engine light - Mustang Evolution
Old 03-09-2015, 05:11 AM   #1
engine light
So I was driving on the interstate and I didn't notice I was in 5th gear instead of 6th until the engine light flashed at me so I immediately pulled over and turned the car off, I waited a few mins turned it back on and it was like the light never flashed in the first place the car sounds good still runs the same, I haveno gotten on it since then I'm kinda nervous, should I be concerned? Or was it just the car warning me?
dee_gt is offline   Reply With Quote
Old 03-09-2015, 05:24 AM   #2
hitmeagain's Avatar
The car should cruise happily in 5th as long as you want it to with no light. I would say there is an issue some were but a minor one that has nothing to do with what gear you were in...it'll be hard to track down until the light comes on and stays on though.
hitmeagain is offline   Reply With Quote
Old 03-09-2015, 05:27 AM   #3
utm18's Avatar
Do you have a tuner? You could pull the code up?
utm18 is offline   Reply With Quote
Old 03-09-2015, 05:28 AM   #4
Yea I guess ima go see if the computer saved a code to tell me what happened but if nothing shows up Idk
Sent from my SM-N910V using Mustang Evolution mobile app
---------- Post added at 11:28 AM ---------- Previous post was at 11:27 AM ----------
I don't have one anymore I guess ima go to auto zone and get them to pull it up for me
Old 03-09-2015, 06:35 AM   #5
KARgt13's Avatar
5th is perfectly fine to be in on the highway, 6th is just overdrive. The flashing is for a misfire. If the light isn't on it probably didn't hold the code. Mine has been known to do it when holding around 3k in 5th gear as well, rarely, but it has happened.
KARgt13 is offline   Reply With Quote
Old 03-09-2015, 06:38 AM   #6
So do I need to get something fixed or do I just leave it alone?
Old 03-09-2015, 06:46 AM   #7
And I read that a misfire damages your catalytic converter which I don't have anymore so idk
Old 03-09-2015, 06:55 AM   #8
KARgt13's Avatar
When it first happened to me the light stayed on next time I started the car so I took it to the dealer and they applied a TSB fix. Next time it happened the light didn't stay on, I still took it in and they did nothing because there was no code. Unfortunately I think you'll have the same experience if the light doesn't stay on. It's fine as long as it doesn't keep happening. Just make note of it if it happens again.
As long as it isn't happening frequently it isn't much of a big deal. While it shouldn't happen at all, it's hard to fix something the dealer refuses to acknowledge without an engine code.
Old 03-09-2015, 07:08 AM   #9
Right well thanks man I appreciate it
Old 03-09-2015, 08:13 AM   #10
Strange Mud's Avatar
+1 on relax unless it does it again and 5th/6th should not matter unless there is more to the story. I assume no tune/mods.
Old 03-09-2015, 08:19 AM   #11
Grabber Blue5.0's Avatar
So you don't have a tune anymore and also don't have cats?
Map light/dome light 99redgt 1996-2004 Mustang GT 3 01-22-2012 05:53 PM
Press O/D button or accelerator break fluid light and seat belt light blink Bgover Pre-2005 V6 Mustang 11 04-02-2011 08:52 AM
The Service Engine Light Soon light is on!! HELP! punisher0822 1996-2004 Mustang GT 11 07-15-2010 10:15 PM
Brake Light & ABS Light on. stevinas 2005-2010 Mustang GT 1 06-26-2008 02:21 PM
Green Light, Red Light Brent Pictures and Videos 11 01-24-2008 04:23 PM
03:42 PM
