Procedure for Profile Learning on Ford Racing ProCal?? - Mustang Evolution
Old 01-31-2015, 04:48 PM   #1
Question Procedure for Profile Learning on Ford Racing ProCal??
Tried the Profile Learning function as a last resort to fix the pinging issue, but the red light never turns off. I was sitting there for about 20 minutes blipping the throttle a number of times to 3.5k, then 4.5k, then 5.5k, and even to about 7k but nothing seemed to work. Red light stayed on and then it gave me the P0315 error. I drove it around for little bit after that and now it says there are no stored DTCs, but it says that with the red "error" light illuminated. Is that normal?
I've changed the octane adjust to "Y", installed a JLT oil seperator on the passenger side (installed for about 1,200 miles), and I am using 93 from Shell.
Does anyone have any suggestions or run into similar issues?
Thanks.
Gray13 is offline   Reply With Quote
Old 02-01-2015, 12:00 PM   #2
Should not be giving any form of red light. Just should set the "wrench" cel and then the blips continue til it goes out. Must be over 3.5 k. Usually takes me a minute, tops.
You sure it's ping? I pulled the plugs after 3 years of running this tune and there was no evidence of any ping damage on them and the engine was spot on across all 8 for compression. The engine will still occasionally give a little transitional rattle at about 4.5k every once in a while but, performance has been outstanding for me.
Old 02-01-2015, 01:21 PM   #3
Thanks 5LHO.
Took the car for a drive earlier today and everything seemed fine. It still has the red "error" light illuminated on procal when I use the "read DTC" function, even though it says there are no stored codes. I could have sworn that the error light was not on that last time I checked for codes. I'll give the tech line a call tomorrow and see what they say. It's probably fine and I'm just being paranoid.
Old 02-01-2015, 03:05 PM   #4
Could be bad comms cable...?
Old 02-02-2015, 10:42 AM   #5
Was the engine running before you pushed the button for relearn? That's a problem I had. Red light says that it was not done properly.
Cobrakit is offline   Reply With Quote
Old 02-06-2015, 09:29 AM   #6
Now that you mention it, I might have started the car before starting the learning procedure.
I did get a chance to call the tech line about checking the DTCs. They said that the red error light being on When checking for codes is normal.
Data Log procedure Konawin 2011-2014 Mustang GT 11 04-04-2014 05:49 PM
Ford's procal tune Smoke 2011-2014 Mustang GT 9 08-17-2012 09:00 PM
Procal Ford Tuner and K&N filter? dailey 2011-2014 Mustang GT 9 07-15-2011 01:40 PM
What is the proper procedure for installing clutch kit for ford mustang 1973? bernardas Classic Mustangs 1 03-20-2010 09:04 PM
DOHC Refill & Burp Procedure jm@ReischePerf 1996-2004 Mustang GT 3 09-30-2009 07:09 PM
12:05 AM
