My 1/8 mile track day - Mustang Evolution
Old 01-30-2015, 01:22 AM   #1
grabber12's Avatar
Well I took the mustang to the track and I've never ran this car or an 1/8 mile track before. I ran a 8.62, my 60ft was 2.25 mph 87.90. I wasn't really happy with my time until I started seeing other cars running. Every Camaro was in the high 8s and low 9's. 2015 mustangs high 8s low 9's. I ran a 1/8 mile to 1/4 mile calculation on the internet and it says I'm only going to run a 13. 5 that doesn't seem right either
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 01-30-2015, 02:55 AM   #2
Standard or auto?
Just_Greg is offline   Reply With Quote
Old 01-30-2015, 04:11 AM   #3
Grabber Blue5.0's Avatar
Originally Posted by Just_Greg View Post
Standard or auto?
It says what he has in his signature.
The 60ft needs to come down some. Was it spinning off the line or did you hook okay?
Old 01-30-2015, 09:00 AM   #4
zinc03svt's Avatar
What was the DA, elevation, and temp at the track you ran at? Wow, and you have the famous M. Rousch tune.
Just for comparison my 14 auto with VMP tune on stock Nero's ran back to back 8.1's @ 88 mph. My 60' were 2.00's. That was 350 range DA and 1500' elevation. fyi
2014 "Cobra Jet" GT/CS
Automatic, Comfort pkg, Oxford White
zinc03svt is offline   Reply With Quote
Old 01-30-2015, 09:39 AM   #5
grabber12's Avatar
Elevation is 2000, it was raining on and off so I ran when there was a brake in the weather. Temp was like 68. I was faster then both my buddies I went with. They both have 5.0s as well. One of them has long tubes, 373 gears, high flow cats, 275 tires in rear. He was pissed that I beat him every time.
Sent from my HTC6435LVW using Mustang Evolution mobile app
Old 01-30-2015, 09:43 AM   #6
grabber12's Avatar
I put some new good year F1 supercar tires in the rear right before I left for the track but it didn't help traction. 255-40-19.
Old 01-30-2015, 09:57 AM   #7
You need a real drag radial. Were you spinning off the line? Did you leave off idle?
Old 01-30-2015, 10:51 AM   #8
Oh2freshstang's Avatar
Name:	ImageUploadedByMustang Evolution1422639943.508149.jpg
ID:	174534 This was my run with just upper & lower control arms. Have u tried checking what the run would of been like with 0 DA? There's online calculators to check.
Old 01-30-2015, 11:29 AM   #9
grabber12's Avatar
DA ?
Old 01-30-2015, 11:31 AM   #10
D/A=Density/Altitude.
It can make a big difference in your car.
Old 01-30-2015, 11:39 AM   #11
grabber12's Avatar
I launched from idle. I didn't just floor it either, I eased in to it as it got closer and closer to shift in to 2nd. When it went to 2nd it still spun a little and kicked the *** end out a hair. I'm sure it put on a good show for the croud. on 2 of my runs my auto did the annoying shift to 3rd then back to 2nd thing they do when 2nd spins to hard. I ran a 8.8 and 9.1 when it did that.
Old 01-30-2015, 12:22 PM   #12
You will definitely need a better tire if you're looking for a better 60ft.
Old 01-30-2015, 12:25 PM   #13
Seems like your launch needs some work or help, looking at your 60 foot. also, the MPH, seems down some, especially for that cool air, with the spinning your experiencing, the MPH should theoretically be a little higher. On the F1's with a minor heatup, and no waterbox, and launching off idle, you should see 1.9's. How did you approach the lights? Did you bypass waterbox? did you shut down advantrac?
DeepImpactPony is offline   Reply With Quote
Old 01-30-2015, 12:32 PM   #14
grabber12's Avatar
Trac control was ON. There was no way around the water box so my tires got wet. I heated up my tires just a little but didn't sit there and smoke them. I was at Irwindale CA track. Light rain on and off. Like I said I'm not happy with the time but considering I beat my friend who has more mods than me it was good to see.
Old 01-30-2015, 12:37 PM   #15
That explains your 60 foot then. Shut advancetrac completely off, and ask track personnel if you can drive around water, most tracks expect this on street tires.
Old 01-30-2015, 12:42 PM   #16
Yea I don't see that on my mobile app...
Old 01-30-2015, 01:03 PM   #17
rocknbronco's Avatar
Well guess your not living a quarter mIle at a time yet so I would suggest better tires and more practice on launch also better or rather dryer track conditions.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 01-30-2015, 01:23 PM   #18
grabber12's Avatar
Well the water box was as wide as the entrance leading up to the tree so there is no driving around it. When I launch with Trac OFF it spins real bad then when it shifts to 2nd the *** end gets sideways. Better tires will fix that so next time I go I should have my 15x10 sve wheels
Old 01-30-2015, 01:30 PM   #19
http://www.dragtimes.com/da-density-...calculator.php Use this to see what ur times would be in neutral DA.
Irwindale usually had decent DA. I agree with grabber tho better tires would really help out. I need to get some better tires asap.
Old 01-30-2015, 01:34 PM   #20
Did u try running in sport mode? I usually run it in sport mode because completely off will spin like crazy & on will kill my times.
Old 01-30-2015, 01:53 PM   #21
grabber12's Avatar
No I didn't do sport. It's crazy that the track has less traction then the street. Any car I've ran seemed like the track was crap.
Old 01-30-2015, 02:49 PM   #22
Yea Irwindale isn't known for the best track prep..I'm sure it's better than most streets tho! Haha. Better tires would definitely help tho & maybe trying sport mode or different launching techniques. Did u lower the PSI on the tires at all?
Old 01-30-2015, 03:37 PM   #23
grabber12's Avatar
I didnt mess with my pressure, just hours before I went to the track I had 2 new tires put on because I got a flat tire and didnt want to patch a warn tire then take it to the track. Like I said above I went with 255-40-19s Goodyear F1 supercars. I think it was a super bad track day just because of all the high 8s and 9s I seen. CTS-V caddy was low 8s, Camero 1LE low9s, STR8 300 mid 9s on radials, and every 2015 Mustang was high 8s to low 9S. Got a few on video. On the way home my friend wannted to run on the freeway and he use to pull me bad on a roll but now we were neck and neck then o creeped on him and the only different thing ive done was Mike Roush tune so I must say the tune helped from my last tune. Whats crazy is he has more mods then me, he is lighter with carbon fiber trunk and hood, i had a passanger too. I still took him so it was still a good night.
Old 01-30-2015, 06:57 PM   #24
I usually lower mine between 25-27psi & it seems to help. Yea no matter what times u get track time is always fun! U should try hitting up Fontana speedway. They have 1/4 street legals like once a month!
Old 01-30-2015, 08:08 PM   #25
grabber12's Avatar
yeah i think CA speed way will be doing a track day next month. I herd its 50$ to race though. ppssshhhh rip off. I keep putting off better tires and 15x10s but now its got to be the next thing i buy. I keep spending money on guns
Old 01-31-2015, 12:47 AM   #26
Dam $50 is crazy! Fontana is $20 on street legal days! I think test & tune is a bit more. Yea I need slicks soon too there next on the endless list. Lmao.
$75 Track day at Willow Springs- Horse Thief Mile -Sept 15 in SoCal Extremespeed Regional Mustang Discussion 1 09-05-2012 01:18 AM
$75 Track day at Willow Springs- Horse Thief Mile -Feb 18-19 in SoCal Extremespeed Regional Mustang Discussion 0 01-28-2012 01:19 AM
$95 Track day at Willow Springs- Horse Thief Mile-Oct 16th Extremespeed Regional Mustang Discussion 2 10-08-2011 06:01 AM
$85 Track day at Willow Springs- Horse Thief Mile - April 2-3rd in SoCal Extremespeed Regional Mustang Discussion 2 03-19-2011 03:14 AM
$85 Track day at Willow Springs- Horse Thief Mile - November 20 - 21st in SoCal Extremespeed General Mustang Discussion 1 10-23-2010 10:55 PM
03:44 AM
