Barton shifter defected? - Mustang Evolution
Old 03-01-2015, 11:25 PM   #1
mustang145.0's Avatar
i got the barton with the post 2 bracket installed it the other day and it didnt go into 1st or 2nd gear but it did go into rest of the gears, i doubled checked everything and it was all good, anyone ever experienced this?
14 GT 6M, steeda lca, uca & relocation brackets, steeda front & rear sway bars, bmr panhard, 3.73, torsen, kw coil overs
mustang145.0 is offline   Reply With Quote
Old 03-02-2015, 07:38 AM   #2
SMS Mustang 013's Avatar
Sorry to tell you this either the shift ball isn't seated right when installed or you have a defective unit. Call Barton they are quite helpful even if you got it from a different suppliers
Sent from my SM-N900V using Mustang Evolution mobile app
SMS Mustang 013 is offline   Reply With Quote
Old 03-02-2015, 08:42 AM   #3
scott_0's Avatar
just what would the shift ball have to do with his issue???? but I agree, call Dave and Barton and he'll get you squared away
Old 03-02-2015, 08:54 AM   #4
The cap that you take off the old shift ball and place on the new one. Not seated or installed will cause miss alignment
Old 03-02-2015, 08:55 AM   #5
Ball at base not the shift knob
Old 03-02-2015, 10:07 AM   #6
scott_0's Avatar
lol my bad, but that's pretty fool proof unless he forgot to transfer it over at all
Old 03-02-2015, 12:58 PM   #7
i had it transfer over ima give barton a call
Old 03-02-2015, 09:10 PM   #8
20bmr14's Avatar
I had an issue when I did not get the rubber shifter boot wrapped around the shifter properly. I took everything apart pulled the boot up and seated it properly and I was able to shift into all gears.
Roush Supercharger,Custom axleback,x-pipe,Barton short shifter with Blowfish trans bracket,Whiteline trans bushing,McCleod RXT twin disc clutch w/billet steel flywheel,Steeda braided clutch line,Steeda g-force brace,BMR cradle lockout braces and bushings,Whiteline front sway bar,SR rear sway bar,SR rear vertical links,MM camber plates,Mich Pilot SS 255/305,Roush rear spoiler and hood heat extractors,and Ford Performance hood shocks,JLT oil separator,Flossy heavy weight shift knob
20bmr14 is offline   Reply With Quote
Old 03-02-2015, 10:19 PM   #9
Great enjoy the drive
Hurst billet shifter plus two or Barton short throw shifter?? hdez41 2011-2014 Mustang GT 25 01-26-2015 09:01 PM
For Sale: FS: Barton Shifter, MBRP Axle backs, Shifter Bushing 1ststang Mustang Parts for Sale and Wanted 8 03-15-2014 06:21 PM
Barton shifter bracket with stock shifter 2011 2011 2011-2014 Mustang GT 5 03-11-2013 07:48 AM
Barton 2 Post Bracket vs Standard Barton Bracket SilverBullet12 2011-2014 Mustang GT 8 08-23-2012 09:43 AM
12:07 PM
