2014 5.0 front end clunk - Mustang Evolution
Old 02-18-2015, 08:58 PM   #1
so i installed bilstein struts and eibach lowering springs and now i have a front end clunk when ever i go over bumps in the road or wiggle the steering wheel left to right any one ever experience this issue ?
val916 is offline   Reply With Quote
Old 02-19-2015, 03:53 AM   #2
Grabber Blue5.0's Avatar
It's probably the strut mounts.
Old 02-19-2015, 04:41 AM   #3
Teebone's Avatar
Did you install the parts or did you have them installed? Reason I ask is the stock caster camber plates come apart real easy and ball bearings get lost. Its almost a must to replace them with at least the GT500 plates. A few missing bearings will cause this problem every time.
Teebone is offline   Reply With Quote
Old 02-19-2015, 07:20 AM   #4
The caster camber plates are at the top where the strut mounts up?
Old 02-19-2015, 07:43 AM   #5
You don't have caster camber plates but rather strut mounts. And yes they're on top of the struts.
Old 02-19-2015, 07:56 AM   #6
I'll look into that today thanks
Old 02-19-2015, 08:50 AM   #7
Would I be able to see that the mounts are bad once I pull the struts out?
Old 02-19-2015, 08:57 AM   #8
The stock ones are junk from the factory lol.
Old 02-19-2015, 11:35 AM   #9
olerodder's Avatar
Region: Oregon
I've got the same issue, but I didn't change struts, they are stock TrakPak struts. I also used Eibach springs and the noise is coming from the drivers side which had the strut mount that didn't fall apart.
Unless you disassemble the strut/spring/strut mount you won't be able to tell anything..........even then it may look normal. Ford says not to reuse them...........when you change either the spring or strut you should replace the mount. Grabber Blue5.0 hit the nail on the head saying they aren't worth much, and especially once you lower the car.
Old 02-19-2015, 12:03 PM   #10
Which is why I constantly preach changing them out for the GT500 ones if you're also changing out the struts. Cheap, effective, and you can gain back the camber you lost when installing them with the arrows pointing in.
Old 02-19-2015, 12:29 PM   #11
olerodder's Avatar
Region: Oregon
When I changed springs I did loose some camber but still stayed at the Ford minimum spec of -1.5 degrees on both sides. What I lost in camber I gained in caster........which isn't all the bad if you like carve corners. I went from +6.4 degrees to +7.8 degrees, which is at the maximum high side of Ford's spec.
So on camber I'm at the Ford minimum spec and caster I'm at the Ford maximum spec. On high speed corners it does handle slightly better....taking a 50mph corner at 100mph it does feel a little more planted.
Old 02-19-2015, 02:29 PM   #12
Teebone's Avatar
Just wondering how you gain back the camber with the GT500 mounts alone. Do they have built in offset ? I thought I read where they were a little taller that stock.
Old 02-19-2015, 08:40 PM   #13
I'm thinking of just getting camber and caster plates
Front end Clunk/Noise 08Mustang 2005-2010 V6 Mustang 5 01-17-2015 12:39 PM
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
Constant clunk in front end suspension Mikeyt03 2011-2014 Mustang GT 28 01-20-2013 02:42 PM
Rear end clunk Brad.krieg SVT Mustang 3 12-08-2011 12:05 AM
02:29 PM
