Installed Sr lowering springs - Mustang Evolution
Old 02-27-2015, 08:36 PM   #1
I installed these earlier. The rears I installed with the more compressed coils facing up. Was that the right way? I'm getting a lot of creaking from the back.
Sent from my SM-N910T using Mustang Evolution mobile app
jrdnsky59 is offline   Reply With Quote
Old 02-27-2015, 08:38 PM   #2
I'll snap more pics tomorrow so far pleased with the results.
Old 02-27-2015, 09:09 PM   #3
Sloasslx's Avatar
Looks good man
Sloasslx is offline   Reply With Quote
Old 02-27-2015, 09:14 PM   #4
2014oxstang's Avatar
Looks great. Sweet heat extractors Click image for larger version
Name:	ImageUploadedByMustang Evolution1425093258.369568.jpg
2014oxstang is offline   Reply With Quote
Old 02-27-2015, 09:23 PM   #5
Sloasslx's Avatar
I wish I would have done the Oxford white. Who knows maybe plastidip it.
Old 02-27-2015, 09:29 PM   #6
I love the OW. In a perfect world I'd get the car painted that matte grey/blue on VG's RTR spec 5 or whatever. That color is sick.
Old 02-27-2015, 09:59 PM   #7
dinobike19's Avatar
Looks good. I'll be starting mine tomorrow morning. Hey did you do it the way the video I sent you ? how did it work, any issues?
dinobike19 is offline   Reply With Quote
Old 02-27-2015, 11:32 PM   #8
Yes I did it worked out great. The whole install took 2 hours.
---------- Post added at 05:31 AM ---------- Previous post was at 05:31 AM ----------
When taking the strut bolts off make sure to hold the disc firmly. That sob flung my brother back lol.
---------- Post added at 05:32 AM ---------- Previous post was at 05:31 AM ----------
The only thing is I'm getting a creak from the back.
Old 02-27-2015, 11:33 PM   #9
dinobike19's Avatar
Good thing he didn't get hurt.
Old 02-27-2015, 11:40 PM   #10
Overall it looks nice. You feel the road a lot more.
Old 02-27-2015, 11:41 PM   #11
dinobike19's Avatar
Good to hear that's what I'm looking for. Sadly I won't be able to test mine for a month or so
Old 02-27-2015, 11:42 PM   #12
Are the rear springs installed with the more compressed coils on top or bottom. The way I installed them the numbers on the springs are upside down
Old 02-27-2015, 11:42 PM   #13
dinobike19's Avatar
Sounds like the wrong way then
Old 02-27-2015, 11:46 PM   #14
I've been trying to search and have found nothing. Can anyone verify which way they go?
Old 02-27-2015, 11:53 PM   #15
dinobike19's Avatar
Larger spaces of the spring on top. Where the spring is compressed more on the bottom. I'm 99% sure of that
Old 02-27-2015, 11:57 PM   #16
http://youtu.be/WUZODaXmkYU
---------- Post added at 05:57 AM ---------- Previous post was at 05:57 AM ----------
This guy did them the other way around?does it vary by brand of springs you go with?
Old 02-28-2015, 12:01 AM   #17
dinobike19's Avatar
Looks like I'm wrong. U'll have to take it for a drive and then tomorrow check to see if u have wear marks to find ur problem
Old 02-28-2015, 12:14 AM   #18
This guy did the tighter coils on bottom????
Installed New SR Performance lowering springs
Old 02-28-2015, 12:16 AM   #19
dinobike19's Avatar
Lol. No real straight answer I see.
Old 02-28-2015, 12:18 AM   #20
Hopefully someone can chime in.
Old 02-28-2015, 11:26 AM   #21
Strange Mud's Avatar
idk but I doubt it matters as long as both diameters are the same.
2012 V6 with suspension, shifting, stopping and sound mods.
Strange Mud is online now   Reply With Quote
Old 02-28-2015, 11:29 AM   #22
I have a feeling I put them on wrong. All these people with Sr springs and no one to chime in.
Old 02-28-2015, 11:30 AM   #23
pm the guys from AM
Old 02-28-2015, 11:32 AM   #24
I sent Will a pm
Old 02-28-2015, 02:02 PM   #25
Maybe you didn't seat the spring on the axle housing pad the right way, or you didn't line up the spring properly. It's hard to say bro. Gotta get back in there and check it out. Having it upside shouldn't cause clunking. Also, did you trim the bump stops? You're probably bottoming out on them.
Old 02-28-2015, 03:23 PM   #26
olerodder's Avatar
Region: Oregon
I assume you put the isolators back on the spring that you took off the old ones, right?
Also, although I've only used Eibach's, I thought the upper pocket was smaller than the lower pocket, and I always put them end with the letters/numbers facing towards the rear of the car and so you could read them right side up.
When you took the old ones out did you match them up with the new ones..........both springs should have looked to be in the same orientation although your lowering springs were shorter.
As for the clunking, did you torque everything to factory specs?
Old 02-28-2015, 04:36 PM   #27
I left the bump stops alone. I tightened everything with an impact gun. The Sr springs had clear isolators in the middle. And am inside of weather they are upside down or not.
Old 02-28-2015, 04:42 PM   #28
Could be the bump stops.
Old 02-28-2015, 04:46 PM   #29
I'm gonna drop it and cut the bump stops. and I'm gonna flip the springs. (Tighter coils on bottom)
Old 02-28-2015, 04:50 PM   #30
This is how rears look
Old 02-28-2015, 04:59 PM   #31
olerodder's Avatar
Region: Oregon
Ok, you need to cut the bump stops in half, this could be causing an issue....maybe.
An impact gun is not a torque wrench. On suspension parts you really should use torque settings.
I'm talking about the rubber insulators that were on the top of the spring and fit between the body and spring.....it's kind of important to get those back where they belong or you will get creaking and groaning with metal to metal.
I think you've got the springs in the right way. Don't the tops have a smaller diameter than the bottoms..........
Old 02-28-2015, 05:00 PM   #32
No there the same top and bottom. OK I'm gonna drop the rear end and inspect it. I will cut the bumpstops
Old 02-28-2015, 05:06 PM   #33
olerodder's Avatar
Region: Oregon
Look up in the upper spring pocket and make sure the insulators are between the spring and body. I assume you will check the ends of the spring to make sure they are seated in the pocket also.
Old 02-28-2015, 05:07 PM   #34
For the rears?
Old 02-28-2015, 05:11 PM   #35
This ^
The bump stops need to be cut in half. And torque everything to spec, not guess with a gun. There's a good chance everything is over torqued.
Installed New SR Performance lowering springs Kaka Mustang PQ 2011-2014 V6 Mustang 8 04-06-2013 11:56 AM
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 09:42 PM
Lowering Springs Installed Napoleon85 Pictures and Videos 15 03-23-2012 06:42 PM
Pics(Lowering Springs Installed) Reaperstang Mustang Audio & Video 13 12-21-2006 01:49 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 04:57 PM
12:56 PM
