10 Camaro SS vs 13 GT - Mustang Evolution
Old 12-27-2014, 08:56 PM   #1
stangz13's Avatar
I enjoy reading the "vs" post so I decided to do one. Since it's several months before my local strip opens I just wanted to see how everyone thinks they compare on paper.
Buddy's car
2010 Camaro SS 6 spd.
Base model, clothes seats and well as plain as you can get.
Engine mods: cam (not sure the size, just know he regrets not going bigger now) K&N CAI system, and tune.
Exhaust: full length headers, x pipe, and manga flow mufflers
Suspension: stock
My car
2013 Mustang GT Premium auto
Fully loaded (shaker 1000 system, dual front power heated seats, navigation, glass roof, etc.)
Engine mods: Boss 302 intake, airaid CAI
Exhaust: roush axle back
Suspension: eibach pro system plus
Thoughts on the current setups? Advantage him, lighter car and more power? Neither of us have good tires for the strip right now. I'm hoping to get some type of street comps and do UCAS & LCAS, and panhard bar. He saids he's not changing anything else until he sees what his car will run. I've just recently got my car and don't know what it will run. His car where we live he ran this past summer. At the time his was stock and best run of 13.2X. Hope I'm not forgetting anything that will help or be the determining factor.
13 GT Fully loaded glass roof Airaid CAI, Boss 302 intake, Eibach Pro System Plus, Roush Axle Back Exhaust
stangz13 is offline   Reply With Quote
Old 12-27-2014, 09:01 PM   #2
IF he hooks up, he owns you.
Sent
txffmike is offline   Reply With Quote
Old 12-27-2014, 09:02 PM   #3
Your being an auto is more than likely a tremendous advantage though, assuming he isn't a talented driver.
Sent
Old 12-27-2014, 10:32 PM   #4
hctr154's Avatar
Are you tuned? If so, you might be surprised what a good tune can do for an A6.
2013 GT A6
hctr154 is offline   Reply With Quote
Old 12-27-2014, 10:36 PM   #5
The Mustang will get drug by the Camaro.
Boss manifold on an auto with stock converter will actually be a bit slower than stock manifold.
Old 12-28-2014, 12:21 AM   #6
Ish416's Avatar
My friends cam/full exhaust/CAI and tune 2010 puts down 500 whp and traps around 124 mph and ET's high 11's, on stock tires, with a bad driver (M6).
On the same dyno, a fully bolt on Boss was putting down low 430's.
Any LS engine that has an aftermarket cam, will likely pull on the majority of NA Ford engines.
If you're running at the strip, the Mustang has a chance but the Camaro will be the faster car by a good bit on the back half.
From a roll, that Camaro shouldn't have any issues putting bus lengths on that 5.0.
Old 12-28-2014, 07:44 AM   #7
zinc03svt's Avatar
A 150 shot on the stang would even out the odds for cheap...
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 12-28-2014, 10:31 AM   #8
rocknbronco's Avatar
I hate to say this but the Chevy I feel has the advantage here and will more than likely win unless the driver can't shift all. Off the line I feel the Mustang has the advantage you need better tires and power adder to win.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-28-2014, 10:33 AM   #9
Rapinator126's Avatar
You do not need a power adder to beat a cammed 5th gen.
Sorry
But you will need more than a cai, and boss
Old 12-28-2014, 01:20 PM   #10
504gt's Avatar
Get you some nice radials or slicks, if he spins he will have a hard time catching you
504gt is offline   Reply With Quote
Old 12-28-2014, 01:21 PM   #11
Does not matter.
The 2nd fastest bottom end 5th gen camaro is in Houston. Makes over 900 to the ground.
He runs 10.5's-10-8's.
Horrible they are bull****
Old 12-28-2014, 02:58 PM   #12
DWoody's Avatar
I'd recommend looking into an aftermarket converter.
DWoody is offline   Reply With Quote
Old 12-28-2014, 02:59 PM   #13
Don't matter. A 4.6 2v NPI will crush both of the cars.
Old 12-28-2014, 04:49 PM   #14
WhiteCali5oh's Avatar
Region: West Virgina
^ I love the sarcasm lol
WhiteCali5oh is offline   Reply With Quote
Old 12-28-2014, 07:22 PM   #15
zinc03svt's Avatar
Internet Hero's...luv em.
Old 12-28-2014, 09:09 PM   #16
stangz13's Avatar
Stock he never got under 2 second 60'. He's added more hp but still has done nothing for traction. So is his 60' going to improve or worsen?
Old 12-28-2014, 09:18 PM   #17
Probably worsen if he can't hook up com not positive though
Old 12-28-2014, 09:54 PM   #18
grabber12's Avatar
[QUOTE=Ish416;2147916]My friends cam/full exhaust/CAI and tune 2010 puts down 500 whp and traps around 124 mph and ET's high 11's, on stock tires, with a bad driver (M6).
Any LS engine that has an aftermarket cam, will likely pull on the majority of NA Ford engines.QUOTE]
Wait Wait so a 427hp stock camero (+ or - a few) with mods mentioned above gives the Chevy more then 100hp? To put down 500whp that would make him like 550-560 @ crank right? Doesnt the SLP supercharged camero put down the same numbers as your buddies "camed" camero?
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 12-28-2014, 11:14 PM   #19
DWoody's Avatar
Fast Automotive SLP Supercharger Install on 2013 …: http://youtu.be/xeZcS57y2_c
Old 12-28-2014, 11:25 PM   #20
Nobody can predict the outcome without knowing the size of of the cam. Camed is a generic term and without knowing the size it's impossible to say how much power. But likely if he put a fairly decent sized cam he will win assuming he can drive. And when you get into 400+ hp cars the driver mod can make night and day difference
StarzTA17 is offline   Reply With Quote
Old 12-28-2014, 11:35 PM   #21
[QUOTE=grabber12;2148212]
Look at it this way. An LS1 makes roughly 300whp stock. Add just a pretty aggressive cam and you can see 370 to the wheels easily. A cam only LS2 can see 400 to the wheels.
An LS7 makes 505 crank horsepower stock. New heads, cam, and intake manifold and people have seen 600whp.
N/A modular and N/A LS motor, mod for mod, dollar for dollar, the LS makes so much more power. This is why the Modulars need 2 things, rpms and boost. A lot of both. A bit factor is the lack of displacement. If you were to get a pushrod displacement out of a modular you will most likely see more power than the pushrod. But that would be one overly massive motor to do that.
Old 12-28-2014, 11:55 PM   #22
grabber12's Avatar
So what your saying is a cam and tune can't give a ls7 500whp.
Sent from my HTC6435LVW using Mustang Evolution mobile app
Old 12-29-2014, 12:06 AM   #23
Actually a cam only (implies a tune) LS7 can put down over 500whp. That's actually going to be through a very mild cam, an aggressive cam can do much more.
Old 12-29-2014, 12:14 AM   #24
grabber12's Avatar
I'm putting my Mustang up for sale tomorrow and buying a camero then. Stock they pull 360/375whp right? Cam tune exhaust adds 125+whp. I'm going to give my buddie a call and see what cams his SS has cause he puts down just shy of 500 and said he has cams, ported heads, intake, tune, long tubes, off road pipe, throttle body.
Old 12-29-2014, 12:16 AM   #25
This is why modulars need boost.
Old 12-29-2014, 06:25 AM   #26
Older ones do.
Old 12-29-2014, 09:54 AM   #27
olerodder's Avatar
Region: Oregon
I've been away from Chevy's for many years but doesn't the LS3 have about 426 "advertised" HP, which is probably a little shy, but I would say stock vs. stock, the Mustang and Camaro should be a pretty even match.
Although I haven't taken my Mustang to the strip, on the street it has no traction in 1st or 2nd and all I have is CAI and can'd tune, but I've got a 6spd.
The single most important piece for you is a converter, then the other stuff can follow. Take a look at the adders Grabber Blue5.0 has on his car and he runs 11.2's in the quarter with 1.5's in the 60'...................and he has a Boss302 intake and "Converter".
I would guarantee you'd leave the Camaro more than one car length behind......IMHO
Old 12-29-2014, 10:11 AM   #28
grabber12's Avatar
Yeah that converter seems to be the best mod you can do to make the auto a beast all around.
Old 12-29-2014, 10:21 AM   #29
Some of you really need to get out.
Old 12-29-2014, 10:24 AM   #30
olerodder's Avatar
Region: Oregon
Would really love to, but it's raining and 39 degrees outside. Not really Mustang weather!
Old 12-29-2014, 11:25 AM   #31
Ish416's Avatar
My friends car has either an LG G6X3 or X4. It's whichever you can go without fly-cutting the pistons. LG doesn't release cam specs but I want to say it's around a 235/240 - .650/.610 on a 111 or 112 LSA. It's not a fun car to drive as it has horrible cam surge under 1500 rpm. 6th gear is useless until after 85 mph.
Here is a thread with the same exact mods as his car, just different tuners - **495 RWHP 2010 Camaro Cam/Header/CAI only from LG Motorsports** - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
His car was tuned by Mike Norris in Indy. He is one of the best LS tuners in the country.
His 5th gen will pull hard on my 430 whp Z28 after 80 without spray. My Z28 generally puts car lengths on full bolt on coyotes. Given, his car is on the verge of being over cammed. His original goal was to build a 418 cui LS3, but life happened and he hasn't gotten around to that yet. He has ran a number of Camaro's with TVS2300's (the joy of living 40 minutes away from Lingenfelter) and generally runs door to door or ahead of them after a few runs. Same with a stock 2014 GT500, it's generally a close race (1 or 2 car lengths) until a few pulls and then the GT500 starts dropping back.
So yeah, it's likely putting down very similar whp numbers with less wtq than the SLP supercharged Camaro as it also uses a TVS2300. It's a fast car, it just can't get it's fat *** out of the hole very well.
Old 12-29-2014, 11:35 AM   #32
I'm sorry but you guys have some slow *** cars in your area or something is up.
Never had a 430hp fbody pull on me on motor. Never
Old 12-29-2014, 11:36 AM   #33
This is about to get good
Old 12-29-2014, 11:59 AM   #34
Not trying to start any ****. But the fbody has been on a pedistal for along time. And it was the fastest thing around 4 awhile.
Unfortunately alot of coyotes are running around on ****ty tunes from local shops etc. Who have no business tuning a fkn lawnmower
Old 12-29-2014, 12:16 PM   #35
You guys make me want a Camaro. Good thing they are ugly as ****.
I'm shocked tho, I've read a lot that mustang vs Camaro with bolt on, the stang comes ahead.
I know nothing about cams and etc. However my car with just tune and CAI is running down low 12s maxima with 12lbs of boost.
20145pointOH is offline   Reply With Quote
Mullet wearing Camaro drivers rule you !!!!!!!!!!!!!!!!!!!! Danger Dude Regional Mustang Discussion 32 07-12-2004 01:04 PM
Camaro Blasting / Civic Bashing / Accord Smoking Morpheus Pre-2005 V6 Mustang 33 01-03-2004 03:55 PM
radio clip of IROC Camaro idiot tire The Bar 8 08-12-2003 10:41 AM
My Stang Vs. Camaro v6 98 PuReHeLL Pre-2005 V6 Mustang 1 08-11-2003 10:09 AM
new camaro Rellik The Bar 50 08-05-2003 09:41 AM
10:50 PM
