Suspension Specs questions - Mustang Evolution
Old 01-23-2015, 07:36 PM   #1
Coyote2820's Avatar
Hey guys, I know there are tons of suspension threads out there but I didn't see any that mentioned these questions I had. Keep in mind I am strictly a daily driver.
I'm looking at panhard bars but I'm not sure what material to go with. I see some that are steel and some that are aluminum? There are other material makes I think but which is better or is there any difference?
Should all ends be poly bushings or do you want to have some that aren't?
Also, which parts are necessary to be adjustable? Do they need to be single, double or triple adjustable?
There are just so many options and variables that come into play whenever changing out suspension and handling parts. I just need some direction and opinions on this subject. Thanks in advance guys!
2014 5.0 GT Premium - Active Duty
2013 5.0 GT - Retired
2003 GT - Retired
Coyote2820 is offline   Reply With Quote
Old 01-23-2015, 09:07 PM   #2
Personally I'd go with either ford racing or white line. I've only heard good things in regards to the product and the brand. Both are steel iirc. I'd go with steel personally. Although I don't think they are triple adjustable
Although I don't think I would want a double, triple, or quadruple adjustable if my stang was only ever gonna be a dd
Just_Greg is offline   Reply With Quote
Old 01-24-2015, 02:16 AM   #3
Oh2freshstang's Avatar
BMR!
For the Panhard bar on a DD u want a single adj. w/ poly bushing.
Old 01-24-2015, 03:50 AM   #4
Grabber Blue5.0's Avatar
BMR for sure.
Old 01-24-2015, 08:59 AM   #5
BigJay's Avatar
Anything steel adjustable with poly bushings.
BigJay is offline   Reply With Quote
Old 01-24-2015, 10:30 PM   #6
For my own Curiosity, would a completely non adjustable Panhard bar be an noticeable improvement over its GT counterpart???
Old 01-25-2015, 12:41 AM   #7
20bmr14's Avatar
Hotchkis is the one NOT to get-Go with BMR
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 01-25-2015, 05:11 AM   #8
Coyote2820's Avatar
I know we all have the particular brands we are all partial to and I appreciate the recommendations guys I do, thank you.
This threads purpose is more about determining what the best components and specs are of each individual part of the suspension and why that specific option is ideal.
2003 GT - Retired
Old 01-25-2015, 07:04 AM   #9
Region: Nevada
I have the Ford Racing chrome moly panhard bar, which is probably overkill for a daily driver.
2005-2014 MUSTANG ADJUSTABLE PANHARD BAR | Part Details for M-4264-A | Ford Racing Performance Parts
2014 SGM GT, 300A base coupe, 6R80, daily driver.
silverstate777 is offline   Reply With Quote
Old 01-25-2015, 09:13 AM   #10
BigJay's Avatar
No, you will find that your rear axle in your car is not centered and if you are adding a panhard then the adjustment will help you correct it even at stock height. Not a necessity but if your gonna do it....
Old 01-25-2015, 01:23 PM   #11
Ok thanks bud. Makes sense
Old 01-25-2015, 04:08 PM   #12
Coyote2820's Avatar
Haha that is high performance for sure, if I had unlimited funding then I know I could find some way to justify that purchase.
2003 GT - Retired
Old 01-28-2015, 07:51 PM   #13
20bmr14's Avatar
Hotchkis makes good parts but their panhard bar has to be taken apart on one end to adjust and to do that you have to take down the sway bar end link....what a pain in the arse and bad design.
Need 94-95 specs engine specs blaster_5.0 1979-1995 Mustang GT 0 10-28-2013 09:23 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Questions about Ford Engine Specs 2K05GT General Mustang Discussion 8 02-18-2008 09:50 AM
Vibration Dampener Torque Specs ridelikehell The Bar 2 02-17-2004 05:39 AM
2002 bumper and hood specs BIGMONKEYJ Mustang Audio & Video 6 01-04-2004 08:08 PM
03:51 AM
