Lund Data Log - anyone dumb this down for me? - Mustang Evolution
Old 12-09-2014, 11:09 AM   #1
My 1st concern is am I harming my engine and do I need to put on another part?
Jon Lund II (Lund Racing Support)
Dec 08 11:46 AM
Robert,
Fueling looks pretty good, but you're getting some knock activity indicating you have a fuel quality issue or oil is getting by the PCV (if you don't have a separator or breathers) and lowering effective octane, OR it is false knock. False knock is typically caused by exhaust rubbing, etc. The next step is to pick up some octane booster like Lucas or Torco (Torco is more potent) and toss a bottle/can in and drive on it, do some WOT pulls to let the knock sensor learn then re-log the same log for me so we can see if it helps the knock activity dissipate.
Jon Lund II
20145pointOH is offline   Reply With Quote
Old 12-09-2014, 11:22 AM   #2
Voltwings's Avatar
Knock ****** is the computer keeping the engine alive by preventing detonation. Basically, he is saying that the quality of your gas is sub par, OR, you have oil reducing your effective octane.
1. If adding the octane booster clears the knock, then your gas is likely sub par and you should probably choose a different station.
2. Oil will reduce the effective octane of gas. Oil gets into the system via the PCV since the engine uses manifold vacuum to siphon the crankcase of fumes. Putting a separator in is always a good idea, i run the firewall unit from Bob's myself.
Bob's 2011+ 5.0 Ultimate Firewall Oil Separator Kit
You can always see about sourcing your own lines and fittings, but good PCV line is ~$10 a foot anyways so... you dont save much.
3. Rattles. A knock sensor is just a microphone, so it can pick up false "noise" in the engine bay such as loose exhaust bolts, an intake that isnt buttoned down ... things like that.
Heres a thread i made a while back if you'd like to familiarize yourself with your logs.
How to: Understand your datalogs
Old 12-09-2014, 11:35 AM   #3
joefez55's Avatar
Are you using 93 octane or at least the highest rating in your area ?
Sent from my 831C using Mustang Evolution mobile app
joefez55 is offline   Reply With Quote
Old 12-09-2014, 11:37 AM   #4
Only have 91 100% gas.
And that is getting tough. But yes, always 91oct
I'll look over the link, thank you. Any other advice is appreciated.
Old 12-09-2014, 11:58 AM   #5
Picked up a separator. Hopefully it's straight forward install.
Old 12-09-2014, 12:03 PM   #6
DiESeven's Avatar
the separator is probably going to be the easiest install of your life. it's even easier than reaching in your pocket for the keys and pressing the unlock button.
Old 12-09-2014, 12:11 PM   #7
Holding you to that!
Old 12-09-2014, 12:19 PM   #8
Voltwings's Avatar
Did you get the bobs one? Its not "That" easy, you have to do a little work, but its by no means a complicated install.
Old 12-09-2014, 12:20 PM   #9
Old 12-09-2014, 02:12 PM   #10
WhiteCali5oh's Avatar
Region: West Virgina
Here's what I'm doing. Vmp said he would like me to run a 91 tune but use 93 octane. On my supercharger tune in case my fuel isn't very good quality I won't be running as much timing and the octane will make up for the quality of fuel.
WhiteCali5oh is offline   Reply With Quote
Old 12-09-2014, 05:18 PM   #11
Big Q's Avatar
Region: Nebraska
Is that Bobs separator two or just one for that price?
Big Q is offline   Reply With Quote
Old 12-09-2014, 05:23 PM   #12
scott_0's Avatar
Originally Posted by Big Q View Post
Is that Bobsseparator two or just one for that price?
that's for a single side (passenger) you can add the drivers side for extra (only necessary on boosted applications) but it's a high quality piece, I bought one just recently, very very high quality, makes the JLT piece look like a toy pretty much
sent from my HTC M8 using tapatalk
Old 12-09-2014, 05:28 PM   #13
Big Q's Avatar
Region: Nebraska
Don't doubt it's a quality piece, but it's a canister, mount, pipe fittings and hose. Little spendy for my taste, Thx.
Old 12-09-2014, 06:36 PM   #14
zinc03svt's Avatar
An easy pcv fix is just picking up a breather kit for 30-40 bucks. As stated many times before your engine knock or lack of is gasoline dependent. 91 octane is usually a minimum for adding any timing. If your running a supercharger VMP on 91 octane I would invest in some torco to keep your engine alive or plan on running soft on your tunes. fyi
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 12-09-2014, 06:38 PM   #15
I'm running a 91 tune but running 93 octane. He said it would be a safety blanket.
Old 12-09-2014, 08:09 PM   #16
Voltwings's Avatar
Thats what i thought, and just spent $125 for the "bare bone" kit + firewall mount... Then $30 on Pcv grade silicone hose ... Then another $20 on fittings that arent even as nice as the AN ones provided. So i saved a little money said and done, but really the kit is just worth the money.
Old 12-17-2014, 03:56 PM   #17
joefez55's Avatar
20145pointoh deleted your inbox it's full , I'm trying to message u
Sct X4 how to Data log - Bama tunes Jaylg86 2011-2014 V6 Mustang 2 07-03-2014 12:52 PM
Data Log procedure Konawin 2011-2014 Mustang GT 11 04-04-2014 05:49 PM
Data log Marc3.71994 AmericanMuscle 4 01-25-2014 02:30 PM
Data log trouble bama tune jaredGTneelley 2011-2014 Mustang GT 5 12-16-2013 08:53 AM
SCT Data log how-to now up! SpectorV General Mustang Discussion 2 12-31-2009 05:45 PM
11:15 PM
