Lowering spring install w/o impact wrench? - Mustang Evolution
Old 03-01-2015, 12:25 PM   #1
Jgrummz's Avatar
Before i start taking stuff apart to install my BMR lowering springs, does anyone know if this job is possible without an impact wrench?
Jgrummz is offline   Reply With Quote
Old 03-01-2015, 12:38 PM   #2
ncfive0's Avatar
Yes, I put springs on with regular ratchets and wrenches.
---------- Post added at 07:38 PM ---------- Previous post was at 07:38 PM ----------
I did have to use a breaker bar for some of the bolts though.
ncfive0 is offline   Reply With Quote
Old 03-01-2015, 12:39 PM   #3
oxford5pointoh's Avatar
It is. It's not as easy though. Sometimes the strut shaft will start to spin with the nut and you will have to put a wrench on the shaft in the opposite direction. Soooo much easier if you have an impact. I'd suggest borrowing one from a buddy if possible.
Old 03-01-2015, 12:48 PM   #4
Jgrummz's Avatar
Appreciate the quick responses guys! Unfortunately i dont have access to an impact so looks like im going to stop and get a breaker bar just incase and see how it goes without those handy power tools lol
Old 03-01-2015, 01:05 PM   #5
ncfive0's Avatar
If the strut shaft starts spinning, make sure to put something around it to protect it before you grab it with something.
Old 03-01-2015, 01:34 PM   #6
jande063's Avatar
The other option for the strut is to use a craftsman max access external ratchet to tighten the nut, and a conventional internal ratchet to hold the hex head on the shaft of the strut.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 03-01-2015, 02:33 PM   #7
joefez55's Avatar
This ^^
Sent from my 831C using Mustang Evolution mobile app
joefez55 is offline   Reply With Quote
Old 03-02-2015, 12:23 PM   #8
You should have a TORQUE WRENCH and make sure all is back to factory specs. That is very important to get it all tight. Ford recommends using new bolts on much of suspension.
Teak 14 is offline   Reply With Quote
Lowering spring install question GrabberBlue1993 2011-2014 V6 Mustang 41 08-24-2014 10:23 PM
Lowering spring install Adogg 1979-1995 Mustang GT 14 08-05-2014 09:48 PM
Socket size for impact wrench 2011 Kona Blue General Car Discussion 2 01-13-2014 08:03 AM
Impact wrench question matthoffman22 1979-1995 Mustang GT 12 06-16-2011 10:53 AM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 04:11 PM
09:18 PM
