BMR LCA holes don't align?? - Mustang Evolution
Old 03-19-2015, 06:01 PM   #1
Jvibe92's Avatar
Im having issues finishing some installs. The picture should tell it all. My cars still on jack stands until I figure out what I should do. Is this common for the passenger side rear LCAS? Click image for larger version
Name:	ImageUploadedByMustang Evolution1426809662.872690.jpg
Jvibe92 is offline   Reply With Quote
Old 03-19-2015, 06:07 PM   #2
Umm, just pry bar the rear end until they do align and ram the bolt in.
Old 03-19-2015, 06:08 PM   #3
Jvibe92's Avatar
I figured but didn't want to pry it in and damage the bushing if it wasn't meant to fit. The drivers side went in perfectly
Old 03-19-2015, 06:09 PM   #4
oxford5pointoh's Avatar
If you have a large screw driver or a hole punch you can't get it in the hole and pry it into place?
When I did body work we had a tool for things like this, it's basically a bigger looking punch tool. But once you align it then you start the bolt from the other side.
I would imagine the rear end placement needed to move anyway. Right?
Old 03-19-2015, 06:13 PM   #5
It's just crowbar city. You don't need to stick anything in the hole. Gently pry against the body work and it'll be fine. You're totally overthinking this; it really is as simple as it looks. The job is made easier if you just take off one side at a time.
Old 03-19-2015, 06:14 PM   #6
Jvibe92's Avatar
Right on. Just confirming. Torque specs are 130 for these bolts right?
Old 03-19-2015, 06:16 PM   #7
They are whatever the manufacturer of the arms (BMR) tells you they are. Those specs are for the factory arms. Factory arms have massive steel sleeves in them, to support the mushy rubber bushing.
Old 03-19-2015, 06:26 PM   #8
Jvibe92's Avatar
Yeah probably wouldn't get to that number anyways while laying on my back. Not enough leverage. BMR does say 130. Lol
Old 03-19-2015, 06:31 PM   #9
Huh, do you only have one arm or something? 130 lbs with a 2 foot torque wrench is nothing. I'm barely a buck fifty myself and had no trouble zipping to 130 on the garage floor. It's all about the miracle of leverage and body position....
Old 03-19-2015, 07:23 PM   #10
Jvibe92's Avatar
My torque wrench is like a foot issh plus. Can't seem to get good position
Old 03-19-2015, 07:33 PM   #11
It's less than ideal but, put an extension on it to get it outside the body area and you should be able to lean on it. I did it bracing my legs against the axle drivers side and pushing back into it. Pass side a little less easy but put my back against the floorboard and pushed with my mass.
Wait til you try the UCA main bolt that's tightened to like 350 lb/ft.....
Old 03-19-2015, 08:02 PM   #12
2014oxstang's Avatar
The main bolt was fun....lol
2014oxstang is offline   Reply With Quote
Old 03-19-2015, 08:07 PM   #13
2 Stangz's Avatar
Region: Nevada
Yeah sometimes you just have to use a little force, at your own discretion of course
Old 03-19-2015, 09:21 PM   #14
Famine's Avatar
Region: South Dakota
I had a hard time getting the drivers side to line up but once I got that one, the other was easy. Torque wasn't that bad. Do you even lift? Lol...always wanted to use that.
Famine is offline   Reply With Quote
BMR LCA Grease RaceRed3.7 2011-2014 V6 Mustang 5 01-24-2015 03:19 PM
Installed BMR adjustable UCA, LCA, loud noise/clunk on sharp turns Riko 2011-2014 Mustang GT 24 12-14-2014 02:46 PM
Squeaky Right BMR LCA OzzyLiriano 2011-2014 Mustang GT 15 03-29-2013 09:46 AM
Front end align 98mustang11 Pre-2005 V6 Mustang 6 02-15-2013 11:52 AM
How Do I Clean Out My Holes? ...spark plug holes? Nel86 General Car Discussion 8 08-06-2011 03:55 PM
11:16 PM
