Brake fluid upgrade - Mustang Evolution
Old 02-08-2015, 04:22 PM   #1
Redonblackpony's Avatar
Brake fluid upgrade
I currently have dot 3 brake fluid and will soon be upgrading to motul 600. My question is how much brake fluid do I need to purchase to properly change fluid and bleed the brakes.
Redonblackpony is offline   Reply With Quote
Old 02-08-2015, 05:53 PM   #2
20bmr14's Avatar
I think I used pint and a half-2 pints.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 02-08-2015, 06:59 PM   #3
BigJay's Avatar
3 to be safe. Get rid of remainder within a short time. Like if you have a track event soon like a week or two use it to bleed after event. If you just street drive the car there are other fluids that are quite good with a better price tag.
BigJay is offline   Reply With Quote
Old 02-08-2015, 07:59 PM   #4
I found the motul 600 on several websites for $14 a container (500ml). Three containers sounds about right.
I will to bleed the brakes myself with the one-man operation. I've watched several YouTube videos and they seem very helpful. The process seems quite easy.
Has anyone else bled their own brakes with the one man operation??
Any advise?
Old 02-08-2015, 08:02 PM   #5
BigJay's Avatar
The motive power bleeder with the aluminium cap for the master cylinder 70 bucks shipped jegs
Motorcraft Transmission Fluid or Royal Purple Fluid 2011 Kona Blue General Mustang Discussion 7 10-15-2013 09:38 PM
What Brake Fluid do you use? 99ford General Mustang Discussion 1 06-27-2011 09:34 AM
Smell diff fluid or tranny fluid when I get on it? ajpturbo 1996-2004 Mustang GT 0 06-19-2010 09:26 AM
Still dripping some brake fluid WhiteStang99 Pre-2005 V6 Mustang 19 06-21-2005 07:00 PM
Getting brake fluid on... MonteCitan The Bar 8 03-26-2005 09:50 PM
08:50 AM
