Man these shops charge a lot to put on racing strips. - Mustang Evolution
Old 02-07-2015, 12:08 PM   #1
Devil Strider's Avatar
Seems like if you don't buy their strips they charge you more. Then some act like they can only put on their strips. I already paid for the strips form Big Worm so someone's putting them on. One shop said $500, another said $600. Got one more to check but they are closed on the weekends so I'll check them out Monday.
Sent from my SM-N910P using Mustang Evolution mobile app
Devil Strider is offline   Reply With Quote
Old 02-07-2015, 12:48 PM   #2
natestang07's Avatar
If you are patient you might consider doing it yourself because that is a lot of money
Old 02-07-2015, 01:03 PM   #3
Yeah I agree. I'm going to start researching it now.
Old 02-07-2015, 01:09 PM   #4
Just measure everything up a couple times and take your time
Old 02-07-2015, 01:40 PM   #5
Noodles76's Avatar
I was quoted 350 including materials and install.
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 02-07-2015, 01:47 PM   #6
2014 5.OHHHHHH
Yeah I found out this one place starts at 350 with materials. So I'm going to check them out Monday to see how much it is with my own materials.
Old 02-07-2015, 01:51 PM   #7
Noodles76's Avatar
If it's cheaper you could buy theirs and sell the other ones. Just another option.
2014 5.OHHHHHH
Old 02-07-2015, 01:54 PM   #8
2014 5.OHHHHHH
Or maybe return it if that is an option
Old 02-07-2015, 02:30 PM   #9
20bmr14's Avatar
Research dyi. It is not that hard. It takes awhile but for $350 hell thats another part you could buy.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 02-07-2015, 02:43 PM   #10
Wow that's a ton! My local shop is charging 200 for stripes and labor
kaveh14GT is offline   Reply With Quote
Old 02-07-2015, 04:40 PM   #11
BigJay's Avatar
Sheet, for 600 you could have them painted on.
BigJay is offline   Reply With Quote
Old 02-07-2015, 05:05 PM   #12
Exactly.
Old 02-07-2015, 05:18 PM   #13
Waylap1's Avatar
Region: New Hampshire
Apparently it is though. I called my body shop, the only one for 100 miles around and they were asked by the Chevy dealer to do a couple Camaros. They no longer even attempt it after f'ing up a couple SS.
If a body shop staff (even a crappy one) won't do them, I sure as heck am not going to screw up my own car with zero experience.
Waylap1 is offline   Reply With Quote
Old 02-07-2015, 05:19 PM   #14
Are you near Fredericksburg ? If so look up laidnotsprayed vinyl workz he does good work and very good prices
Old 02-07-2015, 05:38 PM   #15
That's VA right? I'm in Colorado springs.
Old 02-07-2015, 06:45 PM   #16
TommyV's Avatar
When they are put on correctly, it's a tedious job. Measuring, unbolting stuff to get wrapped under, etc. You can tell the difference between a good job and "less expensive one."
'13 5.0 PW Premium / E-Force Supercharger w/ Brenspeed tune / FRPP Recaro's / GT500 quad exhaust / DSS Aluminum / Stop Tech 6P 15" / 13" rears / LP over axels / MGW / Moroso separator / 3:73's / Forgestar F14's 20x9/20x11 w/ Nitto Invo's 275/35's & 315/35's / Steeda Sport springs / Koni STR.T's / Steeda PHB / GT500 Spoiler / Roush upper and lower grills / Stillen front splitter / Boss steering wheel
TommyV is offline   Reply With Quote
Old 02-07-2015, 06:47 PM   #17
I was thinking that as well. It better be a damn great job for that price.
Old 02-08-2015, 11:00 AM   #18
ch0wd0g's Avatar
You should really consider doing it yourself if you have the patience. Went to YouTube and you can see it is not hard. Just a little soap and water and time. Did it myself on my '98.
ch0wd0g is offline   Reply With Quote
Old 02-08-2015, 11:07 AM   #19
If you have a good "Window Tint Shop" in your area.
Find a reputable window tint shop to install your stripes.
They probably won't charge near as much and do a better job.
Old 02-08-2015, 11:36 AM   #20
KryptonKnight's Avatar
Stripes
I started off new with Ford Racing vinyl professionally done by dealer, lasted two years and finally pulled it off and had it painted and never looked back.
Begin with how long do you anticipate keeping the ride?
Short term vinyl is OK and costs less plus when it gets mess up it can be pulled off no harm except for the $.
Long term advantages of painted made it my choice: beautiful, done the right way, custom to your preferences-color,width, placement, style, easier to maintain (clean and wax) and more durable, sets you apart from everyone else including the 500's, not to mention resale value. Just my 2 c's.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Old 02-08-2015, 11:43 AM   #21
At least two years. Maybe longer because when I deploy the car will be in my garage for 9+ months. No elements touching it at all.
Old 02-08-2015, 11:53 AM   #22
Another question concerning choice of mods. Keep in mind that external mods are enjoyed every time the ride is seen even when not moving. Performance mods are internal, unseen, and enjoyed by you when driving wild or on the track. Purpose is a good guide to get where you really want to be. I for one, want to see and enjoy the results of my hard earned every day. But I realize there is a good reason why there is chocolate and vanilla.
Old 02-08-2015, 12:05 PM   #23
ch0wd0g's Avatar
Yes, I bought about paint but had already dropped quite a wad rebuilding mine. Someday though.
1998 GT that rebuilt from salvage.
2015 GT 50th Anniversary Edition.
Old 02-08-2015, 12:45 PM   #24
I feel the same way you do.
Old 02-08-2015, 08:17 PM   #25
TommyV's Avatar
Wow Krypton, 17 posts in eight years. You are a man of few words.
Old 02-09-2015, 08:20 AM   #26
WOW a big surprise for me too. I am a member of the Mustang Club of Maryland and post there but I have never really left S197. I just don't think I have much to offer. P.S. I am really glad that it did not go away for good.
Adding LED light strips geepoons 2011-2014 V6 Mustang 37 09-27-2015 08:49 PM
It takes lot of strenght the put the car into gears Red_venom_01 SVT Mustang 8 05-25-2013 01:07 PM
Strips removed and spoiler delete BaSohol 2005-2010 Mustang GT 19 03-26-2012 11:54 AM
Drag Strips in my area?? petrey10 Pre-2005 V6 Mustang 6 07-07-2005 10:26 AM
02:41 PM
