Engine Knocking and Smoking - Mustang Evolution
Old 02-16-2015, 10:26 PM   #1
silvrbullet2012's Avatar
So awhile back my 14 mustang started to "poof" smoke at start up. Didn't think much of it since it was very cold outside. Then started more and a burning smell appeared whiteout being hard on it. I started to worry a little more then it started to have a knock! Sounds like lifter clatter rear passenger side engine. I only have muffler deletes with 13k miles. And no I don't rag out my car.
It's been about a week since I left it at the dealer so in the morning I'm going to go check on the process of it. They already gave me trouble attempting to blame me for abusing the car cuz it's a mustang. Do I get on it, yes I do, do I abuse it. No I don't. End rant....
silvrbullet2012 is offline   Reply With Quote
Old 02-16-2015, 10:39 PM   #2
natestang07's Avatar
Did you check oil levels? To me it sounds like it is burning oil and maybe has a leak in a gasket domewhere
Old 02-16-2015, 10:43 PM   #3
5.Ohboy's Avatar
Region: New Hampshire
Did you put an oil separater on it?
Sent from my SCH-I535 using Mustang Evolution mobile app
5.Ohboy is offline   Reply With Quote
Old 02-16-2015, 11:34 PM   #4
I've had one on it the day I bought it actually. Been catching a lot of oil from it.
Oil levels were normal when I checked. Plus it sounded like it had a misfire after warm up.
Old 02-16-2015, 11:46 PM   #5
If they don't fix it and you are in warranty escalate it up the chain
Old 02-17-2015, 04:59 PM   #6
Ok. Small update. Contacted the dealership and asked for a update. What the tech found was metal shavings in the intake. So now it's going to be a complete Engine teardown.
Old 02-17-2015, 05:57 PM   #7
olerodder's Avatar
Region: Oregon
You mean in the block valley or intake manifold.
Old 02-17-2015, 06:02 PM   #8
Pretty sure it's the intake manifold. I was at work when they called. So couldn't really talk.
Old 02-19-2015, 02:12 PM   #9
5.Ohboy's Avatar
That's very unusual, you should be out of the break in period. As far as the miss fire I had those once, Ford actually issued a service announcement and created a retune. You car being a 2014 shouldn't be included but it depends when it was built.
Old 02-19-2015, 02:38 PM   #10
This is all new for me. And I checked different forums about this problem but seems like I'm the only case. Planning on getting another call tomarrow on the status of it.
Smoking engine bay Zhim 2005-2010 V6 Mustang 11 01-29-2014 09:03 AM
95 mustang 3.8L V6 engine knocking 95mustang Pre-2005 V6 Mustang 3 01-21-2011 02:20 PM
Engine Knocking NotoriousSPG Pre-2005 V6 Mustang 10 07-08-2010 04:42 PM
Engine knocking sound (video inside) Brent Pre-2005 V6 Mustang 19 12-02-2004 11:32 PM
Knocking engine Black Panther Pre-2005 V6 Mustang 25 11-02-2004 06:57 PM
02:59 AM
