UCA & Bracket Mount - Mustang Evolution
Old 12-09-2014, 07:39 PM   #1
JPrider's Avatar
UCA & Bracket Mount
Just installed bracket mount and adjustable UCA (Steeda) on a 2014 GT Premium track pack. Curious to know what pinion angle should I have when I have stock suspension. Also, how do you go about getting the pinion angle.
2014 Mustang GT Premium, Grabber Blue, GT Track Pkg, Navigation System w/rear sensor
JPrider is offline   Reply With Quote
Old 12-09-2014, 08:09 PM   #2
BigJay's Avatar
If you talk with Sam strano on pinion angle you would install it and mimic the same angle the stock unit came out. Drive the car if you have zero vibration you're good. Problem with a set number is you are going to get several different answers. Steeda will tell you 1.5-2 degrees negative. If you have to measure put an inclinometer on the rear driveshaft record the number. Put the inclinometer on the pinion dampner just behind the yoke take that number subtract from driveline angle should be around the 1.5-2. Negative. There is quite a bit of room for error on how people measure so Sam's way works well. If you had no issues before install that angle was okay. If you drive now with no issue it is okay.
BigJay is offline   Reply With Quote
Old 12-09-2014, 08:11 PM   #3
BigJay's Avatar
Mark my words you will get a different response on this and that is why after all my research I trust Sam he has never steered me wrong yet.
Old 12-09-2014, 08:14 PM   #4
WhiteCali5oh's Avatar
Region: West Virgina
Bmr said the same. Although ford set it to 4-
WhiteCali5oh is offline   Reply With Quote
Old 12-09-2014, 08:24 PM   #5
Laquisha's Avatar
-2 is mine.
Naturally Aspirated Is Lyfe
Old 12-09-2014, 08:25 PM   #6
Also I think auto cars should be different than manual. Don't hold
Me to it though.
Old 12-10-2014, 06:12 AM   #7
JPrider's Avatar
Thanks...that's exactly what I did, I just adjusted it to the same length as the stock UCA. So far I have zero vibration, however I hear some clunking going on when hitting bumps on the road. It's not load but I can notice it, therefore I thought maybe I had the wrong angle.
Old 12-10-2014, 07:47 AM   #8
c_rizzle's Avatar
Clunking is due to harder materials. Its the trade off.... soft materials are quiet but flex more and give "softer" performance.
Basically, almost everything people do to the cars... suspension wise are about making things stiffer... shorter/stiffer springs, stiffer struts/shocks, stiffer LCAs & UCA, stiffer sway bars, stiffer engine mounts, etc, etc..
Too stiff can be worse in SOME situations (like sway bars) as it will actually cause you to lose grip, but the thing I like about stiffer parts... they're a lot more predictable when pushed hard.
c_rizzle is offline   Reply With Quote
Old 12-10-2014, 08:59 AM   #9
JPrider's Avatar
That's what I figured...not to annoying but I just know it's there.
Old 12-10-2014, 09:48 AM   #10
BigJay's Avatar
Re check your work and blue Loctite the adjustment joint if you don't they can come undone pretty easily can't they will clunk when you go over bumps in the road
UCA & Bracket Install JPrider Mustang DIY and Technical 1 12-19-2014 05:43 AM
Lca & uca & relocation bracket Laquisha 2011-2014 Mustang GT 43 11-15-2014 12:02 AM
WTB: BMR UCA & mount for 2011+ GT HPFury Mustang Parts for Sale and Wanted 0 02-12-2014 08:27 PM
UCA and mount for lowered car JayblesStang 2011-2014 Mustang GT 28 10-02-2013 03:18 PM
Metco motorsports rear uca and mount Eric e AmericanMuscle 1 06-24-2013 10:14 AM
02:34 PM
