Niche Targas shaking - Mustang Evolution
Old 12-20-2014, 09:13 PM   #1
BlackFiveOh's Avatar
Just got the black niche targa 20" staggered on my car. They look absolutely awesome. However, once I hit 40 mph, my steering wheels starts shaking terribly. The tire shop supposedly mounted and balanced, but something is obviously not right. What do you guys think it is? And also I got Sumitomo 285/30/20 and 255/35/20. Will I need to go get my gauges recalibrate? Thanks guys!
BlackFiveOh is offline   Reply With Quote
Old 12-20-2014, 09:22 PM   #2
Shifty 5.0's Avatar
Iv worked in tire shops for 4+ years it's a balance issue lol it's a pain in the *** to balance low profile tires and 20 inch wheels. Should have them road force the tire (if possible) while on balancer
Shifty 5.0 is offline   Reply With Quote
Old 12-20-2014, 10:02 PM   #3
WhiteCali5oh's Avatar
Region: West Virgina
Be sure to take the retaining clips off the car when u change the wheels out. They'll be one on each hub.
WhiteCali5oh is offline   Reply With Quote
Old 12-20-2014, 11:48 PM   #4
I had two bad tires that caused the same thing. They were brand new too.
Mikeyt03 is offline   Reply With Quote
Old 12-21-2014, 05:46 AM   #5
Noodles76's Avatar
Mine had to be rebalanced 3 times before they were acceptable.
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 12-21-2014, 06:44 AM   #6
Old 12-21-2014, 07:02 AM   #7
audioAl's Avatar
I just got 2 front 255/40/18's and at 65 I get steering wheel shake, so I know what your going through. I need to find time to have mine re balanced too.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 12-21-2014, 09:40 AM   #8
JimC's Avatar
Before you do anything else check this. The retaining clips are just used for assembly to hold the rotors on and the stock wheels have a recess to clear them Aftermarket wheels don't have one usually and that small clip is enough to cause the shake.
I put my drag wheels on and the first pass had the shakes - then remembered that I hadn't removed the clips. So jacked the car up, pulled those off and put the drag wheels back on. No more shaking.
JimC is offline   Reply With Quote
Old 12-21-2014, 10:29 AM   #9
Me too^ I took the clips off and have no shake at all now
Old 12-21-2014, 10:45 AM   #10
paulflor98's Avatar
I had the same issue. Had to have them balanced twice before it was fixed. First time balanced i took their word, second time i watched from start to end the entire process. Funny how it was fixed second time. Sometimes you got to INSPECT what you EXPECT.
paulflor98 is offline   Reply With Quote
Old 12-21-2014, 01:05 PM   #11
Old 12-21-2014, 06:16 PM   #12
Funny...I use that term about 10 times a day at work.
Old 12-21-2014, 09:31 PM   #13
Mlp07's Avatar
I've had my rims rebalanced 3 times at the dealership, and my steering wheel still shakes a little in around 40-60 mph. I removed the retaining clips today and I can still notice the steering wheel shake.
Mlp07 is offline   Reply With Quote
Old 12-21-2014, 10:21 PM   #14
U may have imperfections in either
Your wheel or tire then. Meaning they're not perfectly round or something. Mine are the same way. I've never had aftermarket wheels that didn't shake some
Old 12-21-2014, 11:05 PM   #15
paulflor98's Avatar
Same here!
Old 12-22-2014, 07:58 AM   #16
c_rizzle's Avatar
Yep... I bet so many people do this... take it to a shop... shop says.. oh yeah we rebalanced them... charged them for the balance and all they did was pull the clips off for the person!
c_rizzle is offline   Reply With Quote
Old 12-22-2014, 02:56 PM   #17
It's super easy too.
Old 12-22-2014, 10:14 PM   #18
mike s's Avatar
All of my shake was also from the clips...I was so excited to put my new wheels on I didn't even think about taking them off. Needless to say the first drive sucked it shook horribly. Pulled the wheels back off removed the clips and solved the problem
mike s is offline   Reply With Quote
Old 12-22-2014, 10:52 PM   #19
Mlp07's Avatar
I wonder if I need a alignment for that. My car got its lower control arms changed with a heat shield, since it's suspension work maybe it needs it. My car goes straight, it just shakes a little.
Old 12-24-2014, 04:17 AM   #20
Could be the difference between the wheel being hub centric and lug centric. OEM wheels align to the hub and are machined to fit perfectly centering themselves every time (hub centric). Aftermarket wheels many times are not machined to match the hub, and instead rely on the conical shape of the lug nuts "center" the wheel.
If not torqued in proper sequence, this can result in the wheel being off center from the hub, which will cause the wheel to shake. A solution on other applications is hub centric rings, which will allow the aftermarket wheel to align on the hub. Or just remove the wheel and re-torque the lugs in sequence and cross your fingers.
BadCon is offline   Reply With Quote
Old 12-24-2014, 02:40 PM   #21
JimC's Avatar
All good suggestions, but the OP hasn't come back to say if he used any of them?
I would do the simple one first. If the clips haven't been removed from the rotors then do it and check to see if that fixed it. If you don't do that first then you may be tossing away money chasing things. 99% of the time this simple thing is the problem
Old 12-24-2014, 03:26 PM   #22
grabber12's Avatar
Such a small item can cause a huge pain in the a$$. Good info here. I would have never thoght about the clip causing an issue. Good to know!
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 12-25-2014, 08:45 AM   #23
Eric5oh's Avatar
Got my new wheels and tires yesterday...made sure to tell the tech about this and my car has never ridden smoother. Good thing i read this thread lol
2013 Sterling Grey GT/Brembo package/upper and lower Billet grill/SR Performance lowering springs/J&M adjustable panhard bar/Roush axel back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 12-25-2014, 09:58 AM   #24
Rosco3's Avatar
Sucks about the problems your having, but let see a pick of those bad boys when you get the chance. I really like those wheels.
Ingot Silver Metallic 2013 Mustang 5.0 Premium, Flowmaster Outlaw Exhaust, Airaid CAI, JLT Oil Separator, MMD Black Zeven Wheels
Rosco3 is offline   Reply With Quote
Old 12-27-2014, 01:31 PM   #25
Sean313's Avatar
You need to get hub rings
Sean313 is offline   Reply With Quote
Old 12-28-2014, 09:48 AM   #26
Intense.'s Avatar
That was my first thought, rotor retaining clips.
'14 Race Red GT M6, premium, comfort package, Steeda stb
Intense. is offline   Reply With Quote
Old 12-30-2014, 06:29 AM   #27
2014GTCS's Avatar
After reading this thread I popped off my RTR's and found that I still had my retaining clips. Never had any issues with them on, but I took them off anyway.
Appreciated the info on this forum.
Hope you all have a great 2015!
2014 GT/CS / B4 Blue / Auto / Eibach Prokit / Whiteline Panhard and LCA's / RTR wheels / 275 Sumo's / Mike Rousch Tune / GT500 Axle Backs for a little growl
2014GTCS is offline   Reply With Quote
Old 01-23-2015, 07:11 PM   #28
So after two visits to the tire shop to get my wheels balanced, they still shake. The shop said I needed to order hub centrics for my wheels? Said after market wheels only fit the hub correctly 1/4 of the time. I've never heard of this before. Do you all know anything about this?
Old 01-23-2015, 08:14 PM   #29
Sean313's Avatar
Like i said you need hub centric rings with most after market wheels to stop it from shaking
Old 01-23-2015, 09:12 PM   #30
The only after market wheels that have shakes for me were the AMR's.
Old 01-23-2015, 09:50 PM   #31
Mlp07's Avatar
Same here. Actually I had my wheels rebalanced 3 times and there's still shaking on my steering wheel. I'm going to buy the hub centric rings and see if that fixes it.
Old 01-24-2015, 07:14 PM   #32
JimC's Avatar
Did you check for the clips and make sure that they were removed? That was all it took for my Race Stars to quit shaking.
Old 01-25-2015, 07:44 AM   #33
Rosco3's Avatar
Any pictures of the wheels yet?
Old 01-29-2015, 04:41 PM   #34
Name:	ImageUploadedByMustang Evolution1422574793.309642.jpg
ID:	174484Click image for larger version
Name:	ImageUploadedByMustang Evolution1422574855.133718.jpg
Old 01-30-2015, 06:09 AM   #35
Rosco3's Avatar
Attachment 174484Attachment 174485
Looks good. I've been wondering how they would look on my silver 2013.
Niche brand wheels - thoughts? Charlotte Stang Mustang Wheels & Tires 24 01-07-2015 12:26 AM
Niche apex wheels installed Noodles76 2011-2014 Mustang GT 2 09-08-2014 02:36 PM
Niche Verona 10.5 on 2013? Rickster_1823 2011-2014 Mustang GT 40 09-07-2014 07:13 PM
New Niche Verona wheels Ishoot Mustang Wheels & Tires 43 08-24-2014 02:56 PM
04:07 PM
