Premium door panel swap - Mustang Evolution
Old 01-19-2015, 02:42 PM   #1
Noodles76's Avatar
Hey guys I was going to buy premium panels for my GT but wanted to know what would be required to get the extra subwoofers at the bottom to work. Is it just a harness or do I need to splice or get a premium stock radio.
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 01-19-2015, 06:22 PM   #2
You'll need a better amp. Not sure if the base amp will supply enough power to those speakers.
Mikeyt03 is offline   Reply With Quote
Old 01-20-2015, 04:37 AM   #3
Noodles76's Avatar
Do you think I would need the shaker radio, amplifier and harnesses as well. I'd like a stock ford setup and I don't want to lose my sync.
2014 5.OHHHHHH
Old 01-20-2015, 07:24 AM   #4
Compstall's Avatar
You will need at least an Apple IIE processor and Centurylink cable installed with at least 2 pay-per-view packages.
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 01-20-2015, 10:15 AM   #5
Noodles76's Avatar
You're so helpful....
2014 5.OHHHHHH
Old 01-20-2015, 10:29 AM   #6
That much less then what you'll need to fix your slow *** mustang.
Old 01-20-2015, 10:35 AM   #7
ninerone's Avatar
If you want it to sound the best, you're going to need some time and some power tools.
I took my doors off (the entire door, off the hinges), pulled the wiring harness, and drilled a hole into the corner of the harness. Then I fed a speaker wire from the interior through the wiring harnesses, down the flexible tube and into the door cavity. There's no wiring harness to be used if you are swapping up from the base door panels to premium. Link those wires up to the sub in the door and the output of your amp (you'll need to buy this, doesn't need to be ford or kicker or anything special). I don't know about the output of the stock deck but I'm assuming it has subwoofer outputs that aren't being used. Tap into those if you can find them (assuming they exist). If not, you can tap off the front or rear speakers (prefer rear) and just make sure you use a low pass filter on the line or use a crossover to cut the signal down below 100-120hz, or lower depending on the music you listen to.
I've got some pictures of my install on my imgur, ninerone.imgur.com
Sent from my Lumia 1020 using Tapatalk
2014 GT / Black / 6-speed manual
Airaid CAI / Roush Exhaust / Bama Tune /
Custom Vinyl / Shelby Spoiler
ninerone is offline   Reply With Quote
Old 01-20-2015, 02:09 PM   #8
Noodles76's Avatar
Thanks man I appreciate the info!
2014 5.OHHHHHH
Please help! need to remove instrument panel left side panel Peruano_loco 2011-2014 V6 Mustang 5 02-02-2014 08:24 AM
86 svo mustang header panel wanted header panel? wit 2.3 Mustang 1 08-21-2009 07:39 PM
2004 door panel speaker removal drwang Mustang Audio & Video 3 10-13-2005 07:43 PM
door panel insert idea Bane- Pictures and Videos 4 05-27-2005 12:19 PM
MWspeedshop door panel decals wiarumas Mustang Audio & Video 22 01-22-2004 01:07 AM
» Members Mustangs
Equinox
Steve96
150
dimo
Add your Mustang
04:51 AM
