Ques: 2013/2014 LED fog light on 2012 - Mustang Evolution
Old 02-23-2015, 09:15 AM   #1
Dear, I just wanted to ask if anyone know or did install the 2013/2014 OEM (Upper) GRILLE LED Fog lights on the 2012 Mustang GT and if they do fit, are they plug and play or I need some harness to do that ?
I don't want any after markets solution I do want the OEM one on the 2013/2014 mustangs.
Regards,
abadi_1989 is offline   Reply With Quote
Old 02-24-2015, 04:45 AM   #2
Waiting....
Old 02-24-2015, 08:43 AM   #3
bazinga11's Avatar
You can't fit 13-14 LED fogs on 10-12 models. Grill housings for fogs on these generations are different.
However, if you're set on doing this swap it can be done. Gotta upgrade your hood and front bumper to 13-14 so that you can use the grill designed to retain led fogs
Old 03-21-2015, 03:25 AM   #4
Thank man !
Old 03-21-2015, 03:40 AM   #5
You need a swap harness from retrofit source or someplace similar for h10 to led bulbs. Then you will need to mount the fogs on custom made brackets behind the grille and shave off a little bit of the heat sinks on the LEDs to clear the core support. Takes some work but well worth it because the 13-14 LEDs alone are brighter than both the headlights and fogs on a 10-12
Old 03-21-2015, 03:51 AM   #6
yes, i do belive i saw a harness somewhere that convert the upper grill lights for the h10 mustang to the LED fog lights on the GT, i was thinking of doing that just wasent sure about the grill fog light fitment before i read your post, will give it a try soon and will share the result in the forum,
just will buy a 2 2013 upper grill fog lights from ebay and the harness and will test them
Thank you & Regards
2013-2014 Roush Fog Light Kit Coyote2820 2011-2014 Mustang GT 1 05-12-2015 04:06 PM
For Sale: 11-14 Cat Deletes, 5.0 Plenum Cover, LED Fog Light Lenses Coyote2820 Mustang Parts for Sale and Wanted 3 03-03-2015 07:07 AM
2014 GT grill and LED fog lights on a V6 Toydos 2011-2014 V6 Mustang 17 06-03-2014 09:02 PM
Selling 2013 gt grille and LED fog light. McQueen Mustang Parts for Sale and Wanted 7 01-06-2013 06:53 AM
LED 9145 Fog Light bulbs Jeffola 2011-2014 Mustang GT 16 07-25-2012 07:32 PM
11:14 PM
