Barton shifter and reverse. - Mustang Evolution
Old 01-25-2015, 05:54 AM   #1
hitmeagain's Avatar
I have been lusting over a barton for my 14gt and found a good deal in the shifter through a friend. I installed it yesterday and I'm completely happy with it except the little extra force it takes to go in to reverse. The car goes into reverse and the forward gears are all fine but it feels as if I have to push down hard to go into reverse and there is no positive feeling that I'm in reverse till I ease out on the clutchto see if it will roll back wards. I know that the install of the rubber boot is critical as so it will go into reverse. Is it normal to feel like it does and I'll get use to it or do I need to take it apart for the third time to move the rubber boot around again?
hitmeagain is offline   Reply With Quote
Old 01-25-2015, 07:15 AM   #2
Konawin's Avatar
I just installed the Barton shifter, bracket, and white line bushing. Right after I had the install complete I went to drive it and realize that I had the boot twisted when I tighten down the knob which caused the shifter to not want to move properly in it's gate. I simply loosen the ball shifter, adjusted the boot. I held the top of the boot in place and retightened the shifter ball. Not sure that's your problem or not but that's the simplest and first thing that I would think of to look at.
Konawin is offline   Reply With Quote
Old 01-25-2015, 05:22 PM   #3
hitmeagain's Avatar
Thanks for the reply... I took it back apart again and removed the rubber boot completely... It fixed all my problems with reverse and I'm debating wether or not to even put it back. It's a little more noisy but let's you hear the nice whine of the trans and hardly any road noise. I still would like to know what I'm doing wrong with the boot.
Old 01-25-2015, 06:35 PM   #4
scott_0's Avatar
are you saying you may put the rubber boot back in? I don't recommend that man, that boot keeps out nastiness and water
Old 01-25-2015, 11:48 PM   #5
slayertodd's Avatar
Get the MGW shifter by far the best made it replaces the whole shifter trust me I have it.
Sent from SlayerTodd
slayertodd is offline   Reply With Quote
Hurst billet shifter plus two or Barton short throw shifter?? hdez41 2011-2014 Mustang GT 25 01-26-2015 09:01 PM
For Sale: FS: Barton Shifter, MBRP Axle backs, Shifter Bushing 1ststang Mustang Parts for Sale and Wanted 8 03-15-2014 06:21 PM
Barton shifter bracket with stock shifter 2011 2011 2011-2014 Mustang GT 5 03-11-2013 07:48 AM
Barton 2 Post Bracket vs Standard Barton Bracket SilverBullet12 2011-2014 Mustang GT 8 08-23-2012 09:43 AM
Barton shifter and bracket install - SUCCESS! mmike87 2011-2014 Mustang GT 12 07-26-2012 11:44 AM
01:06 AM
