Installed BMR adjustable UCA, LCA, loud noise/clunk on sharp turns - Mustang Evolution
Old 12-06-2014, 02:18 PM   #1
Riko's Avatar
I've installed BMR adjustable UCA, non Adj LCA, relocation bracket, adj Panhand bar, Steeda ultra light springs, Koni yellow, MM caster Camber plates and adjusted the pinion angle to -2 degrees. The car runs great except when I take a sharp turn. On sharp turns I hear like a raspy noise/clunk coming from the back of the car. Today i jacked the car up and rechecked everything, retightened and the noise did not go away. Have anyone of you had experienced this issue? Any advise would be greatly appreciated.
Riko is offline   Reply With Quote
Old 12-06-2014, 02:25 PM   #2
scc2014gt's Avatar
Im in a similar boat actually just installed my eibach sportlines and bmr adj panhard bar. Im hearing a clunking noise as well. I had the shop doing the alignment tighten everything right after I did it. Somebody said that maybe the panhard bar didnt get greased up enough, so I may try that when this rain clears out.
2014 Black Mustang GT. Roush Axleback Exhaust, Airaid Intake, JLT Oil Separator, Black Billet Grille, Fog Light Relocation, 19" sve drifts with 275/40's, D2 Coilovers, BMR Panhard Bar, BRM LCA's and UCA, KOI and Oracle Orange Dip
scc2014gt is offline   Reply With Quote
Old 12-06-2014, 03:23 PM   #3
Region: Oregon
Just a thought, but when placing my order on black Friday for the BMR UCA they have this note on their page.
UTCA027 - Upper Control Arms, DOM, On-car Adjustable, Polyurethane Bushings, 9 Inch Rear | 2005 - 2014 Mustang GT | Upper Control Arms | BMR Suspension - High Performance Suspension & Chassis
*BMR strongly recommends upgrading the stock Upper Control Arm Mount when utilizing an aftermarket Upper Arm on S197 Mustangs. Clunking noise may become present without an upgraded Upper Control Arm Mount. The correct part # for this application is UCM001.
skramblr is offline   Reply With Quote
Old 12-06-2014, 04:55 PM   #4
olerodder's Avatar
Region: Oregon
Just a question, why did adjust the pinion angle to -2 degrees?
Not familiar with a two piece drive line hence the reason for asking.
Does the two piece driveline have a universal in the middle and one at the pinion? I didn't pay much attention to mine since I will be going with a one piece drive line.
Old 12-06-2014, 05:03 PM   #5
Laquisha's Avatar
Im full BMR suspension no problems here.
Naturally Aspirated Is Lyfe
Old 12-06-2014, 05:23 PM   #6
Frozen Yettie's Avatar
Did you grease?
2014 Black Mustang 3.7L V6 Premium | 93Race MPT Tuned | Too many mods to list just check out my garage.
Frozen Yettie is offline   Reply With Quote
Old 12-06-2014, 06:06 PM   #7
Laquisha's Avatar
Originally Posted by Frozen Yettie View Post
Did you grease?
No, Lube was put on though.
Old 12-06-2014, 07:38 PM   #8
Riko's Avatar
It is what BMR recommends -2 to -3 degrees for manual transmission.
---------- Post added at 09:38 PM ---------- Previous post was at 09:37 PM ----------
Did you grease?
Yes I did grease/lube
Old 12-06-2014, 07:41 PM   #9
Riko's Avatar
Did you grease?
I upgraded to the BMR Upper Control Arm Mount too.
Old 12-07-2014, 11:55 AM   #10
WhiteCali5oh's Avatar
Region: West Virgina
I have the BMR uca. Bmr uca
Mount. Bmr relocation brackets. Bmr non adj. lcas. bmr panhard bar and eibach pro kit and the only problem I have is a small squeak coming from what sounds like the uca. Other than that no other noises.
WhiteCali5oh is offline   Reply With Quote
Old 12-07-2014, 11:56 AM   #11
Laquisha's Avatar
Ha! Sucks. I have no problems with mine, did you lube all yours?
Old 12-07-2014, 11:57 AM   #12
Yeah I greased them. You can barely hear it. But. It may be the seat belt thingy rubbing against that hump in the rear seat I ain't sure yet haha
Old 12-07-2014, 12:14 PM   #13
Laquisha's Avatar
Yuck! You should get it checked, that would totally annoy me lol.
Old 12-07-2014, 12:37 PM   #14
Doesn't bother me enough to get it checked. I'll just pull the rear seat out and look
Old 12-07-2014, 12:52 PM   #15
Laquisha's Avatar
Goodluck mannn lol.
Old 12-07-2014, 12:52 PM   #16
Won't be able to hear it over this supercharger whine in a few weeks anyway lol
Old 12-08-2014, 05:12 PM   #17
I would advise removing the LCA's and UCA and check the bushings this is what happened to one of mine.
LCA bushing problem - Mustang Evolution
Check and see if your bushings are deformed if so email FordTech@bmrsuspension.com
They will send you some new bushings.
Old 12-08-2014, 06:17 PM   #18
scc2014gt's Avatar
I only replaced my panhard with a bmr adjustable and I am hearing the noise too. I wonder if I might be having the same issue on the panhard bar bushings. Definitely going to check into this too. Thanks!
Old 12-08-2014, 07:03 PM   #19
Riko's Avatar
I did remove the LCA and UCA, Bushings are good. The sound is like when metal slightly rubs against metal. The only thing I have yet to do is an alignment.
Old 12-09-2014, 05:30 PM   #20
Fabman's Avatar
Oh, baby...you gotta lube it up so everything slides nice....
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 12-09-2014, 07:18 PM   #21
Laquisha's Avatar
You know it ! πŸ”»πŸ”ΊπŸ”ΊπŸ”»
Old 12-13-2014, 11:50 AM   #22
scc2014gt's Avatar
Just left my hook up at ford. Turns out my panhard bar bolts were loose still. He tightened up and noise is gone. Problem solved! I'm pretty sure that clunking is the most annoying sound in the world.
Old 12-13-2014, 02:16 PM   #23
Famine's Avatar
Region: South Dakota
I was thinking the panhard bar. I got a full ford upgraded suspension on my old s197 and had the clunk and the common denominator is the panhard bar. Dealer looked at it numerous times and never figured it out.
Famine is offline   Reply With Quote
Old 12-14-2014, 10:59 AM   #24
Riko's Avatar
The Steeda springs ultralites are rubbing against the metal well on one side. I took them out, double checked the proper installation and reinstalled but still rubbing on one side of the metal well. the part number is 555-8206. Any advise would be greatly appreciated. Thanks
Old 12-14-2014, 02:46 PM   #25
Riko's Avatar
Issue resolved. I have the UCA length to 10 inches and it was too long. To solve the issue I shortened (screwed in) the UCA to 9.5 inches and setup the pinion angle and now the springs are no rubbing against the metal's well.
BMR adjustable UCA Ian13 2011-2014 Mustang GT 11 05-18-2015 07:50 PM
WTB: BMR UCA & mount for 2011+ GT HPFury Mustang Parts for Sale and Wanted 0 02-12-2014 08:27 PM
Adjustable UCA and panhard bar SouthFLV6 2011-2014 V6 Mustang 5 12-18-2013 05:20 PM
Bmr uca ajustment Jetag93 2011-2014 Mustang GT 10 03-28-2013 09:16 PM
grinding and popping sharp turns Blackedout Pre-2005 V6 Mustang 10 03-17-2013 08:36 PM
06:10 PM
