11 gt offset question - Mustang Evolution
Old 01-29-2015, 11:43 PM   #1
so I'm looking at getting a set of 19x8.5 and 19x9.5 staggered wheels and was curious about acceptable offsets. The wheel I'm looking at offers a +35 and a +25 would the +25 work? If i understand correctly that would give a deeper lip due to the hub vein nearer the center of the rim.
11albinodark is offline   Reply With Quote
Old 01-30-2015, 05:44 AM   #2
BigJay's Avatar
+35 on the rear would probably fit but it depends on the wheels. The front with that width a +25 might work out the +35 is better. It depends on spoke design type of brakes etc. What wheels and brakes do you have. If you are wanting the +25 for the rear it's going to depend on tire selection and I would do a test fit first.
BigJay is offline   Reply With Quote
Old 01-30-2015, 06:35 AM   #3
DallasStang77's Avatar
+35 works until he lowers the car
Old 01-30-2015, 07:55 AM   #4
BigJay's Avatar
How do you know that?
Old 01-31-2015, 12:28 PM   #5
I run +45mm and the tires rubbed after I got MT 305/35/20. I had to roll the fenders. Being +35mm it's sticking out about a half inch further to the outside fender.
I know he's got 19" wheels but a +35mm offset isn't for the 11-14 mustangs. I believe it'll fit the new edge but it's not the best fit for the OP
Old 01-31-2015, 12:54 PM   #6
BigJay's Avatar
I agree it's not the optimum fit. I have 10 inch with a positive 42 offset with 285 and it works fine lowered. I figured the plus 35 offset on a 9.5 rim would only be a quarter inch difference to be outside. And being a 9.5 inch wheel I figured he would run no more than a 285 tire. It could be very close so the best thing to do if you really want the wheels is to mount it up and tested it.
Old 02-03-2015, 07:25 PM   #7
diego302's Avatar
I'm running 19x9.5 +35 all around without any rubbing issues. My car is slammed on coilovers.
diego302 is offline   Reply With Quote
Old 02-03-2015, 07:37 PM   #8
BigJay's Avatar
Tire size?
Old 02-03-2015, 11:21 PM   #9
diego302's Avatar
I've done 295/30/19 michelin pilot sports and 275/40/19 michelin pilot super sports. Super Sports are a bit wider than Pilot Sports.
Old 02-04-2015, 07:50 AM   #10
BigJay's Avatar
Good info
Old 02-04-2015, 09:33 AM   #11
Thanks for the input guys the tire size and offset fittings are still something I'm trying to figure out
Old 02-04-2015, 09:43 AM   #12
My brakes are the standard brakes for the gt/cs. So what would be a wheel size/ offset in 19 that would definitely work ? I eventually will lower the car about 1-1.5 inches nothing crazy.
Old 02-04-2015, 10:02 AM   #13
diego302's Avatar
19x9.5 +30 can be done in the front. IMHO, RTR's have the perfect offset for a square setup. In the picture, I'm running 295's up front on my RTR wheels. RTR's are a +35. I still have a bit of room to push the wheels outward a bit. Click image for larger version
Name:	ImageUploadedByMustang Evolution1423068904.105889.jpg
Old 02-12-2015, 07:17 PM   #14
C_Dailey95's Avatar
25mm on a 9.5 wheel works front and rear. With a 275/40 and lowered i never rubbed. The tire will stick out of the fender a bit though.
I have 9.5 +35 front and 10.5 +22 in the rear right now.
C_Dailey95 is offline   Reply With Quote
Wheel offset question RUNNWLD 1996-2004 Mustang GT 3 11-18-2012 10:51 AM
Wheel/Tire Question 17x9+24 offset doug5.0 Mustang Wheels & Tires 4 10-07-2012 08:03 PM
Wheel offset question. Napoleon85 1996-2004 Mustang GT 5 03-22-2012 07:58 PM
Offset question Rolltide 2011-2014 Mustang GT 2 01-24-2012 11:13 AM
OFFSET question DMAC Mustang Wheels & Tires 0 08-07-2004 12:17 PM
08:28 PM
