Camaro SS Brembo Brakes - Mustang Evolution
Old 03-20-2015, 10:14 PM   #1
tgmeyer's Avatar
I've been wondering.. Will the Camaro's Brembo brakes (front and rear) fit on a 2013-2014 GT? Also, is it possible to fit 18's wheels with them on?
Sent from my SCH-R970 using Mustang Evolution mobile app
tgmeyer is offline   Reply With Quote
Old 03-21-2015, 12:03 AM   #2
tgmeyer's Avatar
Like these--
Old 03-21-2015, 12:08 AM   #3
Originally Posted by tgmeyer View Post
Like these--
Doubt it
Old 03-21-2015, 03:41 AM   #4
The fronts probably would but don't quote me on that. I'd love to get a set of rears and try it out though
Old 03-21-2015, 07:46 AM   #5
The fronts look identical to the Mustang Brembo's (I have a Camaro V6 with the SS Brembo's on them). The rears might fit but it will be up to the spacing on the caliper bolts. There are 18" wheels that will fit on the Camaro but they have some good backspacing on them, might stick out on the Mustang.
Don't really think the Mustang needs brembo's on the rear except for looks, my fully loaded Mustang 5.0 weighs almost 100 lbs less than my stripped down 1LT Camaro V6. The Camaro is a pig that needs big brakes.
If I have to take apart the rear knuck on my Camaro soon I can do a test fit. Might have damaged my wheel hub from hopping at the track.
2014 Mustang 5.0 Brembo Package, 401A
2010 Camaro V6 Supercharged
MagnumForceGB is offline   Reply With Quote
Old 03-21-2015, 09:33 AM   #6
tgmeyer's Avatar
It would be solely for looks! Haha, I love the look of big breaks in the front and back. But definitely let me know if they will fit, when you take apart your Camaro. Would be highly appreciated!
Old 03-21-2015, 09:35 AM   #7
I dunno, the rear brake size is radically different between the two cars. The Mustang has 11.8 inch rears and Camaro SS has 14.3 which suggests the caliper bracket on the Mustang would likely put the caliper in the wrong place, even if it bolted up. The rear brakes are also a different type, using a single piston with attachments at the far ends of the cali, so, I don't think that'll work, just visually. Based upon my takeapart of the rears last week, I'd have to say no way.
You are also bound to freak the **** out of the ABS, TC and advancetrack, which is a lot of hassle for "looks".
As has been stated, BBP front is all that's really needed on the road for a Mustang weight car. Really need something bigger, you might have better luck with GT500 stuff but, I haven't researched that as to fit in any way, same as this.
Old 03-21-2015, 10:21 AM   #8
GT500 brakes will fit on the GTs and V6s. But you have to run at least a 19 ideally since they are 15" 6 pot. There is a kit on AM
Old 03-21-2015, 11:27 AM   #9
Personally wouldn't go 6 pot up front if I already had 4 pot. Pad choices at this time are slim and expensive and the additional unsprung weight isn't helpful either. Add the wheel fitment challenges and it starts to look like a zero-sum game. If looks are the deal, like the op says, the back brakes need the help over the fronts.
I like the relatively plentiful and inexpensive good quality pad choices of the 11-14 BBP setup.
Here's a functional rear upgrade but, it still uses the charmingly unsophisticated single piston caliper so definitely function over looks:
S197 Mustang 13.8" GT500 Rear Brake Upgrade Kit - Vorshlag LLC
Baer makes a wicked kit for a demonically high price:
Baer Brakes Mustang Rear Disc Brake Kit 14" Pro Plus 2005-2012
Oh yeah and to add to the hassles fitting the Camaro brakes, the E brake isn't likely to work anymore either....
Old 03-21-2015, 11:46 AM   #10
What would be even better than more braking power.... Less weight. That will mean less force needed to stop and less power needed to accelerate. Kill 2 birds with one stone (more like 3 if you count cornering also)
Old 03-21-2015, 05:34 PM   #11
tgmeyer's Avatar
Do you know if the 07-14 GT500 Brembo Brakes will fit a 13-14 GT?
Sent from my SM-T807R4 using Mustang Evolution mobile app
Old 03-21-2015, 05:37 PM   #12
07-12 GT500 brakes are the 14" 4 pot like normal Brembos on 11+ GTs. It's the 13-14 that are the 15"
Old 03-21-2015, 08:58 PM   #13
tgmeyer's Avatar
Awesome! Appreciate the help!
Old 03-22-2015, 08:21 PM   #14
Diehard's Avatar
Thought the 13-14 Brembos were 14" and the 2015 are 15"
Old 03-22-2015, 09:10 PM   #15
Read...it's the 13-14 gt500 he's referring to. They are 15 inch 6 pots.
Old 03-22-2015, 09:22 PM   #16
olerodder's Avatar
Region: Oregon
My TrakPak has 4 pots, and even the GT500 only has a single pot with 13.8" rotors in the rear. The calipers on the 13/14 GT are the same as the GT500. All you need is this adapter to move the calipers up to fit the 13.8" GT500 rotors and you are in business and you don't even need to remove the axles....
05 14 Mustang 14" Rear Brake Adapter Brackets GT Boss 302 GT500 V6 Free Shipping | eBay
Then just buy some EBC rotors, or pay $92ea. for Ford OE rotors and you've got 14" rotors in front and 13.8" out back.
Old 03-22-2015, 09:48 PM   #17
2007-2012 GT500 = 14" 4 pot
2011-2014 GT (brembo) = 14" 4 pot
2013-2014 GT500 = 15" 6 pot
2015 GT (Brembo) = 15" 6 pot
You can see a pattern, GT500 gets them first and then the GT as an option.
Old 03-23-2015, 04:16 PM   #18
Jbone007's Avatar
I have been thinking about the brake upgrade also, since I already have the 20 inch wheels the stock brake setup looks so small! I hope to find a used set off a 2013-14 GT500 but, also looked at the complete set from AM.
Ford Racing Brembo 6-Piston Mustang Brake Upgrade Kit - 15in Rotor M-2300-T (05-14 GT, Bullitt, Boss, GT500) - Free Shipping
Jbone007 is offline   Reply With Quote
Old 03-23-2015, 05:51 PM   #19
Diehard's Avatar
don't forget...50 posts gets you a 6% discount from AM.
Old 03-24-2015, 11:57 AM   #20
olerodder's Avatar
Region: Oregon
If you were to buy the front Brembo 15" kit, then buy 13.8" rear rotors and just get the adapters I posted a link earlier you can use you stock rear calipers. The GT rear calipers are the same as the GT500. I just purchased the rear 13.8" upgrade for $315.
If you purchase the upgrade use posted you will have to pull the axles on your rear end to installed the caliper brackest.
I've seen Brembo 15" GT500 brakes go used for $700. You might contact Shelby American in Las Vegas as they sell them regularly used.
Old 03-24-2015, 12:03 PM   #21
Jbone007's Avatar
Thanks olerodder, did not thing about that! I am bidding on a set now on e-bay, was just out bit at $450.00 but still a few days to go!
Old 03-24-2015, 12:14 PM   #22
Jbone007's Avatar
13-14 SHELBY GT500 BREMBO 6 PISTON FRONT ...
US $455.00 5 bids 5d 7h
post 24 almost 1/2 way there lol!
Old 03-24-2015, 12:22 PM   #23
Jbone007's Avatar
Wow bit is over 600 now!
Old 03-24-2015, 01:20 PM   #24
olerodder's Avatar
Region: Oregon
The vendor is Shelby in Las Vegas. Yes, I've seen them around $750/800.
Old 03-24-2015, 01:24 PM   #25
Jbone007's Avatar
Yep just noticed it after I looked at who was selling them, did not realize it was actually Shelby's e-bay store when I 1st started bidding on them.
To Brembo or not to Brembo (13 GT?) MustangCPA General Mustang Discussion 14 03-20-2015 09:21 AM
Camaro Brembo's on Mustang? alexblackGt 2011-2014 Mustang GT 1 09-08-2014 05:48 AM
Brembo GT-R Brakes? AGG 2011-2014 Mustang GT 16 07-12-2012 03:46 AM
2010+ Mustang with Brembo Brakes msgt46270 2011-2014 Mustang GT 2 09-13-2011 09:47 AM
04 saleen brembo brakes f/s MUTstang99 Mustang Parts for Sale and Wanted 2 12-26-2007 05:42 AM
04:28 AM
