Brake Squeak - Mustang Evolution
Old 01-29-2015, 10:53 AM   #1
v8erik's Avatar
Brake Squeak
I have a brake squeak everytime i press ! When i drive and when in stopped ! Its coming from the right front brake ! Any guesses what it might be ?
2011 Mustang GTCS
BBK CAI
Lethal Performance Off-Road X-Pipe (kept my cats on)
DMH Performance Electric Cutouts
Flowmaster AxleBacks
v8erik is offline   Reply With Quote
Old 01-29-2015, 02:25 PM   #2
KARgt13's Avatar
2011 Mustang GTCS
BBK CAI
Your rotors are probably glazed. I have the same issue but I haven't gotten to taking the rotors off and getting them turned. Changing the brakes alone won't help. Granted, that's if what I said is the issue.
KARgt13 is offline   Reply With Quote
Old 01-29-2015, 03:07 PM   #3
v8erik's Avatar
Its not when im braking it just squeaks when i press on the brake like when im stopped
2011 Mustang GTCS
BBK CAI
Old 01-29-2015, 08:31 PM   #4
DWoody's Avatar
Let me get this straight. Your brakes squeak only when you're sitting still? And they don't squeak at all whatsoever when you're actually braking?
DWoody is offline   Reply With Quote
Old 01-29-2015, 10:05 PM   #5
v8erik's Avatar
They do a little only when im going to slow down when im in low speed
2011 Mustang GTCS
BBK CAI
Old 01-30-2015, 06:38 AM   #6
Voltwings's Avatar
Its the pad moving around inside the caliper. Get some Brake grease and just apply some everywhere the outside pad (usually the pad against the pistons is not the problem) touches the caliper on the back and sides. Put the car back together, and firmly press the brake pedal a few times, as the "grease" will actually act like glue after a while and keep the pads still.
That being said, depending on their life, it may just be time to replace them anyways.
Old 01-30-2015, 01:15 PM   #7
v8erik's Avatar
You think this is the reason i have the Service Trac light On ?
2011 Mustang GTCS
BBK CAI
Old 01-31-2015, 06:21 AM   #8
Mhsupreme's Avatar
You probably need brakes. We have a metal tab that catches the rotor when pads are low and causes a squeak. If pads have been done recently use gold copper paste on the ears of the pads (ONLY FOR BREMBOS). If you have standard calipers there's a different paste for them.
Mhsupreme is offline   Reply With Quote
Old 02-02-2015, 11:12 AM   #9
rocknbronco's Avatar
Replace the brake pads and inspect the calipers and rotors.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Brake/Rear end squeak?!?!?! 08mustanggt 2005-2010 Mustang GT 14 08-11-2015 11:24 PM
Brake squeak 98vertgt 1996-2004 Mustang GT 9 04-16-2013 04:36 PM
HELP- Continuous Brake Issue/Squeak on 2010GT sherv33 2011-2014 Mustang GT 10 10-12-2012 08:30 PM
body kit squeak Warfire80 Mustang Audio & Video 9 11-15-2005 11:20 PM
Rear Squeak....Please Help!!! drzeusd Pre-2005 V6 Mustang 3 10-20-2003 02:44 AM
07:04 AM
