SR Performance short shifter - Mustang Evolution
Old 12-27-2014, 10:52 AM   #1
So I am wanting to upgrade my stock shifter and I am on a limited budget. I know everybody talks about the Barton and MGW but I dont want to spend that much so.....I am wondering if anybody has used the SR performance shifter and their thoughts.
Thanks
speedbyu is offline   Reply With Quote
Old 12-27-2014, 11:38 AM   #2
scott_0's Avatar
I've seen plenty complaints about them, get what you pay for applies here for sure, especially with a transmission as finicky as the mt82 **** box......
Old 12-27-2014, 11:42 AM   #3
What kind of complaints? Heard a video of the Barton and it sound like a shifter in a grain truck....clunk clunk
Old 12-27-2014, 11:49 AM   #4
pss3286's Avatar
If your on a tight budget start with a shifter bracket. I installed the energy suspension shifter bushing and I'm happy with my decision so far. Good luck.
Sent from my iPhone using Mustang Evolutionm
pss3286 is offline   Reply With Quote
Old 12-27-2014, 11:55 AM   #5
Yeah looked into that option too. Read the posts on AM and just wanted some real feedback on the shifter. I would like to hear specifics though so I can know if its something I can live with or not.
Old 12-27-2014, 12:18 PM   #6
Rapinator126's Avatar
The mt82 is not necessarily ****ty. Just needs some work done to it.
Mine is still good
Old 12-27-2014, 12:51 PM   #7
natestang07's Avatar
Seems like most trouble people encounter id within the bracket itself
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 12-27-2014, 01:34 PM   #8
BigJay's Avatar
I agree with upgrading your shifter bushing first. Otherwise save you money and get the mgw race spec. Best complete solution on the market.
BigJay is offline   Reply With Quote
Old 12-27-2014, 02:34 PM   #9
ok so any thoughts on steeda or hurst? I figured the bracket was a must do no matter what shifter you go with
Old 12-27-2014, 02:48 PM   #10
Barton 2 post bracket
Old 12-27-2014, 03:32 PM   #11
Found one on ebay, Core short throw shifter using Hurst stuff. Any thoughts?
Old 12-27-2014, 06:47 PM   #12
ncfive0's Avatar
Go barton or mgw, you definitely get what you pay for as far as these shifters go. I love my barton, solid and you will not miss a gear.
ncfive0 is offline   Reply With Quote
Old 12-27-2014, 06:52 PM   #13
ncfive0's Avatar
Rap, do you think there's a substantial difference between the 2 post bracket and the regular one that comes with the shifter?
Old 12-27-2014, 06:59 PM   #14
Hard to say, if you already have the normal barton bracket, it's not worth the $100. If you do not I would take the 2 post over the normal one
Old 12-27-2014, 07:10 PM   #15
ncfive0's Avatar
Gotcha. I also just watched the video about the solid MGW bushings and that seems like a good bang for the buck and could definitely, along with a aftermarket bracket, stiffen up the shifter for little investment.
Old 12-27-2014, 07:11 PM   #16
It does, I installed mine the other day. Was not expecting much, but honestly was blown away, feels just like a t 56 now
Old 12-27-2014, 07:13 PM   #17
ncfive0's Avatar
Do you have to pull the shifter and bracket off to install them?
Old 12-27-2014, 07:14 PM   #18
No just drop the transmission cross brace. And lower the trans on its own weight
Old 12-27-2014, 07:19 PM   #19
ncfive0's Avatar
Thanks buddy. Didn't mean to hijack this thread, just trying to shed some light on the fact that the mt82 is not that bad. It's just the remote mounted shifter that sucks.
Old 12-27-2014, 07:29 PM   #20
BigJay's Avatar
The two post design is going to be more rigid as there is no bushing at the bottom half. Will it make a big difference? I think it will, as you will still get a fair amount of deflection using the stock front shifter mount, the stiffer the better in this case. I think it's fair to say the more solid the m82 shifter mounting gets the better it performs as evidenced with the new mgw race spec,blowfish bracket etc.
It would be interesting to see if eliminating the stock articulating shift linkage with a solid bar mount would make a big difference with a rear bracket change.
Old 12-27-2014, 07:43 PM   #21
ncfive0's Avatar
That's essentially what the race spec shifter does.
Old 12-27-2014, 08:01 PM   #22
BigJay's Avatar
I put the race spec on my car and really like it but, really can't compare to other options. When I pulled the stock shifter and compared the two it was a shocking the design difference. I'm still at a loss trying to figure out why the articulating shift linkage? Why the floppy mounting?
Old 12-27-2014, 09:54 PM   #23
ncfive0's Avatar
I understand what you mean. I think they should've just figured out a bell housing or mounting design that would put the tranny back far enough for the transmission to not be remotely shifted.
Old 12-27-2014, 11:20 PM   #24
bazinga11's Avatar
OP: as others have pointed out, go with a two post bracket if you're not ready to drop 500 odd bucks on a MGW. You will be more than just happy. Just stay clear of SR shifter, been there done that. Not worth the money for what you get.
Sent from my SGH-I337M using Mustang Evolution mobile app
Old 12-28-2014, 09:09 AM   #25
Thanks guys I will look into the bracket now and save for a shifter. I appreciate all the feedback.
Old 12-28-2014, 07:54 PM   #26
ddtmoto's Avatar
Region: Utah
I first changed out my shifter bracket bushing for the Energy Suspension bushing, 17 bucks, a tremendous difference over the oem piece of sponge. Then just had to upgrade to the Barton 2 post bracket for some reason. A little bit firmer than the ES insert/bushing, but not a huge difference. I could have saved a hundred bucks. I really like my Hurst billet shifter, I got the classic look that I was after and an improved feel, it comes with what looks like an ES bushing in their kit.
ddtmoto is offline   Reply With Quote
Old 12-28-2014, 08:41 PM   #27
Thanks ddtnoto, I like the looks of the Hurst too. I have found these from Core Shifters but not sure of the quality. Thoughts? Whats the part number for the bushing?
Core short shifter w/ Hurst chrome stick & knob 2011-2013 Mustang 6 speed MT82
Core short shifter w/ Hurst stick for stock knob 2011-2014 Mustang 6 speed MT82
SR Performance short throw shifter install ab_mach1 1996-2004 Mustang GT 51 02-24-2016 10:30 AM
SR Performance Short Shifter Help Red Stallion 11 2011-2014 Mustang GT 36 07-05-2014 06:06 AM
Sr performance short throw shifter G3racing General Mustang Discussion 2 04-30-2014 05:51 AM
shifter knob and short throw shifter help blue-saleen Pre-2005 V6 Mustang 7 05-19-2009 07:52 PM
Hurst short throw shifter Blue232 Pre-2005 V6 Mustang 3 10-11-2003 11:07 PM
05:33 AM
