Problem after Paxton install. - Mustang Evolution
Old 03-11-2015, 03:45 PM   #1
rockhillgt's Avatar
Ok, since installing my Paxton, the car jerks as I am accelerating in just daily driving. I thought it was my belt slipping since It was loose. I moved the pulley over and now the belt is tight but it is still doing it. When the car was on the dyno, it couldn't make boost. The dyno guy said he thinks it was because the bypass valve was hanging open and not closing to generate the boost. It was hanging around 3 lbs of boost and wouldn't go up. It did make it like 2 times out of the 7 that he ran and the results were good. He said the bypass valve may be faulty. I'm not sure if this would have anything to do with it but I wouldn't think so since I am accelerating normally and shifting around 3k rpms. If anyone can offer some help it would be much appreciated.
rockhillgt is offline   Reply With Quote
Old 03-11-2015, 03:56 PM   #2
Ammermeow's Avatar
Check all intercooler connections sounds like you blew off a hose.
Sent from my SCH-I535 using Mustang Evolution mobile app
2012 GT Brembo M6, BBK CAI, Dynomax axleback, Bama tuned, UPR UCA & mount, Hotchkis LCA/panhard bar/adjustable swaybars, Whiteline relocation brackets, Barton shifter & bracket, Eibach ProKit Springs.
Ammermeow is offline   Reply With Quote
Old 03-11-2015, 06:46 PM   #3
Famine's Avatar
Region: South Dakota
Check all pipes and vac lines. Easy place to start. A significant leak like that shouldn't require a boost leak tester.
Famine is offline   Reply With Quote
Old 03-12-2015, 07:42 AM   #4
Deerslayer's Avatar
If your boost gauge only reads 3psi, you do have a significant leak. It could be either the BOV hanging open or a charge pipe not connected. Have you clocked your MAF sensor? (orientation) What BOV are you running? I have a brand new never used or installed MaxFlo Race BOV. I bought it and a Tial and installed the Tial and liked it so never installed it. I can make you a heck of deal on it. It is a significant upgrade to the stock BOV
2013 GT : 6sp MT, Track Pkg, 3.73 Rear End, Brembo Brakes, Vortech V3 SC, Boss IM, BBK 90mm TB, JLT CAI, ID1000 injectors, BAP, Brisk Plugs, Tial BOV, Lethal OR X Pipe, 3" over axle to GT500 Quad Exhaust, Dynotech Alum DS, MGW Shifter, Eibach R2 Coil Overs, Bob's Billet LCA's, UPR adj. UCA, Eibach Adj PH Bar, TruCarbon Carbon Fiber inside/out. Tuned by Jon Lund II Three salvaged Bosses worth of Parts live on in this car. 705.11rwhp 5.33pulley/Torque Booster Wastegate
Deerslayer is offline   Reply With Quote
Old 03-12-2015, 11:47 AM   #5
rockhillgt's Avatar
i am just running the stock bypass valve. I went over the pipes and they were all hooked up tight. I have not clocked the maf sensor. not sure how to do that?? shoot me a PM on the price for that BOV to 29730
Old 03-12-2015, 11:56 AM   #6
rockhillgt's Avatar
the BPV hanging open wouldn't cause the jerking at such low rpms would it? since I wouldn't be hitting boost at that point anyway. There isn't but a couple vac lines. Only put a "T" into the one at the back and ran the line to the BPV. I will recheck those today after work
Old 03-12-2015, 01:46 PM   #7
Deerslayer's Avatar
PM sent. Take a pic looking straight down on the pipe your MAF is on.
Old 03-12-2015, 02:42 PM   #8
Deerslayer's Avatar
I am 90% sure your MAF position needs to be adjusted. If you have it at 4 or 5 o'clock, (looking straight down from the top - standing in the front of your car) it DEF needs to be moved closer to 2 o'clock. It needs to be in line with the 90 degree bend above it. It is about laminar flow. You need there to be no turbulence going over the MAF sensor or it can cause rough idle, hesitation, stall etc.
The BOV sticking open would cause loss of boost pressure. It does only need to be T'ed into the vacuum line. The BOV opens when you let off the throttle, and closes when you accelerate, controlled by vacuum pressure
Old 03-12-2015, 02:55 PM   #9
rockhillgt's Avatar
I'll look at that tonight as well. I will adjust it when I install the new BOV since i'll have to remove those tubes from the TB to get to the BPV anyway.
My Paxton Install Experience Jukens 2011-2014 Mustang GT 30 09-01-2012 04:35 PM
Lovely Dealing With Paxton gixxer007 General Car Discussion 0 03-29-2011 05:45 PM
Problem after typhoon intake manifold install. RudyJ 1996-2004 Mustang GT 11 02-12-2011 06:46 AM
Vortect or Paxton SC kit for 1979-93 Fox Body 5.0! afinley11 Mustang Parts for Sale and Wanted 0 11-13-2009 05:20 PM
01:24 PM
