Shifting Movement - Mustang Evolution
Old 03-19-2015, 06:44 PM   #1
Kustumb's Avatar
Shifting Movement
Not your typical shifting question.
I'm new to manuals as I've always had autos but I'm enjoying the change!
One question I have is if the shifting is supposed to have the following feel:
Clutch in
Pull it out of gear to N (1 movement)
Neutral to next gear (1 movement).
I can't seem to pull it and put into gear in one move as there is a notchy feeling pulling it out, and another notchy feeling putting it in gear.
Usually happens 1-2 and 2-3.
Not always but most of the time.
I've got the hurst 2-post shifter.
Can any one of you pull it out and put into gear in one smooth motion? Or is there always that slight pause in between?
Ideas?
Thanks!
Kustumb is offline   Reply With Quote
Old 03-19-2015, 06:54 PM   #2
dinobike19's Avatar
I'm starting to get this too. looks like im getting a race spec shifter before i thought i was
dinobike19 is offline   Reply With Quote
Old 03-19-2015, 07:24 PM   #3
There will always be a little stop at the top but, I shift with two fingers, all the time, no issues. You should not let the shifter centre between shifts, if that's what you mean. I have a few more things done: Steeda bracket, Whiteline trans bushing, Billet knob and MGW shifter arm bushing.
Now, I have been driving stick for over 30 years but this car still took a bit of larnin', no question. The remote shifter and the tight gates made necessary by 6 speeds meant a little learning curve.
Now Hurst is pretty notorious for notchiness. some like it, some don't. I loved it on the T5 in my old '88 but, I wouldn't buy it for this trans, personally.
Old 03-19-2015, 07:44 PM   #4
WJBertrand's Avatar
Every manual transmission I've ever owned had some feeling of coming out of one gear and into the next. Some are more pronounced than others but I consider this normal. I like the feedback as it confirms the lever has gone into the next gate. The 1-2 shift with the M-82 is on the stiffer end of that feedback scale, but at least my car (MGW & BlowFish equipped) feels really nice through the rest of the gears.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 03-20-2015, 10:35 AM   #5
Kustumb's Avatar
Alrighty then, thanks for the responses.
I'm thinking of the blowfish racing one as a possibly next upgrade but everyone's saying it's pretty overkill if the car isn't tracked.
I just want butter smooth shifts when I drive It hard.
Old 03-22-2015, 08:55 PM   #6
ddtmoto's Avatar
Region: Utah
I have the Hurst shifter with a Barton 2 post bracket. It is some what notchy, I like it being old school/classic look. When the transmission is hot, shifts can be hammered away in mine. But, before the trans is sufficiently warm I take it easy, I shift nice and deliberate. Have to kinda let the syncros settle and grab into the next gear change while passing thru neutral in one smooth easy pressure motion with a slight hesitation, I guess. Things are much, much better with the gear oil warmed up.
ddtmoto is offline   Reply With Quote
Old 03-22-2015, 09:35 PM   #7
Nothing will give you a butter smooth shift. Even with the mgw race spec, there is a notchy feeling going into each gear. It's a characteristic of the mt82. The smoothest shifter you'll get in this regard is the stock shifter.
I wish there was a shifter that could be stiff and hold things in place like the race spec and also have a very easy silky smooth shift like the stock shifter. It's a trade off I guess. The gear nibble ****ing pisses me off though. I've tried every shifter and it doesn't go away.
Mikeyt03 is offline   Reply With Quote
Old 03-23-2015, 03:54 PM   #8
Kustumb's Avatar
Foregoing the notchy feel for a moment, what can I expect in terms of difference in feel between Hurst 2 Post and the blowfish race spec?
Old 03-23-2015, 04:46 PM   #9
You mean the Barton two post and the mgw race spec?
Old 03-23-2015, 04:49 PM   #10
Kustumb's Avatar
Old 03-23-2015, 04:50 PM   #11
Kustumb's Avatar
Sorry I meant the plus 2 shifter.
Old 03-23-2015, 05:11 PM   #12
RACE SPEC be done with it.
Teak 14 is offline   Reply With Quote
Old 03-23-2015, 09:21 PM   #13
I disagree, I have the MGW race spec in and it was very notchy at first. Now it is not as much. It has a reassuring engagement as you actually put it into gear. Row-ing through the gears is the same, much smoother now that it's broken in vs the first couple days after install.
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
ShatterPoints is offline   Reply With Quote
Old 03-23-2015, 09:25 PM   #14
But it's still not as easy as the stock shifter. I had the race spec for about 15k miles.
Old 03-24-2015, 04:28 AM   #15
I agree with you both none are as smooth but it will fix so many other things wrong with the stock shifter. Once you go to a shorter throw they all will be a little notchy but later on OP will be getting locked out and not liking that also.
Old 03-24-2015, 07:51 AM   #16
KARgt13's Avatar
They have a street version of the blowfish bracket now that has a lot less NVH. Just FYI.
I don't have it, I just know it exists.
KARgt13 is offline   Reply With Quote
Old 03-24-2015, 11:48 AM   #17
Mikeyt03, you drove with the race spec for 15k miles? It just came out in November!
ads245 is offline   Reply With Quote
Old 03-24-2015, 02:50 PM   #18
k1DBLITZ's Avatar
I have a blowfish bracket and am extremely happy with it.
I'm using the stock shifter though...a lot of the complaints about increased NVH came from people using an aftermarket shifter.
I tried the Barton Two Post first.. and didn't really notice much improvement in shifting, but I DID notice an increase in NVH.
Moving from the Barton to the Blowfish, my NVH actually went away.
With that being said, that MGW race spec looks impressive.
2014 Mustang GT Premium (deep impact blue)
Too many mods to fit in my sig.
Follow my build list on my blog. (still updating mods installed so far)
k1DBLITZ is offline   Reply With Quote
Old 03-24-2015, 02:53 PM   #19
I'm using the stock shifter though...a lot of the complaints about increased NVH cane from user without aftermarket shifter.
I've got the newer mgw race spec in and its wonderful. Slightly more nvh but you'd have to drive around with your hand on the shift knob 100% of the time to really notice. I can't recommend the mgw enough it is perfect.
Sent from my SM-N900T using Mustang Evolution mobile app
2012 GT (Brembo)
MGW Race spec
Steeda Sports
Koni STR's
Air Raid CAI
Borla axlebacks
Old 03-24-2015, 09:02 PM   #20
That was supposed to be a 5 not 15.
Power Shifting vs Quick Shifting BlueDemon 2011-2014 Mustang GT 10 06-02-2016 10:50 AM
Strange Movement Dogbitdude Pre-2005 V6 Mustang 4 10-11-2012 09:57 AM
Should I support CIA sponsored Tibetan exiles's Olympic boycott movement ? christophe The Bar 5 04-01-2010 04:12 PM
Shifting feel KyleUSAF Pre-2005 V6 Mustang 6 02-15-2005 11:28 AM
Shifting on Automatic megax29 Pre-2005 V6 Mustang 52 07-15-2004 12:14 PM
10:16 PM
