Hawk HPS rear brake pad fitment - Mustang Evolution
Old 12-10-2014, 08:35 PM   #1
Redonblackpony's Avatar
I recently purchased Stop tech slotted brake rotors on all four corners and hawk HPS brake pads for my 2012 Mustang GT with Brembos. The stock brake pads were a lot thinner than the new performance pads. I started install on the rear and got the passenger side fairly easy. I moved to the other side at the rear and could not get the caliper to fit after the brake pad install. I pushed the piston in with the clamp as far as it would possibly go and still it wouldn't fit. Has anyone else experienced this problem? Is there something simple that I have overlooked?
Redonblackpony is offline   Reply With Quote
Old 12-10-2014, 08:44 PM   #2
I don't know about your cars brakes. But most rear brakes nowadays the piston has to be pushed in and turned. I had the same exact issue with my cars rear brakes. There are kits out there that you can buy that will do it.
I used a c clamp and vice grips to turn it.
Old 12-10-2014, 08:58 PM   #3
I rented a piston compression tool from O'Reilly. The piston is pushed in as far as it will go, I even used a cheater bar.
I've been reading stuff on Google about the hawk HPS pads being too thick.
Old 12-10-2014, 09:07 PM   #4
I run HPS pads on my car and they worked fine when I did the compression and the turning. But different cars so I can't say for sure on yours.
Old 12-13-2014, 03:47 PM   #5
Mission accomplished! Belt sanded each rear pad for 5 to 10 seconds. That was too easy! Followed break-in instructions and now ready for use.
Hawk HPS pads and Duralast Gold Rotors Question ski_snowman 2005-2010 V6 Mustang 0 10-31-2014 07:47 AM
Hawk HPS brake pads GrabberBlue1993 2011-2014 V6 Mustang 30 10-03-2014 01:24 AM
Hawk Pads - Ceramic or HPS for Mostly DD kramer 2011-2014 Mustang GT 23 05-09-2013 06:29 AM
Rear Brake Pad Install Write-up 1slosix Pre-2005 V6 Mustang 5 03-18-2013 12:11 PM
1994-1998 V6 and GT Mustangs Hawk HPS front brake pads 67mustang97 Mustang Parts for Sale and Wanted 0 03-16-2010 06:55 PM
09:24 PM
