Playing with vinyl - Mustang Evolution
Old 01-24-2015, 05:32 PM   #1
Playing with vinyl
I ordered some 3d carbon fiber vinyl black and red
So I went down to auto zone to buy a roll of vinyl to practice with. Not the best work lol. I went and bought a head gun today and it is a whole lot easier you just need to be patient.
Sent from my SM-N910T using Mustang Evolution mobile app
ID:	174152   Click image for larger version
jrdnsky59 is offline   Reply With Quote
Old 01-24-2015, 05:34 PM   #2
I was thinking of doing all the dash trim along with the radio bezel black. And the chrome rings and steering controls in the red cf vinyl. Any one have any ideas?
Old 01-24-2015, 05:53 PM   #3
Cooolbreeez's Avatar
I think the looks pretty good. One of the first things I noticed when I drove my mustang is the reflection of the chrome bezels and trim while driving. Never thought of wrapping them.
Cooolbreeez is offline   Reply With Quote
Old 01-24-2015, 06:56 PM   #4
It's a little tricky you need to work with it. I'm not too patient with this stuff. Once I get the vinyl I ordered I'll post pics. I just don't know how to combine the black and red cf.
Old 01-25-2015, 10:48 AM   #5
Deerslayer's Avatar
Take your time, use a Popsicle stick and a plastic card along with a blow dryer and you can do the entire dash. I did the base dash we took this car before installing the Boss dash. I sold it but it looked really good. If you decide to do the entire dash, there is a trick you need to do to the glove box panel for both safety and looks. The crease in the center is both function and design. It splits when the air bag deploys. If you just try to lay the CF vinyl in there with out making cuts, it will always bubble up and potentially could be an issue if the airbag deploys. Simply lay the vinyl and use the popsicle stick to press it in the two grooved areas. Right after getting in there good, take an xacto razor and cut each of the bottom corners lightly just through the vinyl. This will keep it laid flat in there plus it will separate if the air bag deploys. You cant see all of it in the pic, but I also cut out the vinyl where "MUSTANG" is in that area. Gives it a much more professional look.
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 01-25-2015, 11:14 AM   #6
That came out nice really nice.
Old 01-25-2015, 02:11 PM   #7
Deerslayer how did you get vinyl on the passenger airbag to fill the two slot so nicely?
Old 01-25-2015, 02:20 PM   #8
Deerslayer's Avatar
^^ I put how in my first post. You lay it, use a popsicle stick to get it into the first grove and then make two cuts with a straight edge razor in both sides of the bottom of the groove. Continue to lay it into the next groove and repeat the process. Use a hair dryer to keep the vinyl warm and laying good. Once you make those relief cuts it will stay put and is safer for the operation of the air bag. I removed the vinyl where the mustang letters are. Start by laying the vinyl over the piece and work from the bottom to the top working any air out. Once you get to the first groove, do use the blade to make the relief cuts, next work it into the top groove and make the next pair of cuts.
Old 01-25-2015, 03:55 PM   #9
Thanks I get the vinyl some time this week. I'll take pics of how it turns out. I'm thinking of doing the dash panels red carbon fiber and stereo piece black carbon fiber. And the chrome rings in red carbon fiber as well.
Old 01-31-2015, 02:22 PM   #10
I got the vinyl I ordered yesterday in the mail. I wrapped some trim pieces and they came out ****ty. The vinyl I ordered was cheap ebay vinyl (technology racing).today I ordered a roll of 3m 1080 cf vinyl. I will be redoing the pieces next week along with the rest of the trim. What do you guys think of the red cf rings and trim? does it go good together?
ID:	174619   Click image for larger version
Old 01-31-2015, 02:24 PM   #11
Deerslayer's Avatar
I think it looks pretty cool.
Get the good 3M cf vinyl for sure.
Old 01-31-2015, 03:19 PM   #12
The only thing is I don't think 3m makes a red cf.
Old 02-01-2015, 07:18 AM   #13
oxford5pointoh's Avatar
That looks pretty killer. Everyone's look pretty cool
Just enjoying my 420 HP daily driver
Old 02-11-2015, 06:38 PM   #14
Progress so far
Old 02-11-2015, 06:39 PM   #15
Old 02-11-2015, 07:15 PM   #16
Deerslayer's Avatar
VERY NICE!!
Old 02-12-2015, 04:13 AM   #17
That's a nice! Looks really good, like the red.
Old 02-12-2015, 09:01 AM   #18
Thank, I'm taking the red off since I won't be able to wrap the chrome around the vents in the middle. It looks a little difficult. And around the shifter as well.
Old 02-13-2015, 01:41 PM   #19
abram2001's Avatar
very nice all, looks great!
abram2001 is offline   Reply With Quote
Old 02-14-2015, 09:30 AM   #20
kona stang707's Avatar
The chrome on the middle vents can be removed also from what I remember u just push it out from the other side and use a flat head on the front to help get it off id have to look at it to remember for sure. It also looks like it can be around the shifter too but when I was trying to I couldn't get it off around the shifter so I just taped it off when I sprayed it.
2011 Kona blue GT.
kona stang707 is offline   Reply With Quote
Old 02-14-2015, 05:32 PM   #21
Around the shifter and the middle vent it looks like the chrome rings are melted on.
Sent from my SM-T530NU using Mustang Evolution mobile app
Old 02-14-2015, 05:44 PM   #22
Deerslayer's Avatar
The trim ring on the console IS melted into place. I had to remove it to complete the install of the carbon fiber console. You can use a soldering iron to melt each tack and then it will pop off. Quite a bit of work tho
Old 02-14-2015, 06:00 PM   #23
Will try that out. Really wanted to do all the chrome rings red.
Old 02-16-2015, 01:16 PM   #24
Some updated pics. Finished my doors, and airbag panel.And radio bezel.
ID:	175531   Click image for larger version
Old 02-16-2015, 01:41 PM   #25
abram2001's Avatar
Very nice, seems like a lot of tedious work.
Old 02-16-2015, 01:48 PM   #26
It was, didn't come out perfect but it was worth it. Plus I have a lot of extra vinyl if I need to do re do a panel.
Old 02-16-2015, 02:35 PM   #27
Deerslayer's Avatar
Good work jrdnsky59. Looks good
been playing with photoshop STEVE The Bar 17 02-16-2015 01:43 PM
So.. me and my friends have been playing a lot of SWAT4 wiarumas The Bar 14 06-03-2005 08:08 PM
first time clips of me playing my 7string guitar sonic04edge The Bar 0 03-31-2005 03:40 PM
Israel isnt playing at all Brent The Bar 4 09-26-2004 11:04 AM
Can't stop playing with my truck!! n8r The Bar 3 09-09-2003 06:18 PM
09:55 PM
