Rear Passenger Knock - Mustang Evolution
Old 01-08-2015, 09:06 AM   #1
SoCal50's Avatar
Hi everyone. I'm experiencing a really bad knocking from the rear passenger side of my car (2014 GT Auto). I have recently lowered it (Steeda Ultrlites, Whiteline adjustable LCAs, Whiteline adjustable panhard, Whiteline relocation brackets) and have checked and re-checked all the jam nuts and torque on all bolts, sway bar is tight, axlebacks don’t make any noise when I bang on em. I'm just baffled at this point. Any ideas would be awesome, thanks.
SoCal50 is offline   Reply With Quote
Old 01-08-2015, 09:13 AM   #2
Eric5oh's Avatar
What kind of knocking because I'm experiencing sort of a squeaking/rattling sound coming from the same area when I get on the gas. Roush axel back and SR performance springs w/ j&m pan hard bar. Everything looks good to me as well
2013 Sterling Grey GT/Brembo package/upper and lower Billet grill/SR Performance lowering springs/J&M adjustable panhard bar/Roush axel back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 01-08-2015, 09:20 AM   #3
SoCal50's Avatar
I get a rattle too when I'm going down the freeway, but when I hit a bump or just go down an uneven road I get the knock, it sounds like something is loose, but I can't find anything that is.
Old 01-08-2015, 09:30 AM   #4
BigJay's Avatar
You didn't list that you check the upper shock mounts so I would start with checking to make sure you have all the bushings in place or maybe just not tight enough
BigJay is offline   Reply With Quote
Old 01-08-2015, 09:35 AM   #5
SoCal50's Avatar
I have checked them as well. Actually took them off last night and put them back on, no difference in sound.
Old 01-08-2015, 09:46 AM   #6
Eric5oh's Avatar
Could possibly be my problem. Haven't checked that. Is there a high probability that's what it is?
Old 01-08-2015, 11:29 AM   #7
SoCal50's Avatar
I doubt it, but it couldn't hurt to check and they are easy enough to get to.
Old 01-08-2015, 12:31 PM   #8
Ammermeow's Avatar
Check the pan hard bar support brace. Should be able to replicate noise by hitting it. The bushing on the new pan hard bar might be stiffer/bigger keeping the support brace from getting tight enough.
Sent from my SCH-I535 using Mustang Evolution mobile app
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 01-08-2015, 01:06 PM   #9
SoCal50's Avatar
I haven't checked that. Will for sure. Thanks
2014 Sterling Grey Metallic GT Premium/BOSS 302 Intake/BBK 85mm Throttle Body/Steeda 101mm CAI/Flowmaster American Thunder Axlebacks/BAMA 91R Tune/Steeda Strut Tower Brace/Steeda Ultralite Lowering Springs/Witeline Adjustable LCAs/Whiteline Adjustable Panhard/Whiteline Relocation Brackets/Niche Veronas
Old 01-08-2015, 01:17 PM   #10
sguevara's Avatar
Endlink. I went crazy trying to diagnose a similar issue. Jack the rear up and jam the endlink with your palm. Compare sides. You won't make as loud of a noise but if this is the problem you will hear the play in the bushing. But only on the bad side.
sguevara is offline   Reply With Quote
Old 01-08-2015, 02:30 PM   #11
SoCal50's Avatar
I smacked on the middle of the swaybar and didn't hear anything. I'll try hitting right on the endlink. Thanks for the reply!
Old 01-09-2015, 12:15 PM   #12
BigJay's Avatar
How did you adjust your rear pinion angle with the new control arm?
Old 01-18-2015, 12:26 AM   #13
Ammermeow's Avatar
Did you ever find the noise?
Old 01-18-2015, 01:13 AM   #14
WhiteCali5oh's Avatar
Region: West Virgina
Mine makes a knock sound like that. I'm also lowered and have all BMR stuff besides springs. It seems
To my like the sound comes from the area in between the passenger side rear wheel and the door. But I can't seem to find it. Also it does it only
Sometimes, and I noticed it if I'm parking and I slam the brakes only going
Forward. It won't do it in reverse for me.
WhiteCali5oh is offline   Reply With Quote
Old 01-18-2015, 09:07 AM   #15
Eric5oh's Avatar
Still have the noise and if anything it happens more frequently now
Old 01-18-2015, 03:58 PM   #16
RJTheIV's Avatar
Check the adj. panhard bar. I had a bad noise after an alignment because it wasn't tightened fully. I was able to replicate the noise by flexing the bar.
RJTheIV is offline   Reply With Quote
Old 01-18-2015, 08:25 PM   #17
Redonblackpony's Avatar
Do you have an adjustable upper control arm? My car was making the same rattling noise from that area and I found out that my UCA was backed out 5 to 6 turns, as it came loose during a track day.
I retightened it and reset the pinion angle. In addition, I re-greased all of my suspension parts. The problem was resolved.
Redonblackpony is offline   Reply With Quote
Old 01-18-2015, 09:24 PM   #18
Eric5oh's Avatar
No. This has been happening since I got the car and when I got it I was convinced my exhaust was rattling something because it would only happen when I would hit it. Now it happens if I moderately gas it
Old 01-18-2015, 09:35 PM   #19
Do you know if you have any poly bushings? They require grease periodically to keep them quiet.
Old 09-24-2015, 02:57 PM   #20
If this is the issue, what would be a fix? I ask because this might be my problem, I have the J&M Adjustable Panhard and I can replicate the clunk right where you suggested.
hwebb78 is offline   Reply With Quote
Old 09-24-2015, 03:15 PM   #21
I had the exact same knock, it ended up being the lower shock mount, just tightened it up and it went away
rwheels is offline   Reply With Quote
Old 10-03-2015, 12:48 AM   #22
Ammermeow's Avatar
Shim the brace with a thin washer.
Sent from my SM-N910V using Mustang Evolution mobile app
Old 10-04-2015, 01:16 AM   #23
Jicenroa's Avatar
Make sure relo brackets arent rubbing against the rear sway bar thats what happened to mine
Jicenroa is offline   Reply With Quote
Old 10-04-2015, 01:56 AM   #24
Billgluckman's Avatar
When does the noise happen? Over bumps? Cruising? Turning?
Billgluckman is offline   Reply With Quote
Found Source of rear end knock sguevara 2011-2014 V6 Mustang 2 11-11-2014 06:39 PM
Passenger side rear floor board soaked? hightower Pre-2005 V6 Mustang 15 01-11-2011 05:04 PM
Passenger side rear end squeak?? SuperDave2010 1996-2004 Mustang GT 4 03-09-2010 01:18 PM
Rear Passenger power window motor failure drnelsen 1996-2004 Mustang GT 5 06-26-2009 08:08 PM
Knock Knock *Language* Brent Pictures and Videos 3 04-03-2008 04:18 PM
04:43 AM
