Drag wheel size questions - Mustang Evolution
Old 03-09-2015, 11:05 AM   #1
Sterlingbeast5.0's Avatar
Ok, done some searching but still a little confused. Here is scenario and some Q&A if anyone can help fill in blanks. These will JUST be for when I get to track. Not even for getting to it.
I have a 2013 Mustang GT I am running 20" AMR wheels on 255 35 20 tires all around. Sportline springs with Eibach prodamper shocks and struts.
1. Do I need swaybar relocation brackets for 15" wheels or ONLY when they are 10" Wide?
2. Will 17" eliminate the need to relocate sway bar or does that depend on width also
3. I am 26.5" from ground to top of tire in rear now. I am 27.25" to start of wheel well.
4. I have been told by multiple people to run a 28" fine but this doesn't make sense to me based on measurements. Am I missing something?
5. Good site or math explanation for how to determine what to order please?
6. Will 8.5 still be ok when I get Vortech or will I really want 10" wide then?
Old 03-09-2015, 11:20 AM   #2
Grabber Blue5.0's Avatar
The only wheel that will require a sway bar relocation bracket is a 15x10 wheel. But that is the best size to go with so don't let the swar bar relocation brackets steer you.
A 28" tire is really what you want or very close to. Your measurements really have no bearing on this.
Old 03-09-2015, 01:02 PM   #3
Ya I looked into the relocation and that doesn't seem like a big deal really. I am still completely confused on the tire though. I haven't taken geometry in years, lol. But if I add 1.5" to my overall diameter it will essentially add 3/4" to the radius. With only 3/4" difference between top of current wheel and well wont I be basically but up against it and with 10" probably start rubbing paint off the well?
Old 03-09-2015, 03:25 PM   #4
You're way overthinking this. Your current setup is 27" tall which is shorter than stock. Regardless you shouldn't have any fitment issues unless you go with the wrong back spacing.
Old 03-09-2015, 03:46 PM   #5
You are way overthinking this...many have been down this road before.
Now, it does depend on what you want to run out back. You don't need a 10" wheel to fit a slick. Slicks are more forgiving of wheel width mismatches than a radial is. An 8" wheel can still easily take a 10" wide slick without problems.
You need a 28" tire only if you are running 3.73 out back and a stick. 26-ish tires will force a shift to 5th before the stripe, if your rev limit is stock.
There's plenty of room in the wheel arch for tires around this height and width, if the backspacing is correct. The fenders are pre-rolled from the factory.
Old 03-10-2015, 07:00 AM   #6
Alright, alright, lol. I tend to overthink often so I will completely believe you guys. Thanks you. I am stock gears but believe the rev limiter is off with tune. I know at track before I get to about 7200 before shift. 2 15x10 Dark Stars 2 28" MT streets and a sway relocation kit are going on the build list.
That is why I love this forum. You guys are great thank you.
Old 03-10-2015, 07:36 AM   #7
If it's just a drag tire setup I'd go full drag slick, not a compromise like the streets....
Old 03-10-2015, 08:03 AM   #8
Exactly. Because you're a manual you'll want a slick unless you plan on using it on the street.
Old 03-10-2015, 09:22 AM   #9
True, I was thinking street/strip but I will never really use it to drive there. Can just change out at track. I am looking at new tires in next 6 months for street and need stickier there too. Problem is I love to look of the 20"'s but they grip like crap
Old 03-10-2015, 10:02 AM   #10
grabber12's Avatar
Look at the SVE drag wheels before you buy dark stars.
2012 Grabber blue, Auto, Eibach pro street S coilovers, MM caster/camber plates, Borla ATAK cat back, off road X pipe, A.E.M CAI, SCT-x4 Mike Roush tune,SR LCA's, BMR Relocation brackets, J&M Pan hard bar, UPR Catch can, SVE 15x10's, Mickey T's 275-60-15.
grabber12 is offline   Reply With Quote
Old 03-10-2015, 10:51 AM   #11
The sve are great especially with stock style lug nuts. Shanks can be a pain to install
kingcobra323 is offline   Reply With Quote
Old 03-10-2015, 11:41 AM   #12
I do not know much about SVE so I will check them out. Just want a black wheel that doesnt cost an arm and a leg. I am only planning on getting the two for rear and keeping my DD front wheels on.
Old 03-10-2015, 01:06 PM   #13
Yeah sometimes they go on sale. I believe the black 15x10 are like 159 or 169 each. Latemodelrestoration.com sells them
Old 03-10-2015, 03:06 PM   #14
I drive 30 miles each way to the track on full race Hoosier slicks. I don't even air them up.
In fact, last year when I blew a regular tire, I drove on those same slicks in the snow for a week until the replacement tires came in.
So, I'd say you shouldn't compromise, definitely. Street/strip means they won't work on either.
Old 03-10-2015, 09:13 PM   #15
grabber12's Avatar
Here are my SVE wheels. 15x10
Old 03-11-2015, 06:35 AM   #16
really appreciate everyones help. Tired of not hooking up. Slicks on 15x10 it is!!
Drag radial size q Moto111 Mustang Wheels & Tires 8 07-08-2013 03:04 PM
Drag Radial size 2013fiveO 2011-2014 Mustang GT 42 05-12-2013 01:04 PM
Drag bash london drag strip in ky. This sunday 4/29/12 H.A.W.K At the Track 1 04-30-2012 01:37 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
drag tire size stang96 Mustang Wheels & Tires 4 11-05-2008 04:42 PM
05:49 AM
