Stop Tech rotors - Mustang Evolution
Old 02-28-2015, 06:10 PM   #1
Black302Alex's Avatar
Stop Tech rotors
Anyone running the stop tech cross drilled rotors?
I've heard mixed feed back on these and I'm unsure of whether to purchase or not!
Thanks guys!
Black302Alex is offline   Reply With Quote
Old 02-28-2015, 07:00 PM   #2
Redonblackpony's Avatar
I recently switched from the stock Brembo rotors to the stop tech slotted.
Are you using the rotors for street or racing? If for Street, the slotted and drilled are probably okay as you will never heat them up like when you're on a track.
Over a period of heat cycles from hot to cold the cross drilled have a tendency to spider crack from hard braking on the road courses during track days.
Redonblackpony is offline   Reply With Quote
Old 03-01-2015, 08:03 PM   #3
Just thought I would add this.
This is from Carbotech's Click image for larger version
Name:	ImageUploadedByMustang Evolution1425265385.025983.jpg
Old 03-02-2015, 01:01 PM   #4
jande063's Avatar
My two cents are that I have had a Wilwood slotted and drilled rotor shatter while testing a Formula SAE car a few years back. Believe me when I say that you do not want that kind of excitement in your life.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
who uses Power Stop Rotors and pads TurboCobra 1996-2004 Mustang GT 5 08-25-2014 01:08 PM
Ah!ah! Stop! Stop It!!! chips The Bar 21 09-24-2004 05:09 PM
08:51 PM
