2013 rear suspension advice - Mustang Evolution
Old 02-10-2015, 10:32 PM   #1
Looking for advice on improving my 60ft via rear suspension updates/adjustments. The car is not a daily.
My questions are; Should the lower control arm relocation brackets be installed on a car that is not lowered? I do have the adjustable upper control arm with upper chassis mnt from Steeda (currently in the lower most hole). I also have the lower control arms running ET streets. What kind of improvements in 60ft times have you seen with each possible control arm position?
Should the front sway bar be removed? Did you change struts?
Can you recommend a starting point. Meaning pinion angle with upper control arm position/length. And if needed lower control arm position.
spawneng is offline   Reply With Quote
Old 02-11-2015, 01:04 AM   #2
WhiteCali5oh's Avatar
Region: West Virgina
Grabberblue should chime in at some point. He is smart on this stuff
WhiteCali5oh is offline   Reply With Quote
2013 GT Racing Stripes Rear Wing Advice... Fritzep Mustang Paint, Appearance & Detailing 4 08-07-2014 02:42 PM
Guys need suspension advice. 99saleen87 Saleen & SMS Mustang 5 04-15-2011 08:20 AM
Need advice on upgrading mach1 suspension jranaudo 1996-2004 Mustang GT 9 03-09-2010 01:56 AM
suspension options...need advice jmp782 Pre-2005 V6 Mustang 2 10-12-2008 04:12 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 07:07 PM
03:04 PM
