Cobra Jet Manifold Install. - Mustang Evolution
Old 01-29-2015, 02:32 PM   #1
Capn__Morgan's Avatar
Hey guys. I'm interested in doing the CJ install on my 14 GT. I know you need the "Ford Racing Boss 302 Install Kit" But I remember seeing a thread a few months ago stating you could substitute that whole kit for a few parts since you don't use the inlet tube if you add the CAI and it isn't necessary to replace the fuel lines. Any help with this? As far as the actual install goes it seems pretty straightforward so I'm not too worried about that. Thanks in advance.
Capn__Morgan is offline   Reply With Quote
Old 01-29-2015, 02:52 PM   #2
Grabber Blue5.0's Avatar
No need for the Boss install kit. All you need is 3/8 fuel line and 2 clamps.
Do you have any idea what you're getting into? Who's doing the tuning? Do you plan on shifting around 7900-8000 rpm to take full benefit of that intake? What are your current mods? Auto? Manual?
Old 01-29-2015, 03:03 PM   #3
Awesome. Thank you.
Yes I do know what I'm getting into. I'm going to start with a basic bama/generic tune then when summer comes and I'll be using it I planned on taking it to get dyno'd and actually dialed in. Currently running Borla Catbacks. I'm just starting engine mods. Manual.
Old 01-29-2015, 03:15 PM   #4
The manuals don't like high rpm shifts and you've already had issues with your transmission. I don't think you do know what you're getting into.
Lol so you're going to have Bama tune the Cobra Jet Intake setup?
Good luck with that.
Old 01-29-2015, 03:21 PM   #5
natestang07's Avatar
Originally Posted by Capn__Morgan View Post
Awesome. Thank you.
That is a poor place to start for an engine mod
Old 01-29-2015, 03:22 PM   #6
How so?
Old 01-29-2015, 03:36 PM   #7
Rapinator126's Avatar
There is alot of work that needs to be done b4 you can hit high rpm shifts correctly, with the shifter,motor and tune.
Old 01-29-2015, 03:38 PM   #8
How so?
In my mind you are increasing flow In the middle of the system instead of working from one end to the other. But who knows if that makes sense
Old 01-29-2015, 03:38 PM   #9
Yes this I know. I planned on a cam swap next as well as possible dropping the entire tranny and putting in the Tremec Magnum.
Old 01-29-2015, 03:38 PM   #10
Why are you wanting to do a cam swap? What are your plans with the car? Current mods? Gears? Etc
Old 01-29-2015, 03:45 PM   #11
Because I understand I'm taking some power from the mid/low and putting it in the high end. The cam swap evens the car back out somewhat. I plan to keep the car entirely N/A which is why I'm taking this route. Car came with the GT Track Pack so it already has a 3.73 rear. Borla cats running with Borla long tube being added shortly. I planned on the whole kit (manifold, CAI, and TB)
Also let me clarify the tunes. I don't run this car at all in the winter, so I planned on buying a base BAMA tuner and using that. Then when I started running it getting a Lund tune because to my knowledge that will work on the Bama tuner. Correct me if I'm wrong?
Old 01-29-2015, 04:02 PM   #12
RollDat's Avatar
It's not a "BAMA" tuner, just an SCT device that bama puts their logo on if you buy from them. Any email tunes can be loaded onto it.
RollDat is offline   Reply With Quote
Old 01-29-2015, 04:03 PM   #13
Exactly. I thought any tune could be put on it. Thank you for clarifying.
Old 01-29-2015, 04:11 PM   #14
If you plan on staying NA and cammed. Change your header choice.
Old 01-29-2015, 04:16 PM   #15
---------- Post added at 06:16 PM ---------- Previous post was at 06:16 PM ----------
Whys that? Aren't long tube recommended for the CJ?
Old 01-29-2015, 04:19 PM   #16
Old 01-29-2015, 04:21 PM   #17
Yes but you will have far better results with a 1 7/8 primary and a 3" collector
Old 01-29-2015, 04:28 PM   #18
The plan sounds pretty good overall just remember the weak link for you is the transmission and clutch. Also you will need to address the oil pump gears as yours won't last for long at those rpm's. It's the rpm's that can be detrimental not the power.
And if Lund is going to be doing the tuning just go right to him from the start. They sell the SCT tuners with their tunes preloaded on them and will do free revisions. Beefcake Racing has the best prices and Terry and Thomas who both work for Beefcake Racing are very knowledgeable guys that will help you with any questions you might have.
Old 01-29-2015, 04:38 PM   #19
Okay. I didn't know Lund sold tuners. I didn't see them in my section. But thanks for the heads up. I'll also look into Beefcake.
Old 01-29-2015, 04:54 PM   #20
Old 01-29-2015, 06:47 PM   #21
Honestly man...it's not worth the power gains. The oil gears cost a great deal of money to install, and you'll need to add a mgw race spec to the mix. After you add everything up, you'll be in supercharger territory. I understand you want to stay n/a but what the hell for?
Mikeyt03 is offline   Reply With Quote
Old 01-29-2015, 09:43 PM   #22
hctr154's Avatar
You'll also need an oval style throttle body and custom intake tube/tract as the OEM factory one will not work.
2013 GT A6
hctr154 is offline   Reply With Quote
Old 01-31-2015, 11:24 AM   #23
GOTROD46's Avatar
Is that the same Beefcake that, used to run a Ford Lightning ?
Hammer Down !!!
GOTROD46 is offline   Reply With Quote
Old 02-03-2015, 07:22 PM   #24
diego302's Avatar
Cams won't increase bottom end or mid range for you. The best all around cams for the coyote are the stock cams. I personally wouldn't get a CJ intake manifold unless I had a Boss 302 to begin with. In order to get the most out of the CJ intake, you're going to have to rev up to 8k rpm. Full bolt ons such as quality headers, a cold air, and deleting the cats will really wake your car up. If that's not enough, then do a 50 shot.
diego302 is offline   Reply With Quote
cobra jet intake manifold RubyRed14GT General Mustang Discussion 40 01-13-2015 02:24 PM
Cobra jet manifold PISTONS8904 2011-2014 Mustang GT 18 05-07-2014 08:01 AM
Cobra Jet manifold jkattchee 2011-2014 Mustang GT 27 03-17-2013 07:32 PM
Cobra Jet Or not to Cobra Jet Jedimindtricks 2011-2014 Mustang GT 12 02-10-2013 09:10 AM
cobra jet manifold Supertzi 2011-2014 Mustang GT 4 08-20-2012 09:32 AM
12:00 PM
