Would a tune make a engine tick - Mustang Evolution
Old 03-09-2015, 04:37 PM   #1
I can't figure this bottom end tick out....temp gauge in the middle...oils clean has 93 premium in it .. only 20000 miles ..feels a lil low on power too
Jstorm is offline   Reply With Quote
Old 03-11-2015, 06:12 AM   #2
Region: West Virgina
What oil are you using? Everything I have read on this situation points to 20W-50 oil or full synthetic being a problem with the tick issue.
2014 Sterling gray GT 6M
Paxton Novi 2200, DW1000 injectors, JMS BAP, ATI damper
Lethal ORP, MGW shifter, BMR upper and lowers, Spicer 1 piece DS, Ram Single disk clutch with aluminum flywheel, Power leather seat conversion. Staggered wheels.
605 RWHP on a safe tune
scott9050 is offline   Reply With Quote
Old 03-11-2015, 06:16 AM   #3
bucko's Avatar
Full synthetic is not the cause of a ticking issue in the 5.0. Let's not start (or continue to add to) this myth.
Old 03-11-2015, 07:18 AM   #4
utm18's Avatar
If you did run 87 octane on 93 octane tune it might cause some issues.
utm18 is offline   Reply With Quote
Old 03-11-2015, 08:29 AM   #5
No might about it. It will.
Old 03-11-2015, 08:47 AM   #6
Konawin's Avatar
Try buying more 93 at a different station. Lower octane will def cause problems on a car tuned for 93
Konawin is offline   Reply With Quote
Old 03-11-2015, 10:05 AM   #7
DallasStang77's Avatar
I once knew a girl who's family owned a gas station/liquor store and they ran regular gas in all their tanks. Or was it that they mixed regular into the higher grade tanks. Can't remember. It's been 10+ years.
Old 03-11-2015, 10:26 AM   #8
c_rizzle's Avatar
Yeah, well I knew someone who worked at a small gas station & they only had 2 tank reservoirs.
I believe from back when they used to only have 2 types of gas (like unleaded & leaded) Point is, they didn't have room to upgrade / add a 3rd tank. And they could not sell lower octane than quote b/c if someone came out & tested their gas & they failed they would be in trouble.
They had to have premium (93) for the premium pump.
And I don't remember which, but one of the other pumps you got a free upgrade.
It was either:
93 & 89 pumps both got 93, with 87 pump getting 87 <-- think
OR
89 & 87 pumps both got 89 octane, with 93 pumps getting 93
c_rizzle is offline   Reply With Quote
the infamous engine tick FullyAutomatic 1996-2004 Mustang GT 15 05-24-2014 09:19 PM
who on here is living with engine tick Mustangman705 1979-1995 Mustang GT 5 10-01-2013 12:55 PM
update engine tick Mustangman705 1996-2004 Mustang GT 1 09-26-2013 09:59 AM
TICK TICK TICK Mustangman705 1996-2004 Mustang GT 13 09-21-2013 06:30 AM
Tick when engine is cold Mikeyt03 2011-2014 Mustang GT 24 11-08-2012 05:59 PM
12:11 PM
