Mysterious sound. I give up need help. - Mustang Evolution
Old 01-20-2015, 08:42 PM   #1
Ok so a while ago my car started to make this very low pitched cricket sound I guess coming from the rear of my car. If you can't hear well you may not hear it but I do hear it its very annoying. It is not present when the car is under say 30mph but after it is there. Doesn't seem to get any louder after 60mph. Just a consistent cricket type noise from the rear I have changed pads and rotors and that wasn't it.
I know when I'm driving and let off has its still there or when I drive and put in neutral while cruising and rev my car it's there so it's not engine or exhaust related. I need help I can't figure it out.
dude0715 is offline   Reply With Quote
Old 01-20-2015, 09:32 PM   #2
ArtU's Avatar
Have you checked to see if at your last service at the dealer they mistakenly added the Trunk Monkey Option to your car?
Seriously however I Had such a issue in my long past 2007 Pontiac G5, turns out it was an emissions canister making noise at times. It wont b that on your car but try to find out which side its coming from and see what parts could be the cause. High Speed read end gear noise is a howling sound, not cricket chirps so I don't think its that.
Old 01-20-2015, 09:35 PM   #3
It's possible. We're you in my trunk earlier?
Old 01-20-2015, 10:15 PM   #4
Ammermeow's Avatar
Do you have an axle back exhaust? If so check the metal hangers at the mufflers. I had two metal pieces that were rubbing together causing a cricket noise when I went over bumps.
Sent from my SCH-I535 using Mustang Evolution mobile app
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 01-21-2015, 06:13 AM   #5
Will do I'll check that
Old 01-21-2015, 07:35 AM   #6
chopper's Avatar
What he said, spray wd40 on the hangers.
chopper is offline   Reply With Quote
Old 01-21-2015, 07:52 AM   #7
Will do but why would it not be present till bout 40 mph? Kinda thinking axle bearings. What you think
---------- Post added at 01:52 PM ---------- Previous post was at 01:51 PM ----------
It's kinda like a whistle noise to can hear it really well next to a highways barrier
Old 01-21-2015, 07:55 AM   #8
chopper's Avatar
If it is the hangers it would be a chirping noise...
Old 01-21-2015, 07:58 AM   #9
I'll try it. I hope it's something easy but I wish I could figure it out
Old 01-21-2015, 08:10 AM   #10
Eric5oh's Avatar
I have the same exact problem and there was a tread less than a week ago about it. The sound is coming from the trunk and there's no debating that. And it happens whenever I'm on the gas a good bit as well as going over small bumps. I drive with one of my backseats down and know for a fact it's coming from the back passenger side of the car somewhere in the trunk. Still clueless to what it is
2013 Sterling Grey GT/Brembo package/upper and lower Billet grill/SR Performance lowering springs/J&M adjustable panhard bar/Roush axel back/AEM CAI
Eric5oh is offline   Reply With Quote
Old 01-21-2015, 08:39 AM   #11
KARgt13's Avatar
Use lube, not wd40. Wd40 dries out after a few days.
KARgt13 is offline   Reply With Quote
Old 01-21-2015, 08:41 AM   #12
chopper's Avatar
Yes your correct. ..
Old 01-21-2015, 08:49 AM   #13
Axle bearings tend to roar, not chirp and it would change with road speed. While you are under there, check shock and their mounts. Pay particular attention to the sway bar end links. They are notorious noise makers. Since the noise doesn't change with road speed indicates it isn't in the driveline.
Old 01-21-2015, 09:09 AM   #14
Strange Mud's Avatar
is it speed sensitive (ie faster chirps @ faster speeds)?
if so check runout to axle flanges....I had a bent axle.
Old 01-21-2015, 01:35 PM   #15
Ammermeow's Avatar
I used some rubber hose cut in half and zip tied it to the exhaust hangers. To rule out the exhaust hangers just grab one if the exhaust tips and shake up and down. If it is the hangers it will make the noise.
Old 01-21-2015, 01:40 PM   #16
chopper's Avatar
What, I thought you would put grease on the rubber hangers
Old 01-21-2015, 03:25 PM   #17
Ammermeow's Avatar
My problem was the metal that surrounds the rubber hanger was rubbing on the metal rod on the exhaust.
Old 01-21-2015, 09:04 PM   #18
I will get a video or recoding Tommorw.
Old 01-21-2015, 10:33 PM   #19
Psmith129's Avatar
Check your antennae as well , mine was loose and sounded exactly like a cricket when driving .Extremely annoying
Psmith129 is offline   Reply With Quote
Old 01-26-2015, 09:36 PM   #20
chopper's Avatar
What happened to the video, did you ever find the noise. ..
Old 01-26-2015, 09:40 PM   #21
http://youtu.be/hGLgVjmHEdw
Taking to Dallas mustang Monday I think it's the carrier or pinion bearing
Old 01-26-2015, 09:44 PM   #22
chopper's Avatar
That's not good. ..
Old 01-26-2015, 09:45 PM   #23
Holy ****, it sounds like the rear end is grinding itself to pieces. It really doesn't sound at all like your cricket sound description in your first post.
Old 01-26-2015, 09:48 PM   #24
Nope not good. I'm renting a car Tommorw until this is fixed car won't move till next Monday. It's weird if you close the seat you can bearly hear it at all so weird ...I'll keep you guys updated and respond to this Thread with pics of the damaged parts of what happend
Old 02-18-2015, 09:30 AM   #25
WR2
Any updates?
WR2 is offline   Reply With Quote
I would give up ????? before I give my stang up Smoke 2011-2014 Mustang GT 24 08-17-2012 07:24 PM
Mysterious ticking from engine Redlsea 1996-2004 Mustang GT 2 08-13-2011 05:39 AM
That's it! I ****in give up and just don't give a **** anymore SilentNoise The Bar 25 07-05-2009 05:02 PM
Mysterious Transformer Trailer Brent The Bar 16 07-08-2007 08:46 PM
GT gets owned by mysterious ice bomb MonteCitan Pictures and Videos 39 01-31-2007 07:05 PM
06:16 PM
