Wheel alignment in AL - Mustang Evolution
Old 12-02-2014, 06:00 PM   #1
Evil_Monkey's Avatar
Hey guys. I recently moved and I just got a '14 GT. I am thinking of lowering it 1.5" in the front and 2" in the rear.
I wanted to see if anyone knew of a good place to bring it for alignment near Birmingham that specializes in lowered cars. Any advice would be very helpful. Thanks!
Evil_Monkey is offline   Reply With Quote
Old 12-02-2014, 07:12 PM   #2
BigJay's Avatar
If you cant find a shop that specializes these cars are basic to align. If you want a street performance type alignment go with -1.5 to -2.0 in camber and toe in about 1mm. If you have camber castor plates installed set the caster as far positive that you can same both sides probably around+7 is all you can get. Any alignment shop should be able to dial in those numbers.
BigJay is offline   Reply With Quote
Old 12-02-2014, 08:10 PM   #3
Ok. Gotcha. I ended up getting camber bolts for the front since it isn't a drastic drop and a panhard rod for the rear. Hopefully those will help keep it close to where it needs to be after its lowered. Do you think somewhere like Kauffman, etc would be able to get it in the range that it needs to be in?
I'm putting new tires on it at the same time, so I want to try to not kill them before I get to break them in if at all possible.
Old 12-02-2014, 10:08 PM   #4
BigJay's Avatar
Any shop should be able to get you there. With the camber bolts you won't be able to adjust caster so even easier.
Old 12-02-2014, 10:41 PM   #5
Awesome. Thanks for the help man.
Wheel alignment help Ghostedmind Pre-2005 V6 Mustang 11 12-29-2013 12:50 AM
2013 v6 Questions about wheel alignment 05MUSTANG4.0L 2011-2014 V6 Mustang 8 10-18-2013 05:31 AM
Do i need a Wheel alignment after installing new wheels Mdazi 2011-2014 Mustang GT 8 05-29-2013 02:50 PM
Wheel spacers vs alignment Raf63 2011-2014 Mustang GT 16 03-18-2013 02:29 PM
wheel alignment needed? iphonemaster93 Pre-2005 V6 Mustang 10 08-19-2012 12:27 PM
10:26 AM
