Where can I get 12v swited on a 2011!?!? - Mustang Evolution
Old 12-25-2014, 10:24 PM   #1
94gtconvert's Avatar
Hey guys, I'm at a stand still here with my 2011 gt. For the life of me, I cannot find a 12v ignition switched power source anywhere. I installed the plx dm100 multi obd2 gauge, and it needs 12v switched. I grabbed the good ol multi meter. And i removed the center console, gauge cluster trim, radio, fuse panel in the passenger kick well, and looked for the "automatic tranny harness the 6 speed manuals are supposed to have just lying under the shift boot" which my car doesn't have.. I also tried the convertible harness sitting in the center console and it gets 12v but none of them are switched. So where? And very specifically where can I find such a wire or fuse to tap into? Thanks for helping!
94gtconvert is offline   Reply With Quote
Old 12-26-2014, 12:53 AM   #2
Ammermeow's Avatar
Radio and Cig Lighter should have had 12v. I would check that you have 12v at the battery or test again with the car running. I am thinking that the Battery may not be fully charged which is why you are not getting 12v. If not you may need to wire into the fuse box in the engine compartment.
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 12-26-2014, 06:32 AM   #3
F28 in the smart junction box should be hot only when ignition is switched on, if that is what you are lookin for
NoTop5.0 is offline   Reply With Quote
Old 12-26-2014, 08:24 AM   #4
RacerX's Avatar
Big blue wire to the mirror connector
2013 Mustang GT Premium 5.0 Sterling Grey 6MT 3.31
35% Tint, MGW Shifter, JHR Hectic Motorsports High Flow Clutch Line, Borla S-Type Cat-back, Airaid Race CAI, Bama 93H Tune, Roush Chin Splitter, GT500 Style Spoiler, GT500 Pedal Assy, Ford Racing M-FR3A-MGTAA, High Performance Key Fob Battery.
RacerX is offline   Reply With Quote
Old 12-26-2014, 10:22 AM   #5
I'm getting 12 volts in all those places, but all those places get 12 volts even when the car is off and the key out. I need switched 12v Which means when they key is on the gauge will be on, when the key is off the gauge will turn off
---------- Post added at 12:22 PM ---------- Previous post was at 12:21 PM ----------
That's exactly what I'm looking for. Thanks! I'll let u know if it works
---------- Post added at 12:22 PM ---------- Previous post was at 12:22 PM ----------
Old 12-26-2014, 10:24 AM   #6
Hmmm, that would work... But I don't want to go though the hassle of running a wire that far. It will be a last resort.
Old 12-26-2014, 01:05 PM   #7
Compstall's Avatar
Cig lighter socket is always hot, key on or off.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 12-26-2014, 02:06 PM   #8
Region: Oregon
On the link where the service manual is located, you can also find the schematics. Here's the instrument cluster
Ford Service Manuals - Wiring Diagrams
That one shows Fuse F36 is switched.
Clicking on the Audio System - that Schematic shows F28 is hot on start (but doesn't mention hot in run). So if that suggestion above didn't work for you, maybe try F38 instead.
Note that the schematic also shows the wires/color code so you can splice directly into the wire, instead of the fuse box, if you want to do that.
skramblr is offline   Reply With Quote
12v led light hook up 99 gt 99redgt 1996-2004 Mustang GT 16 02-01-2012 07:15 PM
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 09:22 AM
96 Cobra 12v power source Brad.krieg SVT Mustang 12 11-02-2011 01:38 PM
12v power always on in shaker 500 sync? Blue Spirit General Mustang Discussion 2 04-19-2011 11:30 PM
Hid 5000k 12v 55w vs 35w 12v 5000k? eljin General Mustang Discussion 1 08-24-2009 05:29 PM
07:15 AM
