4 fog lights at same time! - Mustang Evolution
Old 02-04-2015, 12:56 PM   #1
Mory's Avatar
Hello Guys, I'm planing to add the FORD FOG LIGHT KIT - LOWER VALANCE (13-14 GT) part # DR3Z-15200AA.
Can I run them with my grille fog lights ?
I have 2013 GT Premium.
Name:	ImageUploadedByMustang Evolution1423079637.552600.jpg
Thanks
Mory is offline   Reply With Quote
Old 02-04-2015, 01:19 PM   #2
oxford5pointoh's Avatar
You will have to modify the harness or splice into the existing harness if you want to run them off the factory switch. But you might have to look into how much amperage is being pulled by running them both. Might have to change the fuse and or relays. I know I have seen it done.
Just enjoying my 420 HP daily driver
Old 02-04-2015, 01:30 PM   #3
Mory's Avatar
Thanks, any idea how to change the relay? Just to be safe.and dose the wires handles the high amp ?
Old 02-04-2015, 01:46 PM   #4
WJBertrand's Avatar
I've got that set up on my 2013 premium. Since the lower valence fogs are incandescent bulbs, I think they will draw more (55W each) than the LED fogs in the grill, which have surprisingly small harness wires leading to them. I don't think they'll handle the additional load.
To be safe, I tapped one of the OEM LED fog light's + wire to trigger a relay ($5 at AutoZone). I then ran a new (fused) wire from the terminal in the fuse box that the battery attaches to, through the switched side of the relay, and then to the new valence fog lights. I paired the + leads and ground leads for each bulb.
It should be easy enough to add a switch later if I decide I want to control them separately.
ID:	174856   Click image for larger version
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 02-04-2015, 01:48 PM   #5
Sweet! There's your answer. Looks good
Old 02-04-2015, 02:00 PM   #6
Mory's Avatar
Thanks that's really helps
Old 02-04-2015, 04:16 PM   #7
bazinga11's Avatar
Halogens won't do you any good in those tiny fog light projectors - might as well get a HID kit before you put them in. Color match with your grill fogs would just be a bonus
$0.2
Old 02-04-2015, 05:22 PM   #8
hctr154's Avatar
Nice little project, but around here the local boys in blue would be all over you!
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 02-04-2015, 05:37 PM   #9
WJBertrand's Avatar
$0.2
I'm actually thinking of putting amber bulbs in there, as the yellow light is better at penetrating fog than white or especially blue light. Don't have to worry about a color match that way either.
As far as effectiveness, it's pretty surprising how much light those little projectors throw out there.
-Jeff-
Ventura, CA
Old 02-04-2015, 06:25 PM   #10
bazinga11's Avatar
Oh okay makes sense then. How much are those amber bulbs going to run you? - I ask cuz you can easily get 3000K color H11/H9 HID kit for $35, better/more light of course. But upto you.
PS: this fog light kit is for 120 bucks right? Does it come with everything you'd need to make it work on your car?
Old 02-04-2015, 10:27 PM   #11
WJBertrand's Avatar
All of $5 I expect, if not less.
-Jeff-
Ventura, CA
Old 02-05-2015, 12:14 PM   #12
I have that same set up running for one year no problems. I tapped into stock fog lamps very easy looks Great!!
Teak 14 is offline   Reply With Quote
Old 02-05-2015, 04:51 PM   #13
WJBertrand's Avatar
No relay?
-Jeff-
Ventura, CA
Old 02-05-2015, 05:18 PM   #14
Waylap1's Avatar
Region: New Hampshire
People already wrongly assume my stock GT fog lights are my hi beams because of their location and flash me.
With another set of fogs in a normal spot on at the same time it may be worse,plus the fuzz factor.
Are you getting hi beamed more now?
Waylap1 is offline   Reply With Quote
Old 02-05-2015, 06:06 PM   #15
Mory's Avatar
Like rally cars
Name:	ImageUploadedByMustang Evolution1423184782.697705.jpg
Don't have them yet
Old 02-05-2015, 07:07 PM   #16
Region: Oregon
In some states (like here in Oregon) your Fog Lights are treated like Hi-Beams and must be turned off when traffic approaches. I get flashed in all my cars if I leave my fogs on.
https://www.google.com/url?sa=t&rct=...85464276,d.cGU
skramblr is offline   Reply With Quote
Old 02-05-2015, 07:19 PM   #17
olerodder's Avatar
Region: Oregon
I just moved to Oregon from California and didn't realize this was a law....................I just got back from a 600 mile road trip and from Corvallis to Redding I used the fog lights at night for over 300 miles...........only got flashed once.
I'll think twice about driving with them on from now on.....at least around town.
Old 02-05-2015, 09:35 PM   #18
Coyote2820's Avatar
Yeah you should check your state laws so you are clear and prepared for whenever you get stopped. That's what I did and it was useful information. There are a lot of loopholes and discretionary leniency in Oklahoma as far as using your standard headlamps, fog lights(only with low beams on OR at drivers discretion) 2 sets of fog lights allowed on the front: only 1 set legal to drive with on road; also you are allowed a set of "auxiliary lights" along with the daytime running lights and blah blah blah you're only supposed to have 4 lights on total unless off road but it's all at your discretion at the end of the day. Pisses cops off to hear but a judge would throw out that ticket.
Name:	ImageUploadedByMustang Evolution1423197254.933742.jpg
Name:	ImageUploadedByMustang Evolution1423197298.460818.jpg
2014 5.0 GT Premium - Active Duty
2013 5.0 GT - Retired
2003 GT - Retired
Coyote2820 is offline   Reply With Quote
Old 02-06-2015, 12:10 AM   #19
bazinga11's Avatar
OP: does this kit come with all the hardwired and wiring needed for installation? Or do you have to buy additional stuff to make it work?
Can i have both grill fog lights and lower fog lights working at the same time? servs 2011-2014 V6 Mustang 3 03-31-2014 05:35 AM
switching top and frames at the same time flysure1 1979-1995 Mustang GT 1 01-14-2008 12:04 PM
Swap my Cobra fog lights for your GT fog lights TheDad Mustang Parts for Sale and Wanted 1 01-19-2006 01:01 PM
Everyone you got to read this! Hilarious, scary and sickening at the same time Brent The Bar 62 11-16-2005 06:40 PM
LOL!!! this is horrible but funny at the same time... Zim The Bar 3 01-06-2004 04:42 PM
07:56 AM
