front 19X10 wheels - Mustang Evolution
View Poll Results: Which set are you using or that you recommend to go with 285/35R19?
squared 19X10 3 75.00%
19X10 front & 19X11 rear 0 0%
Michelin Pilot Super Sport 2 50.00%
Bridgestone Potenza RE-11 1 25.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Old 01-03-2015, 09:52 PM   #1
M3hunter's Avatar
Question front 19X10 wheels
Hi Guys,
I have several questions:
Anyone with 19X10 runing squared or
19x10 front & 19x11 rears?
Mounted in 285/35R19 tires, please share driving experience with your setup. Do you have any fitting or rubbering issue?
Which tires do you prefer for Street and track?
Michelin Super Sport or Bridgestone Potenza RE-11
2011 GT Premium, Brembo, 3.73, KONI STRT, Steeda Sport springs, GT500 strut mounts, Strano's adjustable swaybars, 275/40R19 Michelin Pilot Super Sport, HAWK HPS, ATE DOT 4, CS style rear pedestal spoiler, AM Eleanor side scoops, "C style" side decals, Black BOSS style roof vinyl, black custom hood vinyl & Black pony.
M3hunter is offline   Reply With Quote
Old 01-03-2015, 10:32 PM   #2
BigJay's Avatar
19x10 +42 all around. Works well at the track no rubbing 285/35/19 PSS. Good set up for cars with Koni sport and mild lowering springs. Getting into wider options in the 300's for tire size would start to overpower my current suspension setup on the track. PSS is not the best choice for track but it has been the best compromise tire I have run with 30k mileage warranty.
BigJay is offline   Reply With Quote
Old 01-03-2015, 10:43 PM   #3
Before i vote. What will you be using the car for, and what is your driving style? There are pros and cons to each type of set up.
Old 01-03-2015, 11:58 PM   #4
dabishop25's Avatar
What is the widest you can go on these 14s without spacers? I would like to go staggered look on mine. I'm not racing just for looks.
The Michelin I hear get good ratings
2014 GT/CS Sterling Grey, Roush AB's, MMD Quarter Louvers, AM Chrome shift knob, LED's
dabishop25 is offline   Reply With Quote
Old 01-04-2015, 05:49 AM   #5
M3hunter's Avatar
Thumbs up
Thanks BigJay. Which is your brand of wheels?
Old 01-04-2015, 05:54 AM   #6
M3hunter's Avatar
Hi Soccerluvr4,
Spirited driving. DD and ocassional circuit track.
Old 01-04-2015, 05:58 AM   #7
M3hunter's Avatar
Thumbs up
Yes, My Michelin SS have great handling on road or track, even on wet, good wear, much better than the crap stock Pirellis.
Old 01-04-2015, 09:33 AM   #8
BigJay's Avatar
Forgestar
Old 01-04-2015, 09:38 AM   #9
BigJay's Avatar
11 inch wide rim with a 325 tire has been done. Offset needs to be spot on.
Old 01-04-2015, 12:33 PM   #10
jande063's Avatar
My street and road course tires are a set of the Bridgestone Potenza RE-11s in 285/35R-19 square. The RE-11 is a tire that just gets better and better with heat (I was able to keep up with a gentleman I race with in a new 911 GT3, granted it was a pretty technical course). The Michelin is a good street tire, but not useful for competition, the compound is too hard, the tread squirms too much, and the sidewalls are too soft. I have one winter (car is daily driven, year round), 18,000 miles, 45 autocross runs (I ran STU before moving to ESP and Hoosiers for this season), and two full track time trial events on a set of these. My only gripe is that capability at high temp means a low temp compromise. They do not try to kill you when it is cold, the way some other tires so, but they do not have quite the initial cold temp (ambient) grip that the Dunlop Direzza Z2 star specs or the BFGoodrich Rivals, these do need to be warmed up a bit (making the RE-11 a not so great autocross tire, but a lot of road racers love these in the rain, there is not much that is better).
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 01-04-2015, 01:52 PM   #11
Hi Soccerluvr4,
I'd say 19x10 square RE-11s
Old 01-04-2015, 02:28 PM   #12
BigJay's Avatar
Just out of curiosity have you run the pilots for track event etc.?
Old 01-04-2015, 03:47 PM   #13
jande063's Avatar
Yeah, I used them back to back with a set of RE-11s, then A6's on a 2012 WRX that several of us co-drove to see which tire we liked better. For street only use, the Michelin would be quieter (the RE-11 does growl a bit due to the nature of the tread), but from a performance standpoint, the PSS just has too much sidewall deformation and tread squirm. For a 300 treadwear tire, it has a remarkable amount of grip, but, it is still much lower than an actual performance tire. No one in the regions that I frequent runs this tire on a mustang with any regularity (hence the WRX, but another gentleman I race with who tried the PSS on his 911 had the same response though) the question now seems to be RE-11, Direzza Z2, or BFG Rivals.
Old 01-04-2015, 04:47 PM   #14
BigJay's Avatar
Wouldn't argue the other three are track stars over the pss. They do tend to be one sided with lower temps and rain in the equation. Pss has been good for my northwest winter track days and daily.
Old 01-04-2015, 05:49 PM   #15
M3hunter's Avatar
Thumbs up
Yes, I think they did very good, I was on the back of a BMW M3 (V8) at my local PCA track, he could not leave me behind, even that his car was modded, had paddle shift, better track tires & bigger brakes, plus an experienced pilot on that track, mine was my first time with the 5.0. But I don't know how the PSS will compare with the Bridgestone RE-11.
The only thing that was not able to survive, were my stock Brembo brakes.
Old 01-04-2015, 06:17 PM   #16
jande063's Avatar
Once you get some heat in the RE-11 (not hard to do in a heavy car such as a mustang, I have had no trouble getting heat in the tires in 35 degree weather, with that lovely southeastern Virginia humidity and constant 20 mph cross wind trying to suck the tires back to cold), they have more grip than the PSS, and are by far the best rain tire I have used (however, they are on the unfortunate side of useless in the slush and snow). One other advantage to the RE-11 is that it has the stiffest sidewall of any "street" tire, which allows the outside edges to hold up a bit better.
Old 01-04-2015, 09:19 PM   #17
dabishop25's Avatar
11? That is to big for me. Any input on what you think I should do? I have a Sterling Grey CS. I was looking at some Godspeed deep-dish wheel with a 5 in lip. I was thinking 20 rear and 19 front. Let me know please. I would want a super aggressive look with a wide rear tire...
Old 01-05-2015, 10:34 AM   #18
BigJay's Avatar
Good to know. I will likely give them a go next swap. How are they for treadlife?
Old 01-05-2015, 11:24 AM   #19
jande063's Avatar
I have 18,000 miles on them, 45 autocross runs, and two time trail weekends on them. Treadwear is still heaviest on the outside (only noticeable on the fronts, can be minimized by regular rotation to the rear), and the inside to outside difference is about 1/32". I have about 40% treadlife remaining.
Old 01-05-2015, 12:48 PM   #20
BigJay's Avatar
That sounds great thanks
18x9 Front 19x10 Rear? Zacona5 Mustang Wheels & Tires 5 07-22-2014 12:17 AM
Do 19x10 wheels fit over the Brembos? M3hunter Mustang Wheels & Tires 2 06-29-2013 03:56 PM
need help! best tire setup for 19x8.5/19x10 BigHead2010 Mustang Wheels & Tires 0 02-26-2013 08:36 AM
12:18 PM
