Clutch chatter! - Mustang Evolution
Old 02-06-2015, 09:21 AM   #1
94gtconvert's Avatar
Clutch chatter!
Hey guys. I have a early build 2011 gt and it is on its second mt-82 which is a 2014 model and works awesome. Now at 41,000 miles I have clutch chatter. I'm not mad or anything because I know the car was raced by my family member I bought it off. It has a line lock on it. But I also drive it spiritually quite often so it has taken a beating. It chatters if I let the clutch out more towards the top of the pedal. of I ride it more towards the floor it won't chatter. I'm most likely going to be doing a clutch job this summer. and am seeing witch one to get. I'm looking at either mcloud or centerforce. Just a single disk ceramic. I'd like to spend under$700. Also what's a good throwout bearing. I daily drive this car and need it to be reliable. Not sound like a diesel when it idels because of a cheap throw out bearing.
94gtconvert is offline   Reply With Quote
Old 02-06-2015, 09:48 AM   #2
Voltwings's Avatar
The chatter isnt from the throwout bearing, its from the flywheel. Is there a factory clutch in the car now?
Old 02-06-2015, 09:54 AM   #3
Yes factory clutch, flywheel, and throw out bearing. I know it's not the throwout bearing. It's a warped clutch or flywheel. It's going to get new everything. But I'm just wondering what clutch to go with. I definitely don't want an aluminum flywheel.
Clutch chatter ccabral14 1996-2004 Mustang GT 4 03-07-2014 05:25 PM
Clutch/bearing chatter/grind Splogan 1979-1995 Mustang GT 1 11-30-2013 06:10 PM
2006 Clutch - very minor chatter from 1st - 2nd RedFire2006 2005-2010 Mustang GT 3 10-07-2009 09:19 PM
May cause slight chatter at low RPM engagement SuperItalian Pre-2005 V6 Mustang 0 06-12-2007 01:43 PM
Clutch chatter Mike D. Classic Mustangs 13 03-30-2007 03:07 PM
07:49 PM
