Tapping in to dome light - Mustang Evolution
Old 02-06-2015, 11:56 PM   #1
I'm adding led footwell lights. I looked around and it seems the only source is coming from the a pillar. I have the auto dimming mirror so there are two seperate wiring harnesses. I also read some where that the I can tap in to auto shift light source but I have a manual. Can some one point me in the right direction. I want my footwells to turn on and off along with my dome lights. I did it to my wife's 13 camaro and I tapped in to a wire from the bcm.
Sent from my SM-N910T using Mustang Evolution mobile app
jrdnsky59 is offline   Reply With Quote
Old 02-07-2015, 12:14 AM   #2
Nevermimd,found it. Yellow/green from passenger a pillar.
Old 02-07-2015, 08:09 AM   #3
oxford5pointoh's Avatar
Yeah I took a test light to it. Make sure you get the one that dims after the door is shut. I did the same thing. Then there is a good ground location right above the fuse box you can use.
Just enjoying my 420 HP daily driver
Old 02-07-2015, 08:22 AM   #4
Strange Mud's Avatar
+1 on fuse box right side lower kick panel.
Old 02-07-2015, 10:32 AM   #5
The one that dims is the yellow/green wire?
Old 02-07-2015, 10:59 AM   #6
Exclamation
I do not have the auto dim rear view mirror.
Can I still use the Yellow / Green wire??
Where is that wire located please??
Can I find that wire near the passenger side fusebox without having to remove the A-pillar?
I have a pair of the factory OEM lighted rocker panels that light up and say MUSTANG that I got from a 2014 Mustang that had them. I am guessing the plug for that is not already under the carpet and that I will have to tap into a wire that goes to the dome light.
Thanks for the help!
GT 1 is offline   Reply With Quote
Old 02-07-2015, 01:39 PM   #7
I believe it is the green/yellow wire. I think u can tap into the mirror harness if u have 7 wires running into your mirror.
Old 02-07-2015, 11:31 PM   #8
It was not the yellow and green wire. It was the purple and brown wire so it can dim along with the dome lights
Old 02-08-2015, 10:45 PM   #9
Yep. That's the one.
Dome light fuse Renegade 800 Pre-2005 V6 Mustang 7 09-06-2016 07:45 PM
578 dome lights to 578 42mm led dome lights? Sluder4 Pre-2005 V6 Mustang 5 03-10-2013 05:51 AM
Map light/dome light 99redgt 1996-2004 Mustang GT 3 01-22-2012 05:53 PM
Help Me. Dome Light Acting Up brentmustanggt 1996-2004 Mustang GT 17 08-31-2010 10:57 PM
Adding LEDs to the dome light. Dom Mustang Audio & Video 14 03-08-2004 09:00 PM
08:51 PM
