Suspension setup questions - Mustang Evolution
Old 03-14-2015, 11:46 PM   #1
Whiskey Daniels's Avatar
Region: Idaho
Hey all, this is what is in my cart at AmericanMuscle right now.
Koni STR.T shocks and struts
Eibach camber bolts
SR double adjustable panhard bar
BMR non adjustable UCA
Eibach pro kit
SR rear lower control arms
I shouldn't need camber plates, I don't track this car. I just cruise around and wax the occasional camaro. Does this look like enough? or am I forgetting anything major?
Thanks for the help
Whiskey Daniels is offline   Reply With Quote
Old 03-14-2015, 11:49 PM   #2
oxford5pointoh's Avatar
If get the adjustable upper control arm. When you lower the car it changes the pinion angle. This can cause vibrations and still cause you some issues.
You might also want the lower arm relo brackets.
Old 03-14-2015, 11:56 PM   #3
Region: Idaho
So scratch the non adjustable uca and add the adjustable one. Thanks.
Old 03-14-2015, 11:57 PM   #4
Yeah I would
Old 03-15-2015, 09:37 AM   #5
olerodder's Avatar
Region: Oregon
Forget about the "camber bolt", you don't need it and they are not safe.
I've helped lower 5 late model Mustangs along with my own and non of them needed to have anything done. How do I know, all of the owners of the other lowered Mustangs had their alignment checked, as did I. The camber bolt is a total waste of time/money.
If you use the BMR UPC, also use the BMR LCA..........just doesn't make any sense to mix and match different brands.......like putting Champion spark plugs on one bank of the motor and Autolite on the other.
If you would need to adjust your pinion angle with non-adjustable LCA's and non-adjustable UPC your are screwed. Get the adjustable UPC and if you have no need to change the pinion angle set it at 0. If you have LCA's you should get an UPC to make everything solid............the stock UPC is junk and helps remote wheel hop.....IMHO
Old 03-15-2015, 11:20 AM   #6
Famine's Avatar
Region: South Dakota
All you need now is to change your shipping address under your account to my address and you're good to go
Famine is offline   Reply With Quote
Old 03-15-2015, 11:22 AM   #7
Jd431x1f's Avatar
Region: Nevada
I agree with Olerodder, the adjustable camber bolts are not worth it. I lowered my 14GT with the Steeda sport springs and it is fine. But remember when changing the front springs out, the perch is made for one-time use and the little bearings are easily lost. Then the front end will make an awful racket as the springs compress. Trust me as I am dealing with that. I will end up buying the Steeda stainless adjustable mounts when I replace my struts in the next year. I also put in the Steeda no seat delete X brace in the trunk. Very highly recommended, tightens up the back end. Tracks much better now. Just my 02ยข
Jd431x1f is offline   Reply With Quote
Old 03-15-2015, 11:46 AM   #8
Grabber Blue5.0's Avatar
Koni STR.T shocks and struts- They're okay
Eibach camber bolts- Not necessary
SR double adjustable panhard bar- BMR is a better choice
BMR non adjustable UCA- You need an adjustable and a mount
Eibach pro kit-Meh
SR rear lower control arms- BMR makes a better product
Thanks for the help
Old 03-16-2015, 07:58 AM   #9
k1DBLITZ's Avatar
You might consider a Steeda ball joint kit and bumpsteer kit depending upon how low your'e going.
Steeda Mustang X11 Ball Joint Kit 555-8136 (11-14 All) - Free Shipping
Steeda Mustang Bumpsteer Kit 555-8106 (05-14 All) - Free Shipping
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 03-18-2015, 10:26 PM   #10
DallasStang77's Avatar
Old 03-18-2015, 10:45 PM   #11
Region: Idaho
Just to update this. Between the people at AM and the guys that helped me out on here I got pointed in the right direction. I ended up with this.
Eibach sportline kit
BMR adjustable panhard bar
BMR adjustable UCA with mount
BMR rear lower control arms
Old 03-19-2015, 01:49 AM   #12
Compstall's Avatar
- Brent
'11 GT Kona Blue Brembo
"Measure with micrometers, mark with a scribe, chop with an axe"
"I'm not new to driving. I've been doing it for a couple of years now." - Aphex
Compstall is offline   Reply With Quote
Old 03-19-2015, 02:40 AM   #13
Hey Whiskey I would add LCA relocation brackets then that should do it. Then drive it LOVE it!!!
Teak 14 is offline   Reply With Quote
Old 03-19-2015, 10:27 AM   #14
k1DBLITZ's Avatar
Soooo....this is something I've been confused about.
Are LCA relocation brackets necessary if you have adjustable UCA's?
Old 03-19-2015, 10:29 AM   #15
Yep.
Old 03-19-2015, 10:41 AM   #16
2014oxstang's Avatar
What makes the adjustable UCA a necessity grabber? Curious to hear this. I have a fixed BMR w/bracket. Is it strictly for pinion angle and drive shaft clearance? And if so, the fixed one makes it impossible to install a 1 piece DS?
2014oxstang is offline   Reply With Quote
Old 03-19-2015, 12:33 PM   #17
UCA and bracket will help with wheel hop and the adjustable UCA will set the pinion angle not impossible to have one piece DS but to make everything set right should have one for sure!!!!
Old 03-19-2015, 12:49 PM   #18
Ahhhh ok. I'll have to check my pinion angle at some point. There's this cool app by Tremec that allows you to do so.
Old 03-19-2015, 01:01 PM   #19
When you lower the car the pinion angle will be off if you go 1 in. it still maybe close but I think it will be more then 2 degrees. Kelly at BMR is there Mustang guru down there.
Old 03-19-2015, 01:08 PM   #20
This video explains it perfectly in my opinion. I love how it shows the diff movement.
http://youtu.be/9TbwRZqEtxQ
Old 03-19-2015, 02:01 PM   #21
Sterlingbeast5.0's Avatar
once you swap to the ajustable UCA your good to go
Old 03-19-2015, 05:20 PM   #22
Hmmmmm...makes you wonder why BMR even makes a fixed unit?
Old 03-19-2015, 05:21 PM   #23
If your not lowered I suppose?
Old 03-19-2015, 05:25 PM   #24
Ahhh maybe.
Old 03-19-2015, 05:31 PM   #25
Well, anyone want a fixed one? Haha
Old 03-19-2015, 05:32 PM   #26
Also it will still help the wheel hop as its stronger and the bushings have less give. You just can't dial it in to get the best results. But there are some people who don't want to mess with an adjustment so they just get the non adjustable
Old 03-19-2015, 05:33 PM   #27
Haha I didn't realize you had a non adjustable.
Old 03-19-2015, 05:41 PM   #28
Yeah, for my uses, I didn't find it necessary, but now I'm kinda thinking twice lol
Name:	ImageUploadedByMustang Evolution1426808466.985801.jpg
Old 03-19-2015, 05:45 PM   #29
Having the adjustable bracket doesn't help you? Maybe you should check the pinion angle you have now and mess with the position it's mounted?
Old 03-19-2015, 06:15 PM   #30
I'm not sure, I know I'm in the correct hole for a lowered vehicle. Wheel hop was completely eliminated with it combined with the LCA's. I need to check the angle.
---------- Post added at 06:15 PM ---------- Previous post was at 06:14 PM ----------
Seems I'm one of the few with a fixed UCA lol
Old 03-19-2015, 06:42 PM   #31
dinobike19's Avatar
I hope this isn't hijacking but the OP might find this useful as well. 2 questions. With 2014 lowered, BMR adj UCA, but no mount, would that give u a clunk? whats clunking? And LCA reloc bracket, why wouldn't you want to use the bottom hole for more anti-squat?
dinobike19 is offline   Reply With Quote
Old 03-19-2015, 06:47 PM   #32
Still haven't gotten to the bottom of that clunk eh Dino? I would think it may be possible. The BMR piece with the crap oem stamped steel bracket....
Old 03-19-2015, 06:51 PM   #33
dinobike19's Avatar
Nope no fix yet. Pulling it all out this weekend and checking for wear marks etc. couldn't afford the mount sadly
Old 03-19-2015, 07:14 PM   #34
Hey man, we all have different priorities. I didn't buy the adjustable for my needs, but also because of cost. We all cut corners. I'm thinking about getting one though if my pinion angle is fubar'd. Keep me posted as to your findings. I'm curious to see what is causing this noise. Is it noticeable in cabin? Can you video?
Old 03-19-2015, 07:17 PM   #35
dinobike19's Avatar
Oh very noticeable. And I was thinking of making one. Maybe this weekend
Best drag racing suspension setup? black9D5 2005-2010 Mustang GT 1 01-07-2013 09:09 PM
Comparison of Suspension Setup TheBrandowine 2011-2014 V6 Mustang 4 11-24-2012 03:20 PM
good rear suspension setup? notstock02gt 1979-1995 Mustang GT 6 05-01-2007 06:08 PM
Solid Rear Suspension Setup Thomas91169 1996-2004 Mustang GT 16 12-27-2006 01:51 PM
best suspension setup for drag BrooksPS Pre-2005 V6 Mustang 2 03-11-2004 09:09 PM
06:56 AM
