Water leak in car - Mustang Evolution
Old 01-04-2015, 01:19 PM   #1
Water leak in car
I would like to know if anyone else have a problem like this. I have a 14 GT. I just noticed last week water leaked into the interior of my car around the rear passenger floor. Only the carpet around the edges of the rear passenger seat was wet. I have no idea how it got in. I air dried and wet vaccummed most of it out, it felt dry and then yesterday we had a lot of rain. Today I went to check on it and the same area is wet again. Anyone know how water might have got into that back area?
The good thing is the car is still under full warranty and should be covered, but I need the car for this week and will not be able to bring it in till end of the week.
2014 Mustang GT, DIB, MT82, Tech and Track Package
mods are coming, slowly
kanine is offline   Reply With Quote
Old 01-04-2015, 07:27 PM   #2
20bmr14's Avatar
There is a body seam at the right rear fender well that will allow water in. I usually see the water pool at the bottom of the b pillar where the seat belt assembly is. I heard it sloshing around after a heavy rain. I would remove the plastic trim at the rr b pillar. If you pull back the trim panels and the bottom of the fender (between the door and rear quarter panel) is dry....then your search continues. If it is wet or standing water as I had shop vac it and dry it well. Then using silicone you will need to put a couple globs along side of the factory body sealer that you will see at the back and bottom of this inner fender pocket. Smooth it out generously over the body sealer and you will not see water again. Hope this helps.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 01-04-2015, 07:36 PM   #3
My 14 leaks inbetween the clutch and brake pedal. When im driving in the rain I have a constant drip on my shoe. Gonna try to bring it in this week to have it checked out. All drain holes are clear.
Bigshow14 is offline   Reply With Quote
Old 01-04-2015, 07:44 PM   #4
shunc01's Avatar
I have the same problem with mine too and I remembered with my old 05 the dealer said I have to check the plug that is located under the hood where the firewall is, there will be a grommet that you can take it out and get rid of the debris that is inside, it's part of the cowl hood if I'm right, so this is what I did with my 13 and it worked, it was clogged and sometimes the grommet closed up so I put another rubber in there to keep it open. Hope this help. And by the way there is another one in the driver side.
MPT TUNE, Borla S-Type, Airaid Cai, Ford racing X pipe, Mac ceramic shorty headers, 2010 GT500 rims, 35% tint, Sr Springs, J&M phb, camber bolts, blacked out side markers, front and taillights.
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 01-04-2015, 07:50 PM   #5
Thanks but my drains are all clear, its part of my underhood cleaning routine. Looked everywhere for the leak, my carpet is starting to get a dark spot on it. Nothing like the smell of of water in your not even a year old car.
Old 01-04-2015, 07:54 PM   #6
shunc01's Avatar
Okay thats weird, have you noticed under the grommet there is hole with no seal? I think that is culprit is, I sealed mine up, so far no problem cos water can go through there too. I don't why is there though and not sealed.
Mods:
Old 01-04-2015, 07:57 PM   #7
Im going to check that area again. Hope thats it, this is one of the main reasons I recently stopped modding the car. I wanna make sure this isnt a major issue.
Old 01-04-2015, 08:02 PM   #8
shunc01's Avatar
Ok good hopefully it will work out for you man, as for my experienced this is what I did, I plugged the whole under the grommet and put another rubber inside the grommet to keep it open at all times. Keep us posted.
Mods:
Old 01-04-2015, 08:04 PM   #9
Sure will thanks
Old 01-04-2015, 08:24 PM   #10
Thanks, I went to wet vac it out tonight after the rain stopped, it may be coming from the front, I'm not sure, but there is water all along the edge of the passenger side from under the dash and I guess it all settled in the back, my car is park in my driveway and it is slightly angled down. I guess all the water ran from the front down and settled in the back passenger side. The good thing is it is only around the edges of the carpet and not the whole interior carpet.
I will definitely check under the cowel and around the front of the car tomorrow to see if there is any clogs.
Old 01-06-2015, 02:25 PM   #11
I just had a leak fixed on my 14 V6, there was a lot of water trapped between body panels, like 20bmr14 said. I had mine fixed at the dealer before any water got inside because mine made sloshing noises with all the water stuck between the panels. From the area you're describing, it sounds like the exact same place. The wheel well wasn't sealed properly, so driving in wet conditions slung water up into the seam where it fell and settled behind the body panel.
Edit: Here is a link to a different forum post of the same problem, if you scroll down a bit he has pictures of where the water was trapped and you can actually see it pooled up in between the panels.
http://themustangsource.com/forums/f...-panel-526799/
rgstelzner is offline   Reply With Quote
Old 01-06-2015, 02:51 PM   #12
Thanks, I took the car to the dealer and they are looking at it. I can't say mine is for sure from the wheel well, the second time it happened the car was parked the whole time after 2 days of rain. I never heard any sloshing/water sound from my car while driving it before.
Old 01-06-2015, 07:50 PM   #13
20bmr14's Avatar
trust me if you have water pooling in the inner fender. remove the trim remove the seat belt assy. wet vac the water and dry it well with a towel. silicone the body sealer seam UNDER and along side of it and you're done.
Old 01-07-2015, 04:08 AM   #14
kingstrider's Avatar
When I took my quarter windows out there was a gap in the seal on the driver's side. The car is garaged but I wouldn't have been surprised if it leaked because of that.
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 04-14-2015, 08:28 PM   #15
fix ,reseal the the left hand break pedal assemble mounting bolt .mine was leaking around this bolt up under the dash .it is the left bolt facing the front of the car ,your can see the rust on it
wildwolf is offline   Reply With Quote
How do I get rid of hard water marks/sprinkler water marks? HooniganGT5.0 Mustang Paint, Appearance & Detailing 18 12-08-2014 07:37 PM
Water Leak Kick Panel Area ThatsCoolBro 2005-2010 V6 Mustang 1 04-06-2013 11:20 PM
Anyone have a water leak? Mandy4 2011-2014 Mustang GT 48 08-25-2012 03:44 PM
Water leak! Pete08GT 2005-2010 Mustang GT 19 04-16-2011 01:50 PM
12:05 PM
