over bumps. Both of these were replaced at less than 3000 miles on my car
Sent from my 831C using Mustang Evolution mobile app
SilverGT_CS is offline   Reply With Quote
Old 12-01-2014, 11:31 PM   #8
Suspension cold?
1.) You didn't apply enough grease to the joints and bolts
2.) You didn't apply enough grease to the joints and bolts so when the weather gets cold the grease gets less viscous so it's less effective.
Old 12-03-2014, 12:48 PM   #9
Evil_Monkey's Avatar
I recently bought a '14 GT with 12.5k miles on it and I heard the same thing on the front end when going over speed bumps, etc. brought it to the dealer since its under warranty and they say it's the drivers side control arm.
I don't know if that's really the cause, but I'll know soon enough.
Evil_Monkey is offline   Reply With Quote
Old 12-04-2014, 12:13 PM   #10
crroy71's Avatar
Mine did the same thing, brought it to the dealer and there was a TSB for the control arm bushings. They replaced both control arms and bushings. No problems since.
Chris
crroy71 is offline   Reply With Quote
Running lean on Cold start in cold temperatures. Zed 2011-2014 Mustang GT 3 09-24-2014 07:23 AM
suspension noise in cold weather jeremysuarez94 2011-2014 V6 Mustang 8 11-25-2013 08:53 PM
COLD AIR INTAKE or SHAKER COLD AIR INTAKE zalizar21 2005-2010 V6 Mustang 14 08-19-2012 07:41 AM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 11:22 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
11:06 PM
