Too lean bank 1 and bank 2 - Mustang Evolution
Old 01-30-2015, 09:02 AM   #1
Region: Nevada
I have a 2010 mustang with the check engine light on reading the codes too lean bank 1 and 2 .how do I fix that ?
meno1994 is offline   Reply With Quote
Old 01-30-2015, 09:03 AM   #2
Rapinator126's Avatar
Who is your car tuned by?
Rapinator126 is online now   Reply With Quote
Old 01-30-2015, 09:09 AM   #3
Region: Nevada
Well I bearly bought the car like a week ago so Im not sure if it's tuned or not.
Old 01-30-2015, 09:10 AM   #4
What Is done to the car? You didn't ask if it was tuned when you bought it? Or was it from a dealership?
Old 01-30-2015, 10:02 AM   #5
Region: Nevada
Yeah I got it at a delear. It does have a after market air intake
Old 01-30-2015, 10:05 AM   #6
Which cai does it have?
Old 01-30-2015, 10:08 AM   #7
Region: Nevada
Codes P0171 & P0174 (Too lean bank 1 & Too lean bank 2)
Old 01-30-2015, 10:12 AM   #8
It could be a few things. Thats why I need to know more about the car.
But roughly.
1. The tune
2. O2 sensors are bad, usually show (stuck rich) when this is the case though.
Old 01-30-2015, 11:16 AM   #9
thelastsumurai's Avatar
If you have an after market CAI that requires a tune and you don't have a tune installed you can get a too lean condition. Put the stock CAI back on and clear the codes and see if the codes come back. In either case I'd go back to the dealer and bi##h about it.
thelastsumurai is offline   Reply With Quote
Old 01-30-2015, 11:19 AM   #10
Originally Posted by thelastsumurai View Post
If you have am after market CAI that requires a tune and you don't have a tune installed you can get a too lean condition. Put the stock CAI back on and see clear the codes and see if the codes come back. In either case I'd go back to the dealer and bi##h about it.
somewhat. 90% of the time if you have a CAI that requires a tune, and you do not have one. Your car will not even iddle correctly do to the MAF signals being jacked up
Old 01-30-2015, 11:26 AM   #11
Seanp94's Avatar
I bet it was tuned and the last owner returned the car to stock to keep his tuner. Now that you're using the car the check engine light is coming on because the cai on the car requires a tune.
Seanp94 is offline   Reply With Quote
Old 01-30-2015, 11:30 AM   #12
Ditto
Old 01-30-2015, 11:42 AM   #13
olerodder's Avatar
Region: Oregon
I also had the same condition, although mine was just lean on bank#1.
I bought my 14 GT/TrakPak car with 2700 miles on the odometer. It had an Airaid CAI and SCT tuner, the tuner came with the car. When I took the tune out of the car to go back to the Ford dealer it was a little sluggish, throttle response was not the same crisp feel although the idle was fine it was not the same car without the tune. During the time that the tune was out I really never hammer it, I just drove like I had an egg between my foot the throttle pedal. When I got it back from the dealer I warmed it up, and found the nearest straight stretch of road, then hammered it..............the car would barely pull past 6,000 and just felt sluggish (compared to having the tune when it went past 7000). I came to a stop light and looked down and the check engine light was one so I drove home. I got my tuner and read the code and it was 171, lean on bank#1. The next day I called SCT and talked to Mo, and he told me that they get this quite often when someone puts the car back to stock tune and it has a CAI. I erased the code with the tuner, put the tune back in and everything is great once again.
With yours being lean on both banks............at least that part is good because that would tell me your distribution is pretty much spot on..............with mine being lean on just one side that's a different story that can only be fixed with a better tune...IMHO
Old 01-30-2015, 11:43 AM   #14
Region: Nevada
Well at some point when the dealership had it .it did pass smog. So idk why it's giving this code now. I've been bringing the car back and forth because they try something new to fix it every time and the Engine light always comes back on. They changed the intake manifold gasket, they said the fuel pressure is good, they checked all hoses to make sure there wasn't a hole. What else could it be??
Old 01-30-2015, 11:48 AM   #15
Region: Nevada
Exactly sounds exactly what's going on with my car. I do have a air raid intake also and when I hammer the car it doesn't have the power it needs like it doesn't push you back it just slowly goes up in speed but it's still fast just needs that extra hump. My car does idle smooth but it's also really bad on gas idk if it's just cause its a v8 or that something else is causing it to have bad gas mileage
Old 01-30-2015, 11:53 AM   #16
Does anyone read what is posted from b4.
If thr cai requires a tune thr car will not iddle correctly without it. The MAF signals will be messed up
Old 01-30-2015, 12:03 PM   #17
olerodder's Avatar
Region: Oregon
I have no idea why they would have checked it for smog because it was a front brake issue. When I first talked to Mo at SCT he told me anytime I take into the dealer I should bring it back to stock tune. He said that if I had the tune in it and the Ford shop hooked up their test equipment to the OBD port bad things may happen, like I would be locked out and unable to change the tune with my current tuner................so anytime I will take it for service I will take the tune out just to be safe.
So, do you have a tuner or not!
If you answer is no, then that's the first thing I'd do, or just put the stock CAI back on. Personally I don't think a CAI brings much to the party on the Coyote motor..............as I've proven to myself by taking my tune out. With the tune you won't know it was the same car.................in first and second without the tune I could spin the tires............with the tune I can put the car sideways at will in either 1st, 2nd, and sometimes in 3rd. With the tune out the motor struggled after 6000, with the tune it pulls strong up to 7500.
Don't walk, run to get a tuner......................it will really wake the car up!!!!!!!
Old 01-30-2015, 12:36 PM   #18
Region: Nevada
Ok so if I get a tuner. I do it myself right? I've never looked into that.
Old 01-30-2015, 12:38 PM   #19
olerodder's Avatar
Region: Oregon
If a 70 year old guy can do it, I'm sure a youngster can.
Just go buy one, put the can'd tune in..................if you want more contact one of good tuners mentioned here and they can email you one................if you can operate a computer you can do this...............and if you have trouble you can call the tuner manufacture like I did to help me through my first load/unload.
Simple
Old 01-30-2015, 12:42 PM   #20
Region: Nevada
Do you think it'll also fix my too lean codes?
Old 01-30-2015, 12:50 PM   #21
olerodder's Avatar
Region: Oregon
I'm not guarantying that it will solve the over lean condition. As long as you don't have vacuum leaks I would think it should.
It solved the issue I had on my 2014 Coyote motor and back in the late 90's (we didn't really have tuners like they have now) when I put a CAI on my 97 SVT Cobra............it was tuned on chassis dyno and the lean condition issue was fixed.
Running a lean motor can lead to replacing pistons and or a motor.............IMHO
Old 01-30-2015, 01:17 PM   #22
Grabber Blue5.0's Avatar
I would not be putting a tune on this car until you deal with the codes.
Old 01-30-2015, 01:37 PM   #23
olerodder's Avatar
Region: Oregon
Grabber Blue5.0 made a good point, putting a tune in the car with the codes is probably not the best thing to do.
How many miles does the car have on it? Did the check engine light come on after you drove it for a day, week, or ????
Has the dealer deleted the codes before.............if not have them delete the codes. Take the car out and drive it easy...........don't go WOT, just drive it like an "ole lady" for a couple of days and see if the check engine line comes on.............my guess is that driving it this way it won't.................then after a couple of days of no check engine light go out and put the pedal to the metal...............if the check engine light comes back on then I'd be pretty sure it's going lean at WOT and although it still could be a number of issues like fuel pump, injectors or ????, I would almost bet it is the CAI. The only way to really check would be to have the dealer check the air/fuel ratio at WOT to see where it is. Just a guess, but if you have the codes cleared and drive it easy around town and on the highway...........and the check engine light doesn't come on at least that would be a start to narrowing in on this issue.
Just thinking out loud.
Old 01-30-2015, 02:15 PM   #24
Koryak's Avatar
Try borrowing a scan tool or get the dealer to tell you the "freeze frame" info for when the lean code was set. This will give an idea of engine load & rpm at he time the lean condition happened. Another thing to look at is the "long term fuel trim" data which has to be high like + 20 - 25 percent.
If the CAI tube has oversize non-stock diameter at the air flow sensor position then the stock tune can't read the flow correctly - like other posters have said. I think this would likely show up at light throttle or idle but the freeze frame data will tell all.
Koryak is offline   Reply With Quote
Old 01-30-2015, 02:30 PM   #25
natestang07's Avatar
My car wouldn't even run without a tune for my cai. I think all we need to. Solve this is a tune
Old 01-30-2015, 07:47 PM   #26
It's definitely the tune. I just ran into the same problem
danixenia is offline   Reply With Quote
Old 01-30-2015, 08:26 PM   #27
listen people listen
Old 01-30-2015, 08:35 PM   #28
olerodder's Avatar
Region: Oregon
I'm listening, but no one is saying anything
Old 01-30-2015, 08:46 PM   #29
Read my previous post. Not rocket science
Old 01-30-2015, 10:37 PM   #30
I'm so bad at listening
Old 01-31-2015, 09:53 AM   #31
olerodder's Avatar
Region: Oregon
Which one...........none of them seemed to say anything.
Old 01-31-2015, 09:57 AM   #32
Said exactly what it needed to. I could care less if any of yall listen or not. Not my problem.
Old 02-06-2015, 10:45 AM   #33
Region: Nevada
Ok was looking around my gas tank area and something caught my eye. There is a hose sticking out where u put gas in leading to the gas tank. There is a ripped hose just sticking out!! I think that's leading air in.
Old 02-06-2015, 11:50 AM   #34
Region: Nevada
Well I went to mechanic and I guess ford put that there to drain rain water ugh
System too lean bank 1 and 2... Suggestions? Ethier95 2005-2010 V6 Mustang 2 09-27-2013 08:15 AM
Bank 1 and bank 2 running lean. Rich04 1996-2004 Mustang GT 19 04-23-2013 07:20 PM
system to lean bank 2 kingc cobra 97 SVT Mustang 5 01-27-2013 11:20 AM
1998 4.6 running lean on bank 1 and 2 eddie1 1996-2004 Mustang GT 22 11-28-2009 04:54 PM
left bank lean 98mustang2007 Pre-2005 V6 Mustang 1 09-17-2007 07:42 PM
04:58 PM
