First oil change - Mustang Evolution
Old 02-09-2015, 01:42 PM   #1
Region: Nebraska
First oil change
Received first free oil and filter change at dealership.Had them put in 7 qts of Motorcraft synthetic blend oil and 1 qt of Mobil 1 full synthetic with 2 oz of Lucas break in oil additive. The engine is a little quieter an there is NO engine " tick" sound at all. I hope I have found a way to prevent that tick sound from occurring. I have a 2014 5.0 gt.
The Grey Ghost is offline   Reply With Quote
Old 02-09-2015, 01:51 PM   #2
oxford5pointoh's Avatar
In pretty sure you are supposed to run full synthetic in these motors. Correct me if I'm wrong here. I am surprised the dealer would even do that for you.
Just enjoying my 420 HP daily driver
Old 02-09-2015, 02:01 PM   #3
Grabber Blue5.0's Avatar
Not true.
Old 02-09-2015, 02:09 PM   #4
BigJay's Avatar
Yeah, the 5/20 factory cars are a blend the 5/50 are synthetics. You can go either way and in between on weights. Not sure on the concoction to prevent tic. I have run 0w 40 mobil 1 since my first change at 2500 miles no tics.
BigJay is offline   Reply With Quote
Old 02-09-2015, 02:19 PM   #5
Wow. Well my manual says full syn only recommended . At least I thought that's what I had read. I changed mine with the new amsoil made especially for our cars. No noise.
Name:   ImageUploadedByMustang Evolution1423516777.710165.jpg
Old 02-09-2015, 02:35 PM   #6
The track pack cars that call for 5W-50 require full synthetic possibly?
Old 02-09-2015, 02:47 PM   #7
I may have read it wrong. I guess I just thought I had read it. Dunno. Good to know, but I will prob stick with my amsoil full synthetic
Old 02-09-2015, 03:43 PM   #8
BigJay's Avatar
Not from what I have read. On the cap should have the specs your oil should meet. As for weights that is your choice based on application and research. For instance the same car across the pond is filled with 5/30 as there are no cafe requirements. I don't have the specs off hand.
Old 02-09-2015, 04:09 PM   #9
I didn't think so but I've been wrong before. I was pretty sure Ford called for a blend in all cars.
Old 02-09-2015, 04:54 PM   #10
BigJay's Avatar
The 5 50 is full synthetic and is standard fill track pack and boss. I've seen used oil analysis on that oil and it shears down quickly to a 30 weight. The reason they did the 5 / 50 was application they know those cars were more likely going to see more extreme conditions. When they had the oil formulated they must have known that it would shear quickly and quite frankly leaves me wondering why? I have seen used oil analysis on high grade synthetic 5 / 50 and it created some issues with high oil pressure on multiple cars and tripping the bypass. The oil showed signs of more wear too. 40 weight seems to be more happy oil pressure wise and wear wise for extreme conditions. 30 weight is a great middle of the road. The blend motorcraft 5 / 20 is actually a really good oil that has good used oil analysis at 10k miles. It doesn't shear much and when ford had it formulated for stringent US cafe standards they knew it had to be robust being a 20 weight. Not the best choice for extreme stuff though.
Old 02-09-2015, 10:04 PM   #11
Region: Nevada
Attachment 175099
When did they come out with 5-50. Damn it I just put in 5-30
Lvsmc14 is offline   Reply With Quote
Old 02-10-2015, 05:05 PM   #12
I run Motorcraft 5W-20 blend and have no tick and I have 11,200 miles on the car.
Wayne
2014 GT/automatic/Sterling Gray Metallic/GT500AB/GT500 OTA pipes/Bob's oil catch can/Ford aluminum finned diff cover. Ford STB.
70monte is offline   Reply With Quote
Old 02-10-2015, 08:27 PM   #13
Last month! I was excited when I saw it.
Old 02-10-2015, 08:33 PM   #14
Got this in the mail since I am an amsoil preferred customer.
Name:	ImageUploadedByMustang Evolution1423625577.566486.jpg
Old 02-10-2015, 09:46 PM   #15
BigJay's Avatar
you know I am quite curious how this oil will work in the mustang coyote. I have seen other top tier synthetics like redline 5/50 that created high oil pressure problems. Do you have an oil pressure gauge in your car?
Old 02-10-2015, 10:12 PM   #16
BigJay's Avatar
Here is a good thread on the new 5/50
Amsoil Signature Series 5W-50 meets Ford WSS-M2C931-C recommendation
Old 02-10-2015, 11:11 PM   #17
I don't have an oil pressure gauge in my car but I can hook up my kiwi wifi tomorrow and see where it's at.
Old 02-11-2015, 07:21 AM   #18
Region: Nebraska
kiwi wifi. -- what is that?
The manual I have lists a part number for the oil recomended. Check your manual for that number. The person at parts department at your dealer could tell you what it is.I see that the blue guy had the best info on his post. I also have seen oil analisys info from 2 different labs and their info caused me to do what I did with the oil on the first change.
Old 02-11-2015, 07:39 AM   #19
Region: Nebraska
Correction
Sorry -- I meant " BIG JAY"when I wrote blue guy on the oil analysis info he posted. He was right, according to what I found out from more than two sources.There are a few parameters to consider in your oil choice, as you are aware of,I am sure.
Old 02-11-2015, 08:16 AM   #20
BigJay's Avatar
Let's keep in mind ford does not require they recommend and as long as your oil meets the same specs you are okay. In the tread I linked above it does go into detail about the high oil pressure the 5/50 creates and is only advised in extreme conditions when these motors push the upper limits of cooling capabilities. Motorcraft 5/50 shears to a light 40 weight in 1500 miles and down to 30 under 5000. 5/50 amzoil is overkill for any street driven car.
Old 02-11-2015, 10:53 AM   #21
^ I will take overkill on my oil any day.
Old 02-11-2015, 02:13 PM   #22
BigJay's Avatar
Follow the link and start reading. Overkill is not a good thing poor choice of words on my part. Contact the amzoil rep in that thread if you have questions
Old 02-24-2015, 03:30 PM   #23
Region: Wyoming
You guys do know that there's only one plant that makes synthetic oil. The only difference is the label on the bottle. So you can pay more for a specific brand but it all comes from the same batch.
Dr RC is offline   Reply With Quote
Old 02-24-2015, 04:08 PM   #24
Seanp94's Avatar
[QUOTE=Dr RC;2179975]You guys do know that there's only one plant that makes synthetic oil. The only difference is the label on the bottle. So you can pay more for a specific brand but it all comes from the same batch.
Sent from my iPad using Mustang Evolution[/
Do you have a real source that says this?
Iv worked for an oil company and have been to where they manufacture their oil.
Seanp94 is offline   Reply With Quote
Old 02-24-2015, 05:14 PM   #25
Wonderful first post and so far from the truth.
Old 02-24-2015, 05:18 PM   #26
Noodles76's Avatar
Lol
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 02-25-2015, 07:17 AM   #27
Region: Wyoming
OH yes... all you great car experts. Check the patent on synthetic motor oil bottles and then bar codes for the batch numbers. The patent is held by one company, the bar code batch numbers all trace back to the one plant, and yes I've worked for the company where it's made and then trucked to other companies to be put in a bottle, labeled and distributed. And don't worry, I won't post anything again. As a petroleum AND chemical engineer with 30 years of experience in the synthetic oil industry, I guess I don't know anything that would be of value.
Old 02-25-2015, 08:01 AM   #28
Waylap1's Avatar
Region: New Hampshire
Is there some conspiracy at Ford? I mean...who do they think they are, trying to tell me to run 5w20 Motorcraft synthetic blend and a Motorcraft filter?
I don't trust a Ford engineer. There must be some reason they're not telling us the truth about how what you really need is some purple oil or Amway oil triple dog super secret double synthetic. 5WD55 , -20w50 etc.
Ok, yes...I'm a hypocrit slightly here... I do run full synthetic 5W20, but only because it may last a tad longer should I have a memory lapse and not change it sooner than I like to...about 5k miles.
The rest of you guys losing sleep over oil types? Holy crap.
I would be more concerned about sending in my own stool sample for analysis for my own health than pondering Fords recommendation on maintaining their own product.
Waylap1 is offline   Reply With Quote
Old 02-25-2015, 08:19 AM   #29
Strange Mud's Avatar
A quick Google search of "synthetic oil manufactures" shows lots of companies that claim to make it.
just sayin...
Old 02-25-2015, 12:33 PM   #30
Waylap1's Avatar
If my company buys it in bulk and then let's says adds something to it, like a drop of red bull or purple dye, then I can claim to have formulated my synth oil and sell it for the premium price it rightfully deserves.
I'm a pretty big car enthusiast and one of my bucket list items would be to tour a Amway, Mobil 1, Redline, etc oil refinery.
Can't find one yet.
Old 02-25-2015, 12:57 PM   #31
and for clarity I tend to buy whatever full synthetic is on sale. Note this is a V6 (5-20) back on helpful I advocate pulling the fuel pump relay/fuse after changing oil to let the car crank for 2 ten sec cycles under the theory it primes the system. idk if it helps but it's easy and cheap like a good date.
Smell oil burning thru interior air vents after oil change dentman43 2011-2014 Mustang GT 7 10-27-2014 08:36 AM
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
First oil change Schreiberesq 2011-2014 V6 Mustang 1 09-04-2012 02:56 PM
first oil change white pony 2011-2014 V6 Mustang 19 07-06-2012 11:40 AM
First Oil Change! NeedSomeMods Pre-2005 V6 Mustang 12 09-12-2009 12:05 AM
12:24 PM
