Poly bushing replacement in PH bar and sway bar rear - Mustang Evolution
Old 02-21-2015, 12:38 PM   #1
Sway bar, Panhard. Energy Susp kits for both...BBP car.
Always fun getting the rubber parts out from links and arms...hello blowtorch....
Anyway, kinda finished the job in small bits, panhard first because it is a more critical link in the suspension than the sway bar and I dd the car.
Previously, I had installed tubular poly LCAs and a rubber Roush upper. even with that, the car's body had a tendency to try to out-accelerate the rear end when heavy applications of throttle were used out of a turn and this could snatch the rear tires right off the road and made an planned rotation of the rear out of a turn unpredictable.
The panhard was a surprisingly heavy duty bit of kit for a factory piece, easily the equivalent of any aftermarket non-adjustable, once you get rid of the rubber. The only reason to buy another PH bar is if you want adjustability, other wise, just do the bushes like I did. It's a 1/4 of the price of a non adjustable bar and has the same effect.
Since the install, the rear is tracking better, accepts power more predictable and rolls in the back a touch less, from the stiffening of the rear 24 mm bar's action.
I recommend doing this. Cheap, highly effective.
A bit of a pain in the *** but, not a big technical problem, just messy. You'll want a deadblow hammer, a press or a good bench vise to get the bushings in. I found the simple deadblow with the bushing on the floor and hit the link, to be highly effective. Getting the links around the curves in the bar a bit tough. A slathered motorcycle fork oil on the bar to make this easier, as it won't degrade rubber or poly parts, cleaned it off with brake clean and lubed the contact points with silicone brake grease provided with the bushings.
Poly, Rod, or Poly/Rod panhard bar? Mustang Coyote 2011-2014 Mustang GT 2 12-19-2014 11:03 AM
Bushing replacement for stock sway bars mmike87 2011-2014 Mustang GT 4 02-24-2013 08:51 AM
Poly rear axle housing bushing 04machazblue 1979-1995 Mustang GT 8 01-11-2012 10:12 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
Sway bar bushing size Foxone General Mustang Discussion 1 11-13-2009 10:43 AM
04:45 AM
