Any additives needed when changing MT fluid? - Mustang Evolution
Old 02-04-2015, 11:37 PM   #1
Is there anything else needed to be added to the fluid when you change it. I swapped my fluid out for Royal Purple Syncromax the other day and it seems like I can hear the "clunks" of the gears when I shift. Or even when I just engage the clutch to take off. And it didn't really seem to take away the notchiness like I thought it would.
And I know the correct amount is supposed to be 2.7 quarts, so I marked a small container with what I measured out to be 2.7 quarts. The car was basically level, maybe slightly tilted down to the back if at all. Fluid drained right out but filled the container more than 2.7 quarts. Not by much but some. So when I went to refill with the RP stuff I pumped in 2.5 quarts knowing I was getting close. And since the car might have been slightly tilted back that it may start coming out of the fill hole sooner than it should.
Kept pumping and got to what I thought would be right and it still never came out. I measured what I still had left in my bottle and it was actually less than 0.3 quart. So technically I put in a fuzz to much, but by what I took out I may have put in a fuzz not enough lol.
So should I have seen fluid coming out of the fill hole once I hit the 2.7 quart mark or no? Do I need to go back and add until I do or is it good. This also has me wondering since I was hearing that clunking noise.
Thanks
MOOSEDAWG29 is offline   Reply With Quote
Old 02-05-2015, 06:50 AM   #2
scott_0's Avatar
Ive read, once youre at the 2.7qt mark, it should be about a 1/4" below the fill hole
Old 02-05-2015, 04:55 PM   #3
WJBertrand's Avatar
Ford has an additive called XL-18 especially for the MT-82 manual transmission. About $20 at your Ford dealer.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 09-08-2015, 09:58 AM   #4
oxford5pointoh's Avatar
Op,
I am looking at using the same fluid. I read royal purples site and they say no other friction modifiers are needed. Did you ever get the additive or not? Did the transmission ever get better or did it explode? I know this thread is a little old but I used the search function and this was my exact question before I use this product.
Old 09-08-2015, 05:17 PM   #5
I like redline mtl and 1st choice amsoil transaxle fluid 75-90 I believe as 1st choice
chefron50 is offline   Reply With Quote
Old 09-08-2015, 05:44 PM   #6
If you go to either of their websites they do not recommend an oil for the MT-82. I typically run amsoil.
Old 09-08-2015, 05:53 PM   #7
i like redline mtl and 1st choice amsoil transaxle fluid 75-90 i believe as 1st choice
sent from my sgh-m919 using mustang evolution mobile app
75/90 is way to thick for these transmissions
ALLYDRIVER1 is offline   Reply With Quote
Old 09-08-2015, 05:59 PM   #8
I really just want to know if the royal purple syncromax is good to go with no additives. Anyone who has had experience with this please give us some feedback. Thanks
Old 09-08-2015, 06:00 PM   #9
Rapinator126's Avatar
No it's not. It's what I run its the amsoil MTG.
🍼and 🌽 fed coyote.
Old 09-08-2015, 06:41 PM   #10
Ben Calimer the Mt 82 guru recommended the amsoil transaxle 75-90 to me
Old 09-08-2015, 06:49 PM   #11
And do you run it? If so what are the results?
Old 09-08-2015, 07:19 PM   #12
Already bought 3 quarts but he is still building my tranny, it should be ready this week and I should get it shipped by next week then I will let you know
Old 09-08-2015, 07:22 PM   #13
I got his stage 2, REM polished internals and cryo treated internals, plus a few secrets he won't give up
---------- Post added at 08:22 PM ---------- Previous post was at 08:22 PM ----------
He claims it's holding a thousand horsepower right now
Old 09-08-2015, 09:14 PM   #14
bazinga11's Avatar
General rule of thumb with amsoil is hot it gets where you drive. For Texas heat, MTG would be surely a good idea. For every where else, Ben Calimer suggests MTF synchromesh..without any additive. Or 2:1 ratio of MTF and MTG if it's really hot, but not as hot as Texas.. No winters what so ever.
Sent from my SGH-I337M using Mustang Evolution mobile app
Old 09-08-2015, 10:44 PM   #15
Well I'm in Florida, just as hot
Old 09-09-2015, 12:14 AM   #16
bazinga11's Avatar
I'd say try 2 quarts of MTG and 0.7 of MTF and see how it goes.
Anyone use oil additives here? lisl12 2011-2014 V6 Mustang 19 08-30-2014 06:40 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Best Gas to use and any additives? Spiney SVT Mustang 5 12-23-2011 05:35 AM
Additives Blackedout General Mustang Discussion 16 03-07-2011 06:33 PM
Fuel Additives redGT773 1996-2004 Mustang GT 7 01-03-2009 03:28 PM
08:59 PM
