Brake creak issue. - Mustang Evolution
Old 02-04-2015, 12:11 PM   #1
Jvibe92's Avatar
Brake creak issue.
Okay so I'm slowing getting annoyed. I have a loud audible creak noise that comes from the front driver side brake assembly. It occurs when in motion and when idle. It's most pronounced when releasing the brake. Took it into the dealer cause I needed an oil change and alignment(lowered car) and they glazed the rotor and changed the pins. Issue still there. What could be possible reasons for brake creaks even at idle. Pads are still 60-70 percent.
Jvibe92 is offline   Reply With Quote
Old 02-04-2015, 12:26 PM   #2
Jvibe92's Avatar
http://youtu.be/OibEDSI9ljk
Old 02-04-2015, 01:59 PM   #3
oxford5pointoh's Avatar
Brake creak issue.
That sounds like the caliper moving on the guides as it clamps the rotors. Maybe just lube up the pins? Is it a brembo car? What did the dealer say?
Just enjoying my 420 HP daily driver
Old 02-04-2015, 02:23 PM   #4
Jvibe92's Avatar
Pins were replaced and lubed already
Old 06-02-2015, 06:45 PM   #5
09rider's Avatar
Hey, Did you get this figured out? I think I am having a similar problem. I read that on maybe cleaning out the dust on the calipers and pin as well as applying a grease to the pad can remedy this for a short time.... I haven't had time to play around yet.
09rider is offline   Reply With Quote
Creak noise when turning the wheel sebasflorez Pre-2005 V6 Mustang 19 11-21-2013 01:20 PM
Embarrasing Steering Creak? ccabral14 1996-2004 Mustang GT 20 11-16-2013 10:22 PM
Floor Mats and Dash Creak Jeffola 2011-2014 Mustang GT 13 01-13-2012 08:25 AM
Need Help!! Center Console and Parking brake issue... Frogleg 1996-2004 Mustang GT 5 04-15-2009 10:10 AM
brake line issue... jimmy_beaner 1996-2004 Mustang GT 0 03-24-2008 08:11 PM
01:07 AM
